-   -   towing bridle (http://www.defendersource.com/forum/f6/towing-bridle-16407.html)
hamiamham July 22nd, 2008 09:56 PM
towing bridle
im going to replace my factory tie-downs in the front with jate rings and was wondering if anyone had . suggestions for a towing bridle (strap/rope/chain?) that can be used with this set-up>
hamiamham July 23rd, 2008 12:01 AM
let me clarify; a bridle to attach to a yank strap or similar for getting out of stuck situations not towing per se
Cred November 30th, 2008 08:03 PM
Did you ever get an answer on this question. I am wondering as well.
Antichrist December 1st, 2008 01:58 PM
Two of these
http://www.amazon.com/BullDog-Tree-S...8157770&sr=1-8
and a screw pin shackle of suitable rating should give you what you want.
LRNAD90 December 1st, 2008 02:04 PM
Just make sure that the length of the bridle 'legs' is at least twice the length of the distance between the two tow hooks. If it is not, there will be an inward component to the pull that will not be well received by the frame rails...
Antichrist December 1st, 2008 04:27 PM
Yes, 8' straps might be better, depending on that distance.
