-   -   300 tdi intercooler (http://www.defendersource.com/forum/f6/300-tdi-intercooler-15712.html)
Abrooks May 20th, 2008 09:51 PM
300 tdi intercooler
anyone know anything about the "full size" intercoolers that are being sold on ebay?
http://cgi.ebay.com/ebaymotors/LAND-...m140233052800&
Uncle Douglas May 20th, 2008 10:25 PM
and the hot rodding begins- I am jelous. Nice avatar
Buckon37s May 20th, 2008 10:44 PM
I don't know anything about it, but I would go for it. At that price, there is little reason not too. Intercoolers are not that involved. Bigger mostly means better.
Pat May 21st, 2008 10:24 AM
1 Attachment(s)
A not well designed bigger intercooler could also be more restrictive or not cooling at all...
The pic shows the Allard intercooler. Watching the intercooler at ebay I'm not sure if it has the chamber splitter... I would check that out first...
Retrofit May 21st, 2008 10:34 AM
Yep ! I agree with that Pat, splitting the chamber is of real importance it doubles the cooling time of the air as it has to go through the whole intercooler, or else keep the one you have you will not see that much in added cooling.
My 2cents.
Pat
revor May 21st, 2008 10:40 AM
I've been banging this intercooler thing around in my head for a bit. It seems that the core on the factory intercooler is quite restrictive. I have this thought and I'm going to try it out. If I replace the factory core with a less restrictive core such as a bar and plate there could be as much as a 75% increase in flow, all the flow does nothing for you unless the inter cooler cools the intake charge. I am waiting for an old intercooler to be shipped then I will procede with my experiments.
The only reason I'm playing with this is that I wonder just how much this little tractor motor needs. Given the total CFM of throughput the motor can generate I don't know that a huge intercooler will add that much to the bottom line. Good price though! And it looks to be of good quality..
Buy it or I will!
D90user May 21st, 2008 11:47 AM
I just wrote the seller to ask if there was any baffle or divider to force air through the larger cooling area... will post up when he replies.
Abrooks May 21st, 2008 12:19 PM
And I wrote to them last night trying to get more info. I'll obviously post up when I hear anything.
Pat May 21st, 2008 12:20 PM
other point to take into account is that even when the ebay intercooler core looks less restrictive to the intake air flow it will behave much more restrictive to the external air flow ...
don't forget behind the intercooler we have a radiator that also needs a good airflow...
the new intercooler reduces the radiator air flow in 50% of its area....
revor May 21st, 2008 12:42 PM
Great point! That is a Bar and Plate core, probably the best as far as efficiency goes (all the turbo ricers use them) But two things happen, you are covering the rad, probably not that big of a deal especially if you take advantage to the extra space left from the old intercooler and increase the core of the rad. Also the air in the intercooler is changing direction, it may not seem like a big deal with compressed air but ther is a substantial loss in volume due to friction in the intercooler even when going straight, for every 90o bend in a pipe the math says to add a significant amount of length to which the compressed air needs to travel.
Example 2 1/2" pipe 115 PSi compressed air add the friction loss equivelent to 10 additional inches of pipe for each 90o bend the air has go through. Might not seem to be a lot but to maintain the same volume of compressed air with 5 of these bends will make it nessesary to increase the pipe diameter by 1/4"
artm May 21st, 2008 12:43 PM
1. For the price, size and apparent quality, this is worth a try.
2. As Keith said, the CFM we're talking about is way below the IC's rating, again judging by the size alone.
3. For those with AC, a better solution (for me) is the following water-to-air model:
http://www.pwr.com.au/coolers_ltoa.html
Even the smallest one is plenty for the Tdi. The cooling fan (not theirs but any generic one) fits in place of the stock IC.
revor May 21st, 2008 12:48 PM
Water cooled..... NIIIIICE....
TDI Guy May 21st, 2008 07:06 PM
I would like to get a larger intercooler as well.. just installed a NRP exhaust from RN so its breathing very well... No mufflers, just 2 resonators.. now for some more air flow... Then I just will have eo ship Pendy to my house to tweak my injector pump...
Abrooks May 21st, 2008 07:59 PM
So while we're all sitting around waiting to hear back from the seller, what is the most effective was to take advantage of a larger intercooler? there are a variety of threads out there talking about turning up boost and fueling, what are people's first hand experiences?
tmore May 21st, 2008 09:14 PM
I bought one off of E-bay new about a 18 mnths ago or so. I don't think it was from this same company but will check. The install was simple and it made a huge differance in the egt. I have "tuned" the injection pump per the instrucyions on this site and it works great, huge power increase. As far as the wider intercooler interfering with the air to the radiator I have not noticed a differance, I can run mine all day in stop and go or crawling on the trail with no issue, I do heat up pretty quick at highway speed over mountain passes but never seem to get egt over 1000.
Follow-up Post:
Keith, are you waiting on an old factory size intercooler or an oversized? I have a factory size in my garage that you are welcome to experiment with. I also have a spearco racing intercooler that overall is 11"x17" with the core being 7x17. it is oriented differant that the the defender oversize units with the "tanks" on the top and bottom and the tubes vertical. It looks like it would be easy to cut down to size ( lenghth wise) is neccessary. Spearco makes good stuff, i have used them in other vehicles. If you have any interest let me know
revor May 21st, 2008 10:50 PM
Hey Tom
I am going to be experimenting with several thoughts, one being stuffing as big a bar and plate core as possible between the factory tanks and in teh factory location. I may purchase one from teh guy on E bay as well... Then it's off to the flow bench to test them.. Some simple math should confirm what the temperature drop should be.
I keep hearing from the tuner dudes that "the Turbo should be as big as it can be but not too big" what the heck that means is beyond me but i wanna find out.. We should try and hook up!
pendy May 22nd, 2008 01:08 AM
There is no cheap way to do this correctly. IMO And fit and finish of the install makes all the difference. As well as keeping oversized parts from damaging each other.
JP
Muscat May 22nd, 2008 04:19 AM
The same intercooler has been up for sale before - at least the pictures on this sale are identical to those on an earlier auction. I emailed the seller and received the following reply:
It is manufactured by XS Power
it can hold up to 8oo hp application no problem
800hp. from my 300tdi. I wish...
Abrooks May 22nd, 2008 08:29 AM
And the response I got was:
The warranty is 30 days against manufactures defects.
Sorry don't have a number on performance increase as this item is more to make sure the rest of your setup works efficiently and can handle more power than what anyone would want to use in most cases.
dmarchand May 22nd, 2008 08:37 AM
You of all people can make the adjustments to the pump. It is easy.
Going full width lowered my egt by 250 degrees. I was never at the magic 1200-1300 degree mark but have come close. Now I can't get it above 900 no matter how much I flog it (and that was on a long uphill pulling a trailer).
