I can't seem to find this info anywhere but does anyone know what size bulbs fit in various parts of the dash? I believe 194 wedge bulbs are what I need for the gauges. Is this correct? Do all the gauges use the same bulb? Most importantly, what size bulbs fit the various switches such as the rear wiper switch, hazzard switch, defroster and heated windshield switches?
When I replaced the hazard and rear defroster switch bulbs I used the 1.2W bulbs, RTC3635, from Atlantic British. I'd guess the bulbs are also available from other sources. I have not needed to replace any of the gauge bulbs, so no help there.
T.J.
I replaced the bulbs by gently prying the switch covers off with a flat blade screw driver. Removed and replaced the bulbs with needle nose pliers with cloth taped to the jaws for cushion; its a tight fit. Pushed the switch covers back on.
Andrew,
Do a thread search under dash or LEDs. Several threads on replacing the bulbs with these.
Mine is a mess with half the lights out. On the short list..
Related Threads
Defender Source Forum
1M posts
24.1K members
Since 2003
