TruTrac 3rds with 4.11 Gears - Defender Source
Old July 24th, 2012, 02:36 PM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
Kinda sorta a feeler, but looking to sell a pair of complete 3rds with TruTracs and 4.11 gears. The lockers and gears came from GBR, and Appalachin Off Road in MD set up the 3rds. Have both receipts - gears and lockers from GBR was $2k even, and setup was $300. 3k miles on them since they were built in May 2011.
Any takers at $1600?
Semper Fi!
Old July 24th, 2012, 03:59 PM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
I've been running this set-up for about 8 years and over 80k miles with no complaints. Probably isn't the most popular set-up but the simplicity and fewer fail points convinced me to and I'd do it again if I ever needed to.
Clay
Old July 24th, 2012, 04:09 PM
down_shift's Avatar
down_shift
Russell
94' D90 ST & 06' LR3
I would be very interested if 3.54 gears.
Old July 24th, 2012, 04:54 PM
Roverdoc's Avatar
Roverdoc
Dan Kemper
1997 D90 SW #278
Pmd you
Old July 24th, 2012, 05:26 PM
1of40's Avatar
1of40
1of40
Are you concerned about possible weakness in higher gears. FWIW, I spun a GBR front shaft in two pieces at a MAR once in a big mud-pit. Locker and the gears survived with no problems.
Old July 24th, 2012, 06:02 PM
Wolf Fabrication
Sterling Archer
'08 D3
Buy them and sell off the 4.11s. I'll even throw in the stock 3.54s so you can have them set up and ready.
Semper Fi!
Old July 24th, 2012, 06:23 PM
down_shift's Avatar
down_shift
Russell
It is low enough on stock gears with the 5-spd and 33". Even Huff is running 3.54 on 34". Not like folks wheeling in CO and UT at altitude where gearing could help, we have plenty of torque close to sea level.
Old July 24th, 2012, 07:57 PM
Damn, those 4.11.
Why are you selling them?
Old July 24th, 2012, 08:17 PM
Wolf Fabrication
Sterling Archer
'08 D3
Originally Posted by rover4x4
Damn, those 4.11.
I want ARBs.
Semper Fi!
Old July 24th, 2012, 08:29 PM
If you part them id be interested in the front.
Old July 24th, 2012, 08:43 PM
down_shift's Avatar
down_shift
Russell
And I'd be interested in the rear.
Old July 24th, 2012, 08:48 PM
Wolf Fabrication
Sterling Archer
'08 D3
I can split them, I don't care. Both of you are relatively close too. Phillip, are you coming up to VA anytime soon?
Semper Fi!
Old July 24th, 2012, 08:50 PM
Probably not for long The switch to 34's has changed his gear ratios enough to make him feel it.
I'll send you an email with the gear ratios and formula to calculate your final rear ratios and rpms if you want to see what 4.11's would do for you.
But personally I wouldn't go with the TTs over ARBs (sorry Jonathan)
Originally Posted by pendy
I'm here for the D's
Old July 24th, 2012, 08:52 PM
Roverdoc's Avatar
Roverdoc
Dan Kemper
1997 D90 SW #278
Are the fronts reverse cut and any issues since install?
Old July 24th, 2012, 09:09 PM
Wolf Fabrication
Sterling Archer
'08 D3
They came on my RRC I just bought. Not sure if they are reverse cut, but the invoice I have from GBR shows two separate part numbers - GBR414F and GBR414R - which I assume must mean they are 4.14 gears.
The TruTrac numbers are TT912A383 and TT912A407
Semper Fi!
Old July 24th, 2012, 09:50 PM
pushngo
Randy Williams
There is a guy on NELRC looking for a setup like that. Maybe with a Detroit but worth the shot
Old July 24th, 2012, 11:28 PM
I've got 5.13s you girly-man! Deal with it...4.11s won't kill you . They will puuuump [clap]...you up.
Old July 25th, 2012, 06:11 AM
junkyddog11's Avatar
junkyddog11
oil soaked filter
95 RRC 300tdi
It's been a while but I think that is 4:11 *4F* for front (reverse cut) and 4:11*4R* for rear. Not interchangeable, which goes for the TT's also. Keep them labelled LOL.
Matt Browne
Old July 25th, 2012, 06:13 AM
Wolf Fabrication
Sterling Archer
'08 D3
Ooooo, good to know.
Semper Fi!
Old July 25th, 2012, 07:33 AM
junkyddog11
oil soaked filter
95 RRC 300tdi
I would also highly recommended double checking any info I offer up.
Matt Browne
ac
4.11 gears ini88 Wanted 0 July 21st, 2008 12:13 AM
Complete 3rds with ARB's and GBR 4.10 gears lrnasd90 For Sale - Parts 22 July 16th, 2007 11:29 AM
Detroit Trutrac mdmccallum Defender Technical Discussions 18 November 3rd, 2005 06:02 PM
4.11 gears snuffer Defender Technical Discussions 13 June 5th, 2004 10:31 AM
4.11 gears, arb lockers, and arb compressor williasp For Sale - Parts 1 February 27th, 2004 03:15 PM
