Tire Carrier 2 Gas Can & Highlift mount - Defender Source
Old July 4th, 2012, 03:46 AM
CDeWan
Clay DeWan
5.3L beastie
O.k. so I decided to clean up the prior post and repost. This carrier uses the stock upper and lower hinge mounts from a ST and also will use the swing away bar from a ST and come in a semi gloss black powder coat. It holds a spare, two gas cans or cooler and a highlift jack
Also you don't have to use the rack in a "swingaway with the door" configuration but rather unattached if so desired to the rear door.
I recommend all who purchase this to use the latch to crossmember fitting.
So what does the kit include - Full kit will be:
1 rear tire carrier
3 new nuts for aftermarket wheels or early RR classic nuts to hold the spare on to the tire carrier
1 upper rear mount with 1 shoulder bolt and nut and 4 SS bolts, nuts and washer to mount to upper capping
1 lower rear mount with 1 shoulder bolt and nut and bolt 2 tub bolts and nuts and SS long bolt through the crossmember.
1 cross member mount and 2 bolts, nuts and washers
1 shoulder bolt should you want to use your existing swing away arm
1 latch for the cross member mount and SS hardware (4 bolts and washer)
2 stainless steel wingnuts, washers and lockwasher for the highlift jack
Price $600 plus shipping $125 Shipping CONUS.
Please remember these are sold as is. These are made by a professional fab shop that does a ton of racing Toyota stuff and are extremely sturdy. Does NOT come with a strap for the jerry cans or whatever else you decide to put on the tray.
Pictures are of one of the carrier on my truck and it is using the small swing away arm to move the carrier away from the door when open on some of the shots.
The hardest part of the mounting is getting the swingaway small arm to work as you have, the door, the carrier and the swingaway mount to all get in unison. None of the NAS mounts are exactly the same as I had slightly different bolt patters on my stock swing away spare parts but I was able to make them work and the rack will swingaway with my rear door.
Please PM me if you are interested.
Coming soon with be a kit that includes a door mount and a pivot arm for the rack if someone needs those parts.
This will fit either a ST or a HT, 90 or 110 or possibly series. It will also clear the ladder on the ST/HT roof racks.
Pic of the carrier with the door fully open. If used with the swingaway arm from a stock carrier there is a stopper on the swing away mechanism so the door doesn't hit the carrier.
If not using the swing away, the bottom mount will stop the dorr from going past being parallel to the truck's side
Pic of the adjustable crossmember stop as this will prevent the rack from wabbling around while you are driving and it keeps the rack nice and snug to the crossmember.
I may considering delivering and helping with the install if you are in the greater San Diego, OC or L.A. area.
ID:	53826   Click image for larger version
Old July 4th, 2012, 03:48 AM
CDeWan
Clay DeWan
5.3L beastie
Comment from Dave Hazard on his rack. - One more picture with the tire and jerry cans on. The tire is a 35" Baja Claw on a steel beadlock wheel, so very large and heavy. The carrier is very sturdy.
My angle is bad on the picture, the tire does not cover the passenger side lights
http://i20.photobucket.com/albums/b2...ireCarrier.jpg
95 D-90 3" lift, 35" Baja claws, salisbury rear axle, 4.88 gears, lockers, winch, etc
Old July 4th, 2012, 12:29 PM
Funtogun
Robert Lewis
1994 D90 ST
I finally got time to get mine mounted. As everybody else stated...it doesn't appear from the pictures, however; it does clear the passenger side lights. Kudos to Clay for bringing us this great carrier. I've included a couple of pics. Thanks again Clay.
ID:	53846   Click image for larger version
Old July 6th, 2012, 03:17 AM
CDeWan
Clay DeWan
5.3L beastie
Pics from 97 HT
Pics from Shannon's 97 HT with the roof rack. Carrier clears the the ladder for the rack and he is running a 265/75/17 on the truck. For this one we had to shave some of the plastic off of the light plinth for fitment right in the corner of the lower mount. All Defenders are not made the same .
ID:	53921   Click image for larger version
Name:	97 HT2.jpg.png
ID:	53923   Click image for larger version
Old July 10th, 2012, 01:14 PM
CDeWan
Clay DeWan
5.3L beastie
There are 3 carriers left for sale. I won't be producing them again unless I get prepayments for a minimum of 5, so you may not want to wait. Also for SoCal folks I may head up to Cars and Coffee on the 14th where you can pick up the carriers or just check out the construction of the carrier - this is dependent upon anyone going. Thanks to all of you who have purchased the racks.
Clay
Old July 11th, 2012, 08:50 PM
HeloBubba's Avatar
HeloBubba
Chris Murphy
'89 127 (D130), '16 LR4
Clay!
I sent you an email via Fleabay, and will also hit you here with a PM.
Murph
Chris Murphy
'89 D130SW
'86 D110 3-door
'89 D110SW
'16 LR4
Former:
'97 D90SW - SOLD SEP '14
'94 D90ST - SOLD MAY '13
D90s sold while assigned overseas. You're welcome America!
'06 Range Rover Sport Supercharged
'8X FankenRover D100
Old July 11th, 2012, 09:13 PM
lbowers
L Bowers
1997 D-90: ST, BRG
PM with questions sent.
Old July 14th, 2012, 12:00 AM
CDeWan
Clay DeWan
5.3L beastie
pm ya back :)
Surface area of shelf is 15x15.
Old July 16th, 2012, 12:17 AM
lbowers
L Bowers
1997 D-90: ST, BRG
Clay,
I tried to PM you, but I guess your mailbox is full. I'll take the tire carrier. I'm not sure my little Yeti full of beer will fit on the platform, but these things are so hard to find for Rovers. PM me with paypal details and we will get this thing rolling. Thanks.
-Liam
Old July 16th, 2012, 02:31 PM
taoseno's Avatar
taoseno
Todd Kendrick
1995 D90 #2206 Original Owner
Clay I pm'ed you. Save me one. Will you be in Moab in October for Natl?
Todd
'95 D90 #2206
'66 109" P/U
Old July 17th, 2012, 11:56 PM
CDeWan
Clay DeWan
5.3L beastie
carrier
Todd,
I will save you one.
Clay
------ Follow up post added July 17th, 2012 11:57 PM ------
I have 1 (one) carrier left for sale. Thanks to everyone who purchased them!!!!
Old July 18th, 2012, 06:02 PM
BCS
paul palmer
1989 classic, 2003 l322
Clay, I have pm'ed you for the last one
Old July 18th, 2012, 06:41 PM
CDeWan
Clay DeWan
5.3L beastie
Tire Carriers are sold out! Thanks Paul. I will be taking orders for the next round if anyone is interested.
Clay
Old July 23rd, 2012, 08:19 PM
Cred's Avatar
Cred
Clarence
1994 D90 #1057
Finally had the time to get my tire carrier installed. I am really impressed with this upgrade. Clay did an excellent job making these and bringing these to the forum.
Even with my limited wrenching abilities, this was an easy upgrade to complete.
Old July 25th, 2012, 02:42 PM
Birdman's Avatar
Birdman
Chris Bird
1995 D90 ST #2046
Attachment 54567
what size are your tires?
Old July 27th, 2012, 04:49 PM
CDeWan
Clay DeWan
5.3L beastie
I am taking orders for the next round so if you would like one please PM me for deposit detail. The next ones will have a slightly higher tire mount but the same basic design. I welcome feedback from any of the purchasers to let me know what they think and how to improve on the design.
Clay
Note - I do have some feedback on a purchaser of one for a 97. He brake light bar comes out at a more prominant 90 degree then the stock light bar used in the design. I believe he will post pics of it.
Clay
Old July 28th, 2012, 12:37 AM
Cred's Avatar
Cred
Clarence
1994 D90 #1057
285/75/16. I know it's really close to obscuring the lights on the right side. I think since Clay is moving the tire mount up a little bit will help out those of us with larger tires.
Old August 5th, 2012, 08:01 PM
severson
Lisa and Charles Severson
1995 Defender 90
Do you have any of these tire carriers available? I am interested.
Old August 5th, 2012, 09:44 PM
AgRover's Avatar
AgRover
Adin
1997 Defender 90 SW Badge #2493
I'm interested. What are you charging?
Old August 5th, 2012, 10:59 PM
CDeWan
Clay DeWan
5.3L beastie
Same price $600 for the carrier flat $125 for shipping. I am going to get another batch of 10 made up.
If any of the previous buyers would like to chime in on the design please feel free. Lbowlers had a hell of a time as my design did not account for the difference in the 1997 3rd brake light bar. Also, I need the shop to take into consideration the thickness added by the black powder coat.
Clay
carrier, gas, mount, tire, tire carrier
2 Jerry Can Highlift Swing away carrier CDeWan For Sale - Parts 40 September 10th, 2016 09:44 PM
Safari Equip Tire Carriers w/ Highlift Mount FS New SafariHP For Sale - Parts 7 November 4th, 2007 09:32 AM
Safari Gard Tire Carrier Joe P For Sale - Parts 10 November 8th, 2005 06:31 PM
Tire carrier problem - bad threads Antonios Defender Technical Discussions 4 May 7th, 2005 09:15 PM
