Wanted: Rear axle fulcrum bracket - Defender Source
Old April 17th, 2015, 02:41 PM
Wilboro's Avatar
Wilboro
William Ficner
1997 110 csw
So I've lost the battle getting one of the old bolts and the ball joint out of my bracket, so I need a new one.
Anyone have one kicking around for a reasonable price? Used is fine, although I feel like that's kind of unlikely considering the state of mine.
Old April 17th, 2015, 02:47 PM
Wilboro's Avatar
Wilboro
William Ficner
1997 110 csw
WHOOPS wrong area. Mods can you move this please!
Old April 18th, 2015, 04:11 PM
Wilboro's Avatar
Wilboro
William Ficner
1997 110 csw
Ok call off the search. Got the old one cherry red and used two sledges and now I can reuse it! Click image for larger version
Old April 19th, 2015, 01:41 AM
Fearnofish's Avatar
Fearnofish
85 110 CSW
Cherry red... Hopefully you didn't take the temper out that steel...
Old April 19th, 2015, 07:35 AM
Wilboro's Avatar
Wilboro
William Ficner
1997 110 csw
Only about 1.5" of the outer face (where the ball joint goes) got that hot and it was left to air cool, so I think it's likely fine.
Old April 19th, 2015, 12:00 PM
Fearnofish's Avatar
Fearnofish
85 110 CSW
Fair enough. Just didn't want it to go unsaid and have an accident later. Wish you luck.
Old April 19th, 2015, 12:54 PM
I very much doubt these are made from high strength steel.
Old April 19th, 2015, 06:50 PM
Fearnofish's Avatar
Fearnofish
85 110 CSW
You're probably right but the forged piece has a specific rigidness to withstand the forces of the axel. Heating that up to "cherry" may soften that steel a bit. It's worth discussing if it prevents an accident or other components being damaged due to it bending or failing.
Old April 19th, 2015, 07:07 PM
Wilboro's Avatar
Wilboro
William Ficner
1997 110 csw
Are these not cast pieces? Didn't think they were forged
Old April 19th, 2015, 07:28 PM
Of all the components on a defender I cannot see this one failing ... It's just rough cast with 3 holes and 2 bolt holes. It gets its strength from bulk rather than conditioning of the metal.
Fearnofish's Avatar
Fearnofish
85 110 CSW
Well if that's the case then I stand corrected. Just lookin out for a fellow D90 member. Good luck with the build.
Old April 19th, 2015, 07:48 PM
Wilboro's Avatar
Wilboro
William Ficner
1997 110 csw
Hey always good to think things through!
ac, axle, bracket, rack, wanted
Pics of HD rear axle vs stock axle? josh-man Defender Technical Discussions 22 July 4th, 2017 04:22 AM
rte radius arms causing axle to foul panhard bracket sonoronos Defender Technical Discussions 30 August 5th, 2014 01:35 PM
1997 D-90 rear axle housing and 83' 110 front axle housing Tyler Wirken For Sale - Parts 0 January 3rd, 2012 06:31 PM
Series III Rear Axle (Drum-to-Drum or Axle Housing) Lriwater Wanted 0 September 7th, 2009 08:08 PM
NAS Style NTO Windscreen Bracket. ROW Bracket / Clamps Kits FS SafariHP The Vendors Loft 0 February 19th, 2009 07:15 AM
