York onboard air bracket - Defender Source
Old December 15th, 2014, 09:58 PM
RockShow's Avatar
RockShow
Ben Goodwin
1996 D1
Compressor mounting bracket for a york onboard air setup on a rover V8 suction side up. $75 plus ship
Old December 15th, 2014, 09:59 PM
RockShow's Avatar
RockShow
Ben Goodwin
1996 D1
Old January 15th, 2015, 10:26 AM
RockShow's Avatar
RockShow
Ben Goodwin
1996 D1
Including serp belt to make it all work
Old January 15th, 2015, 01:01 PM
lightwriter's Avatar
lightwriter
Carlos Ascencio
'84 One Ten
Will it fit on a 80's 3.5 and a 90's 3.9?
Old January 15th, 2015, 03:12 PM
RockShow's Avatar
RockShow
Ben Goodwin
1996 D1
The bracket is pretty flexible as far as mounting goes so it would probably fit somehow on the carb motors too but I am not 100%.
Old January 15th, 2015, 03:13 PM
Do you still have the pump too?
Old January 15th, 2015, 05:42 PM
RockShow's Avatar
RockShow
Ben Goodwin
1996 D1
I have two actually, either suction side. I am going to hook one up to my Duramax and I haven't decided how to mount it yet. Once I get it figured out I will sell the other one.
If you haven't looked into it yet, the pump is the cheap part! It's the damn specialized fittings and the coalescing filter that make it expensive. Kilby ain't cheap!
Old January 15th, 2015, 05:45 PM
chris snell's Avatar
chris snell
Chris Snell
87 Ex-MOD 110
When you pull the bracket off, would you mind taking some more photos of it? I still need a York bracket for the 300Tdi.
1987 Ex-MOD 110 Tithonus LHD
2013 LR4
Old January 15th, 2015, 05:56 PM
RockShow's Avatar
RockShow
Ben Goodwin
1996 D1
On the 300 all you need is a flat piece of plate to bolt on the AC mounting spot.
Old January 15th, 2015, 06:16 PM
chris snell
Chris Snell
87 Ex-MOD 110
I would prefer a bracket with the ability to tension the belt. A forum member in Colorado (Chris Davis?) built one that had a rotating part that could be adjusted to proper belt tension.
2013 LR4
Old January 15th, 2015, 06:20 PM
RockShow's Avatar
RockShow
Ben Goodwin
1996 D1
Just have a shop cut channels in the piece of plate so you can slide the plate out then tighten it down.
Onboard air setup help needed. RickM Defender Technical Discussions 10 March 9th, 2014 11:12 PM
Onboard air ideas/not locker related RickM Defender Technical Discussions 35 February 19th, 2014 08:26 PM
York 210 On Board Air Compressor for V-belt Davis For Sale - Parts 13 March 31st, 2011 09:12 PM
Onboard air mdmccallum Defender Technical Discussions 15 October 14th, 2007 07:35 PM
Land Rover G4 Challenge - New York City, New York USA chrisvonc Trip & Trail Reports 0 February 4th, 2004 03:40 PM
