York 210 On Board Air Compressor for V-belt - Defender Source
Old June 23rd, 2010, 03:18 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
I am converting my front cover to a serpentine belt/crank driven oil pump which means that my York Air Compressor will have to go bye-bye. Up for sale is a York 210 compressor with a custom (made by me) bracket that bolts right onto your engine if you are NOT running an air compressor and have a v-belt set up. It works fantastic--it will drive air tools, fill up your tires, keep your ARB compressor running, use it to inflate blow-up dolls for those long cold winter nights. The clutch works fantastic and I just replaced the bearing when I rebuilt the motor a month or so ago so that should be good to go for years and years. It is still hooked up to my truck, so if you are local and want to check it out, it works fantastic. Many of you that have wheeled with me have used it and can attest to it's power. The York 210 is the strongest engine run air compressor that I know of and I HATE to see it go but it is physically won't fit with the serpentine set up.
The bracket is designed to rotate to adjust for belt tension so a separate tensioner is unnecessary. Pretty cool design, IMHO.
What you get: York 210 air compressor with v-belt pulley installed, working clutch, and a couple v-belts to fine tune it to your application, the mounting bracket, the mounting hardware. Blow up doll extra. Shipping extra but it can go via UPS.
$250.00 plus shipping if not local.
Old June 23rd, 2010, 03:30 PM
diesel_jim's Avatar
diesel_jim
Jamie Austin
Why not buy a serpentine pulley from Kilby?
That's what i did on my one... which is still sat in the garage awaiting for me to try and glue it to the Td5!
Old June 23rd, 2010, 04:44 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
Can't. With the serpentine set up, the alternator swaps sides of the engine so there physically is not room to fit it anywhere. I have looked at other peoples serp set ups since they wanted me to fab a bracket so they could use the york but we couldn't find a good place to fit it. I will have to figure out a Sanden set up which shouldn't be too difficult but does not put out nearly what the York does. The York is king of the hill.
Old June 23rd, 2010, 07:11 PM
John_Karlsson
John Karlsson
1966 Series IIA 88 SW
How much for the blowup doll, and what is her name. Picture?
John Karlsson
Hope Valley, RI
Old June 24th, 2010, 02:17 PM
ArmyRover's Avatar
ArmyRover
Bill Ski
83 110 "Frankenstein"
so does this replace the ac compressor on the v belt motors?
Unknown Author
716-898-8153
Old June 24th, 2010, 02:24 PM
Gore Ranger's Avatar
Gore Ranger
Jeff
1989 RRC
Oh man, that's cool. If I didn't move to Denver and decide to get the AC fixed (bye bye cool mountain airs) I would be all over this. Sweet deal!
Old June 24th, 2010, 03:37 PM
bharris's Avatar
bharris
Brad Harris
1994 d90 300tdi "Nola"
This is exactly what I've wanted to do... but the bracket isn't going to fit a 300tdi so I'm out...
Old June 25th, 2010, 10:03 AM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
Bill--yes, it replaces the AC on v-belt set ups. John, I never got her name--it was a quick affair which left me light as air but left her deflated so we called it quits.
Old June 27th, 2010, 01:53 PM
seaswood
Diesel
Would that work with a 2,5 NA?
Mounting R side of diesel there are 4 mounting bolts.
Thanx
Old June 27th, 2010, 10:33 PM
Thanx
No. But it is simple (compared to a V8). Took me 30 minutes to make a bracket for a 2.5NA. $25 compressor, 5 minutes at a the junkyard and voila... If you want pictures of the 2.5 NA bracket, let me know. Don't want to mess (more) with this thread.
Old June 28th, 2010, 05:18 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
Priced reduced for 2 days to $150 (plus shipping) then to ebay.
Thanks!
chris
Old March 11th, 2011, 01:05 AM
chris snell's Avatar
chris snell
Chris Snell
87 Ex-MOD 110
Chris, did you ever sell this? I'm looking for the bracket. Any chance you'd make another?
Old March 31st, 2011, 09:47 AM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
It is still available--there was a gent up in Breck that was going to take it but his D90's engine conked and he ended up with a disco serp engine. We can chat--just sent you a pm.
Old March 31st, 2011, 09:12 PM
junkyddog11's Avatar
junkyddog11
oil soaked filter
95 RRC 300tdi
There is actually a factory bracket to mount a York to a V-belt V8. RRC early to mid 80's had York compressor.
Mounting them to a Tdi is a pain in the arse as it has to lay down and there just isn't much room, complicated bracket to fab.
Matt Browne
compressor
Belt driven air compressor set-up sheki Defender Technical Discussions 16 March 2nd, 2005 04:00 PM
CO2, ARB on board air! TwisteD90 For Sale - Parts 4 June 16th, 2004 11:43 PM
On board air compressor Davis Defender Technical Discussions 5 March 7th, 2004 08:28 PM
On Board Air javelinadave Misc. Chit-Chat 13 December 2nd, 2003 12:41 PM
