-   -   Compression testing a 300tdi (http://www.defendersource.com/forum/f6/compression-testing-a-300tdi-15780.html)
Hoosier May 27th, 2008 08:41 PM
I am interested in doing a compression test on my tdi engine. The book calls for a dummy injector from kit LRT-19-007. Anyone done this or know where to find the necessary stuff?
Landspeed May 27th, 2008 10:15 PM
Me too.
I would also like to know how to do this.
MonLand May 28th, 2008 10:37 AM
I'd assume that any shop would be able to just remove the glow plug and do the compression test through there so that you would not have to mess with the injectors?
Now... I'd been a while since I've seen any tdi injectors, are they electrically triggered (i.e. easy to disable by just removing a plug) or is there an injection pump with a cylinder per engine cylinder like on the old(er) 2.5L? In that case, you probably would have to disconnect the injector from the fuel rail.
Hoosier May 28th, 2008 03:29 PM
The LRT-19-007 does use a bosche dummy iinjector and is what is called for in the service manual. I am not opposed to using the glow plug port, but don't know what the 200/300 tdi glow plug is equivalent to in the GM/Ford/VW world. Anyone have an idea?
