Webasto coolant heater $600 - Defender Source
Old August 31st, 2014, 10:24 PM
12v Webasto thermo top C/Z coolant heater with (i believe) 7 day timer.
ID:	101895 Click image for larger version
ID:	101896 Click image for larger version
ID:	101897 Click image for larger version
ID:	101904 Click image for larger version
ID:	101899 Click image for larger version
ID:	101900 Click image for larger version
ID:	101901 Click image for larger version
$600. Funds go to Kent's build.
Originally Posted by pendy
I'm here for the D's
Old August 31st, 2014, 10:36 PM
the rover shop
shayne young
Gas or diesel.. Decal looks like gasoline..??
Old August 31st, 2014, 10:47 PM
I dunno I thought they were all diesel? Model is 85977G, and yes the label says Benzin, which my buddy google says means gasoline in German.
Old September 1st, 2014, 09:15 AM
scrubs
henery
1974
Good price! GLWS
Old September 8th, 2014, 05:56 PM
Bump. Winter will be here before you know it.
Old September 8th, 2014, 07:40 PM
tjfslaughter's Avatar
tjfslaughter
thomas
Burbon
That is a awesome deal for a gas version. Hell the timer alone is worth 200 bucks. This should not last long.
Old September 8th, 2014, 08:39 PM
Fearnofish's Avatar
Fearnofish
85 110 CSW
Wonder what it would take to convert to diesel?
Old September 8th, 2014, 09:28 PM
NPT90's Avatar
NPT90
JT
D90 óriginalé
I imagine not as much as we might all think; tho prolly easier to just buy a diesel variant
Old September 8th, 2014, 10:03 PM
tjfslaughter
thomas
Burbon
Not an option. Imagine converting an engine from gas to diesel using the same block, intake, etc...
Old September 8th, 2014, 10:49 PM
http://empirenews.net/meteorologists...ected-to-soar/
Mark Kellgren
KM4BOR
Old September 9th, 2014, 07:17 AM
Originally Posted by Overlander View Post
The onion post?
Old October 6th, 2014, 04:39 PM
85Red110's Avatar
85Red110
Kent
1985 110 3-door
Bump. Someone must want this, right? Make me an offer. The truck build piggy bank is empty and there is still more to do.
Kent
1985 Land Rover 110 3-door ST
Old October 6th, 2014, 06:42 PM
Roving Beetle
Doug
Was this a known working unit - fully functional? For sure?
Doug
Series coiler monster in building process, in gather parts mode.
Currently driving an ex-southern 1993 SWB RRC with too much "kit". Massive conversion and interior swap in process.
Lots, lots and lots more have come and gone....
Old October 7th, 2014, 04:56 PM
85Red110's Avatar
85Red110
Kent
1985 110 3-door
Doug
Havent tested it since its been in our possession, but I have asked Greg (gchinsr) to chime in here about it. I assume it works perfectly, as his plan was to install it on this truck for his expedition vehicle project.
Kent
Old October 7th, 2014, 06:38 PM
Roving Beetle
Doug
Thank you.
Let me know - I just want to be sure as parts are quite dear for them.
Doug.
Old October 7th, 2014, 07:00 PM
gchinsr's Avatar
gchinsr
Greg Chin Sr
1996 Discovery 5 Speed
The heater was removed from a 110, in good working order when I bought it. This was going to be installed in the camper conversion. Every once in a while, it will go into "interlock mode" and the timer needs to be turned off, then reset to start it. I don't know enough about the inner workings to figure it out, but after resetting the timer it will start up, so did not look into it any more. I will check later today, as I may still have the results from the bench testing on this.
Greg
Old October 8th, 2014, 04:56 PM
gchinsr's Avatar
gchinsr
Greg Chin Sr
Sorry for the delay, I really need to rename my files. Here is the bench test screen shot.
Greg
Old December 19th, 2014, 04:46 PM
85Red110's Avatar
85Red110
Kent
1985 110 3-door
Bump
Make an offer!
Old January 6th, 2015, 08:08 AM
85Red110's Avatar
85Red110
Kent
1985 110 3-door
Bumpity bump
Old January 6th, 2015, 01:21 PM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
I cannot believe someone hasn't snapped this up.
coolant, heater, webasto
Webasto coolant heater roverx For Sale - Parts 9 November 18th, 2013 07:16 PM
Webasto coolant heater and heated seats. tjfslaughter Defender Technical Discussions 3 December 21st, 2012 11:28 PM
Webasto Air Heater Install ideas... tjfslaughter Defender Technical Discussions 10 October 28th, 2011 12:51 PM
Has anyone installed Webasto or Espar heater? Gkase Defender Technical Discussions 48 December 11th, 2007 06:15 AM
Webasto Heater roverx Defender Technical Discussions 1 November 29th, 2005 06:37 PM
