Urge to purge V1 - Defender Source
Old November 2nd, 2014, 10:44 AM
Let's get going here. CRC 1250L pipe clip bag of ten. $5 Click image for larger version
ID:	106183 Box lot of silicone and ally plumbing $30 Click image for larger version
ID:	106184 4x Asr2667 stud plate $5 Click image for larger version
ID:	106185 504697 hasp for fuel cap $5 Click image for larger version
ID:	106186 HD clutch arm for 110 $15 Click image for larger version
ID:	106187 ECR 8980 dipstick tube 300 tdi and dipstick $15 Click image for larger version
ID:	106188 Click image for larger version
ID:	106189 Series clutch tool $5 Click image for larger version
ID:	106190 4x series refurb door latches. 2rh 2lh one no box $10 each or all for $35 Click image for larger version
ID:	106191 4x roof vents. $70 each or all for $225 includes inner trim rings not pictured. Click image for larger version
ID:	106192 Click image for larger version
ID:	106193 Lot 2 4x roof vents. Painted in and out. Includes trim rings $50 each or all four $175 Click image for larger version
ID:	106194 Driveshaft spacer 1 inch. $15 Click image for larger version
ID:	106195 Body shims 17 total. Buck each. Click image for larger version
ID:	106196 RRC air box slight rust on surface. $50 Click image for larger version
ID:	106197 Swiss or German lights. Plastic housing glass lenses h4 bulbs. $15 Click image for larger version
ID:	106198 Click image for larger version
ID:	106199 Set of RRC hella fogs. $75 Click image for larger version
ID:	106200 110 AC box. $25 Click image for larger version
ID:	106201 Click image for larger version
ID:	106202 RRC ABS cv joint. $75 Click image for larger version
ID:	106203 No clue. Make offer Click image for larger version
ID:	106204 200tdi turbo $100 Click image for larger version
ID:	106205 Click image for larger version
ID:	106206 Click image for larger version
ID:	106207 Approx 6' each red and black 2/0 battery cable w lugs and stuff. $20 each Click image for larger version
ID:	106208 Click image for larger version
ID:	106209 Click image for larger version
ID:	106210 Tdi water pump STC 1683 $50 Click image for larger version
ID:	106211 RRC heater box all working $100
Terrafirma HD tower retainers set $25
LT77 tunnel thing $50
Alloy grab handles $10 each
Steel grab handles need refurb $10 each
Lot of series rivet on weatherstripping. Includes a few bits of glass channel and the middle door doglegs. $50
Bulkhead to screen weatherstripping $5
Old November 2nd, 2014, 10:49 AM
grnrvrs's Avatar
grnrvrs
Paul
88
What is the diameter of the ally plumbing and silicone stuff? If 3" I'll take them.
1970 SIIA 88, Sold
Old November 2nd, 2014, 11:14 AM
roverman2010's Avatar
roverman2010
1985 LR 90 200Tdi
Bill I'll take take the tubing&hoses if less than 3" also fuel cap hasp and the four stud plates
Licked
tubing&hoses, fuel cap hasp & the four stud plates
water pump if it is STC 1693
Hey bill is that turbo good, real good? comes with that down pipe of sorts?
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
97 XK8 BRG FHC For Sale
Old November 2nd, 2014, 11:49 AM
More: 300 tdi oil cooler line $20 Click image for larger version
ID:	106223 Click image for larger version
ID:	106224 SPAL fan 11" pusher. VA11-AP7/C-57S 12v. No attaching hw you can order new for cheap. $40. Click image for larger version
ID:	106225 16" puller fan made in USA by Revcor. $35 Click image for larger version
ID:	106226 Series dual gauge BNIB $125 Click image for larger version
ID:	106227 Click image for larger version
ID:	106228 Right side bulkhead door pillar. $35 Click image for larger version
ID:	106229 Headlight surround $15 Click image for larger version
ID:	106230 Series tunnel rubber grommet $10 Click image for larger version
Series dash with plugs $15
Dunno. Free w postage
3 repro series hasp $5 each
5x 16x100mm bolts. All for $8
Door frame repair channel $15
Old November 2nd, 2014, 12:56 PM
RANGEROVERSURFER's Avatar
RANGEROVERSURFER
Tony
95/Range Rover Classic
Bill,
I will take the following Swiss or German lights. Plastic housing glass lenses h4 bulbs. $15
please let me know if $30.00 Paypal will cover this with flat rate shipping to Anchorage Alaska 99516.
please PM me any necessary information and if you have any other RRC odds and ends as I somehow now have 3 RRC SWB, 2 DD 1 resto proj....
Tony
Tony
1995 RRC SWB Chawton White
1990 RRC SWB Eastnor Green
1990 RRC SWB Mettalic Blue
Old November 2nd, 2014, 01:05 PM
Wilboro's Avatar
Wilboro
William Ficner
1997 110 csw
PM sent in regards to the 300tdi oil cooler line.
Old November 2nd, 2014, 02:30 PM
Bill, I'll take the headlight surround @ $15.
Old November 2nd, 2014, 03:09 PM
Fearnofish's Avatar
Fearnofish
85 110 CSW
Bill,
I'll take that reman exhaust down pipe if fits 200 tdi. (Depending on cost). Is it an Allard?
Old November 2nd, 2014, 04:13 PM
Iamkraig's Avatar
Iamkraig
Kraig
1987 defender 110
I will take the turbo with the pipe if it's not sold.
Old November 3rd, 2014, 04:56 PM
I'll take the intercooler piping and the batt cables and the puller fan
Old November 3rd, 2014, 05:33 PM
DB the pipes are sold sorry. Cables and fan yours
Old November 3rd, 2014, 05:53 PM
Update:
Originally Posted by o2batsea View Post
let's get going here. Crc 1250l pipe clip bag of ten. $5 Attachment 106183 box lot of silicone and ally plumbing $30 sold Attachment 106184 4x asr2667 stud plate $5 sold Attachment 106185 504697 hasp for fuel cap $5 sold Attachment 106186 hd clutch arm for 110 $15 Attachment 106187 ecr 8980 dipstick tube 300 tdi and dipstick $15 Attachment 106188 Attachment 106189 series clutch tool $5 Attachment 106190 4x series refurb door latches. 2rh 2lh one no box $10 each or all for $35 SOLD 1LH 1RH Attachment 106191 4x roof vents. $70 each or all for $225 includes inner trim rings not pictured. sold Attachment 106192 Attachment 106193 lot 2 4x roof vents. Painted in and out. Includes trim rings $50 each or all four $175 Attachment 106194 driveshaft spacer 1 inch. $15 Attachment 106195 body shims 17 total. Buck each. SOLD Attachment 106196 rrc air box slight rust on surface. $50 Attachment 106197 swiss or german lights. Plastic housing glass lenses h4 bulbs. $15 sold Attachment 106198 Attachment 106199 set of rrc hella fogs. $75 Attachment 106200 110 ac box. $25 Attachment 106201 Attachment 106202 rrc abs cv joint. $75 Attachment 106203 no clue. Make offer Attachment 106204 200tdi turbo $100 sold Attachment 106205 Attachment 106206 Attachment 106207 approx 6' each red and black 2/0 battery cable w lugs and stuff. $20 each sold Attachment 106208 Attachment 106209 Attachment 106210 tdi water pump stc 1683 $50 sold Attachment 106211 rrc heater box all working $100
Attachment 106213
Attachment 106214
terrafirma hd tower retainers set $25 sold
Attachment 106215
lt77 tunnel thing $50
Attachment 106216
alloy grab handles $10 each
Attachment 106217
steel grab handles need refurb $10 each
Attachment 106218
lot of series rivet on weatherstripping. Includes a few bits of glass channel and the middle door doglegs. $50
Attachment 106219
bulkhead to screen weatherstripping $5 sold
Attachment 106220
------ Follow up post added November 3rd, 2014 05:55 PM ------
Update:
more: 300 tdi oil cooler line $20 sold Attachment 106223 Attachment 106224 spal fan 11" pusher. Va11-ap7/c-57s 12v. No attaching hw you can order new for cheap. $40. Attachment 106225 16" puller fan made in usa by revcor. $35 sold Attachment 106226 series dual gauge bnib $125 Attachment 106227 Attachment 106228 right side bulkhead door pillar. $35 Attachment 106229 headlight surround $15 sold Attachment 106230 series tunnel rubber grommet $10 Attachment 106231
series dash with plugs $15
Attachment 106233
dunno. Free w postage
Attachment 106234
3 repro series hasp $5 each SOLD
Attachment 106235
Attachment 106236
door frame repair channel $15
Attachment 106238
Old November 3rd, 2014, 06:19 PM
Bill, I'll take the hasps and a handful of body shims. Cash at HH or paypal?
thanks,
charles
Originally Posted by pendy
I'm here for the D's
Old November 3rd, 2014, 06:27 PM
HH OK if you bring my brake pipe tool
Old November 3rd, 2014, 06:29 PM
Deal!
Old November 4th, 2014, 11:30 AM
Still available:
ECR 8980 dipstick tube 200 tdi and dipstick $15
2x series refurb door latches. 1rh 1lh one no box $10 each
Driveshaft spacer 1 inch. $15 SOLD
110 AC box. $25
SPAL fan 11" pusher. VA11-AP7/C-57S 12v. $40
Series dash with plugs $15 SOLD
Series dual gauge BNIB $125 SOLD
Old November 4th, 2014, 11:39 AM
I'll take the dash with plugs
Old November 4th, 2014, 11:42 AM
Those are almost perfect OE black and red plugs. Good grab.
Old November 4th, 2014, 11:52 AM
hi bill, i will take the driveshaft spacer please
Old November 4th, 2014, 11:54 AM
Yours Mr Kang
Code P1179 Purge Valve ? ERICZZ Defender Technical Discussions 3 September 22nd, 2009 04:20 PM
Just back from Dealer Purge ESR4222 Hammertime Defender Technical Discussions 7 February 9th, 2009 08:31 AM
Purge Valve ESR4222 Hammertime Wanted 0 February 6th, 2009 03:48 PM
The Great Parts Purge of 2006 evilfij For Sale - Parts 5 June 5th, 2006 04:27 PM
