Truetrac (rear), hd 4-pin diff, 4.11 gear kit - Defender Source
Old September 1st, 2013, 08:05 PM
DaveC
David Crall
1996 Discovery
Selling some parts I've been saving for a build that's not going to happen.
Brand new rear Truetrac (bought 2013), still in bag) with new carrier Timken bearings. $450 shipped
Land Rover HD 4-pinion open differential from a P38 and machined to fit all Discovery, Defender 90, and RRC differentials. P38 rear diffs are 4-pin to handle the 4.6. The carrier is similar but larger in diameter and bearing to bearing width. I had a machine shop make the adjustments precisely (bearing area was mic-ed, which was not cheap). Great for those who want a strong front differential with none of the TT handling issues. New Timken bearings included. $250 shipped.
GBR HD 4.11 gears and differential housing/pinion bearing kit. Perfect for building a set of differentials while your Rover is still on the road. Gears are in excellent shape, no funny wear and light use. Rear set has couple small spots of corrosion- not on the tooth load bearing surface. Housings were thoroughly cleaned, primed and painted. Pinion bearings are used but in excellent condition- they are so nice and smooth I saw no reason to buy new ones. Two 4-bolt flanges in excellent shape also. I will include an assortment of pinion height and preload shims as well as the flange spacers, and ring gear bolts (20).
$500 plus shipping.
Thanks, Dave
*parts in western MA
ID:	78775   Click image for larger version
ID:	78777   Click image for larger version
ID:	78779   Click image for larger version
ID:	78781   Click image for larger version
Old September 1st, 2013, 08:13 PM
Ray_G's Avatar
Ray_G
Ray Gerber
Good luck with sale Dave; love this setup in Coyote (for those looking at it I have one of Dave's previous TT rear/4 pin front setups running 4.11's in my truck-one of his old Discos-and it's been flawless.) Solid seller and a great setup if you're looking for decent traction without going too deep.
r-
Ray
Old September 2nd, 2013, 08:08 PM
DaveC
David Crall
1996 Discovery
Thanks Ray.
It is a great set-up for the less than extreme offroad use.
-complete package: $1150 shipped
Old September 2nd, 2013, 09:07 PM
Baldewin's Avatar
Baldewin
Chris Baldewin
Bastard 90
Dave, looking at your pictures one looks like a front reverse rotation gear set, is that true?
Old September 2nd, 2013, 10:00 PM
DaveC
David Crall
1996 Discovery
Yes, these are GBR 4.11 with front reverse rotation for added strength.
Old September 2nd, 2013, 10:22 PM
DaveC
David Crall
1996 Discovery
4.11 gears most likely sold.
Still have TT and 4-pinion differential.
Still have clean housings- make offer.
Old September 3rd, 2013, 04:02 AM
CDeWan
Clay DeWan
5.3L beastie
That is a great price for the TT shipped especially with the bearings and races. Good luck with the sale.
Old September 3rd, 2013, 04:36 PM
DaveC
David Crall
1996 Discovery
I thought so!
Old September 3rd, 2013, 05:32 PM
jafir's Avatar
jafir
Jafir Elkurd
I'll be visiting a friend in Pittsfield at the end of the month. Any discount for local pickup?
Old September 3rd, 2013, 05:38 PM
CDeWan
Clay DeWan
5.3L beastie
Ultra dumb question but if you are running a 1.2 T case rather than a 1.4 what is your final drive running 4.11s rather than 3.54s.
Basically if you run a 1.4T case and stock gears are you running the same rations as a 1.2T case and 4.11 gears.
Old September 3rd, 2013, 06:09 PM
jafir's Avatar
jafir
Jafir Elkurd
There is a calculator at Ashcroft with pre-entered values for land rover stuff. Assuming an r380, a 1.211:1 transfer case with 4.11:1 gears has 1 first gear, high range ratio reduction of 18.38:1
A 1.410:1 with 3.54:1 has a ration of 18.43:1.
Almost identical. But the combo with the 4.11 gears will get you a lower low range.
Old September 3rd, 2013, 10:16 PM
DaveC
David Crall
1996 Discovery
Sent you a PM.
ac, kit
$200,000 blr 130!!!!!!!!!! rijosho The Flea Market 39 July 25th, 2012 09:58 PM
Rear 4.11 R&P and HD rear shafts NVail Wanted 7 May 29th, 2012 07:02 PM
Truetrac front, Ashcroft HD rear axles DaveC For Sale - Parts 4 September 24th, 2010 04:44 PM
Need a lot...Tire Carrier, Rear Bumper, Stainless Bolt Kit..lots taylo951 Wanted 5 September 17th, 2010 09:59 AM
NAS 90 rear Diff whistler110 Defender Technical Discussions 27 February 3rd, 2005 03:04 PM
