Thule crossbars w/gutter mounts for RRC/D1 - Defender Source
Old August 19th, 2015, 12:31 AM
ntan
N
Range Rover
RRC parts (Thule crossbars, lenses, lettering, mat)
Was doing some cleaning and found some RRC / other stuff. Will keep going through the stuff when I have time but there's a bunch more.
1) Good condition Thule crossbars (2) with set of gutter mounts (4). The bars are the perfect width for a Classic and would support roof baskets, top boxes, ski/snowboard attachments, or even could just be used as a light bar mount if you don't have a full rack. Bars are 58" long. Attached is a picture of what these look like mounted on a RRC. $130.
2) Set of front/rear RR Mk3 lettering in black (non-OEM, but had a similar set on one of my Mk3s and quality was good). $60
3) 3x MRC 9390 (window winder handles from 2-door Range Rovers). Never used, bought new from the UK. $10 for the set of 3.
4) 1 rear view mirror with map lights. Issue is that the mirror has some marks in it (can't clean off). Free if you pick it up.
5) 1x BW TC shifter boot and 1 for an LT230. $15 together.
6) Rear tail light lenses (full set... rear and side). ???
7) Set of older 2-door side marker lights and wiring (worked when pulled from my 2-door). Only pulled because I was restoring it and wanted to replace with NOS units. $40?
8) RRC rear loadspace mat with the "Range Rover" script... I forget who made it, but possibly Lloyd's? Never used. $125
9) Set of front RRC light guards. Should be stripped and repainted for best effect, no mounting hardware. $75
Would rather not ship any of the big items. Located in San Francisco.
ID:	127389   Click image for larger version
ID:	127391   Click image for larger version
ID:	127396   Click image for larger version
ID:	127398   Click image for larger version
Old August 19th, 2015, 01:10 AM
Toughy
95 Yellow ST
Does that pretty green classic come with? :D
Great looking rover bud
Old August 19th, 2015, 01:26 AM
ntan
N
Range Rover
Haha, thanks! If I had the space, I would still have that green Hunter.
Old August 19th, 2015, 01:29 AM
D90Overkill's Avatar
D90Overkill
David Frank
1995 ST #2615
Oh, no! You got rid of that gorgeous Hunter and kept the crossbars? You had you your priorities backwards! ;-) jk. What a sweet ride that must have been! Glwts
Oh, wait! I'm in for the load space mat and the front light guards (pending a pic)! What floor mat rubber is that in the same frame? Rear LWB perhaps?
Old August 19th, 2015, 01:40 AM
ntan
N
Range Rover
D90Overkill - different set of crossbars. I feel like almost every RRC I've acquired over the years has had these Thules. It was an auto. I forget where these shifter boots came from... probably when I swapped the TC in one of my '95s to an LT230 and a spare from a D1 just in case I went crazy and did another LT230. The Hunter was sweet...
Load space mat is yours! You are correct... those are the rubber LWB rear mats!
Old August 19th, 2015, 01:43 AM
D90Overkill
David Frank
1995 ST #2615
And will you be listing them too? If so, I'm interested! And Gratzie for the rear cargo mat!
Old August 19th, 2015, 01:45 AM
ntan
N
Range Rover
LWB mats are here to stay . Let me know when you're in SF and we can make it happen.
Old August 19th, 2015, 01:46 AM
D90Overkill
David Frank
1995 ST #2615
D90Overkill - different set of crossbars. I feel like almost every RRC I've acquired over the years has had these Thules!
I hear ya! I'm trying to convince Toughy to sell me his oem classic rack just to be different ;-)
------ Follow up post added August 18th, 2015 10:48 PM ------
Darn ;-) ha! Will do! And thank you. I actually have a decent set of LWB rear rubbers, but I'm always on the look out for another set of hen's teeth! ;-) I actually bought a whole parts car just for those dang mats!
Old August 19th, 2015, 06:25 AM
J. Pound's Avatar
J. Pound
Jeremy Pound
1960 Series 2a
Nick, I need those decals, buddy! Let's talk.
Old August 19th, 2015, 08:47 AM
ntan
N
Range Rover
You got it Jeremy. Text me.
J. Pound's Avatar
J. Pound
Jeremy Pound
1960 Series 2a
Will do!
Old August 19th, 2015, 11:30 AM
ntan
N
Range Rover
A couple more...
10) Rear bumper end caps for 2-door RRCs with reflector (I was told these were specific to some German RRs; maybe someone with more knowledge in this area knows); black, rubberized and in great condition (no idea if this could be adapted to a regular NAS bumper). $250
11) A couple of old 2-door units. I'll take these out of the box tonight and get some pictures. They'll come together and maybe you can make a good one out of them (note: never tested). $??
12) A couple of sets of mudflaps. $15/set of 2
Old August 19th, 2015, 02:36 PM
D90Overkill
David Frank
1995 ST #2615
Yup! Headlight guards licked! Price?
Old August 19th, 2015, 11:54 PM
ntan
N
Range Rover
A few more pictures, a few more items. Apologies that it's spread over multiple posts, but I couldn't figure out how to consolidate into the original...
13) Carpeted floor mats in sand/tan with black piping from my old 2010 RR SC. Could use a quick shampoo, but were barely used when I dropped in the rubber mats. $150
14) Addendum/replacement for #6. Turns out that I have two full sets of NAS RRC tail lights/rear side lenses. $120 per set
15) Rear RRC tail lamp guards. Missing some of the mounting hardware (I think I used a few of the mounting supports), tail lamp guards are used but in pretty okay shape. $80
16) RR 2-door headlight switch. Don't think it's been used; got it as a spare. $20
17) '95 RRC 14CUX 3.9L ECU; came out of my 2-door after the 4.6 swap. In good condition and worked well when removed. $140.
18) As an addendum to #12, have another set of mudflaps with mounting brackets/hardware, from Bearmach. $75
As of right now, the following are spoken for / no longer for sale:
2) Mk3 front lettering
4) Map light
8) RRC rear loadspace carpet/mat
9) Front light guards
ID:	127495   Click image for larger version
ID:	127497   Click image for larger version
Old August 20th, 2015, 02:06 PM
ntan
N
Range Rover
#2 (lettering) still available.
Old August 23rd, 2015, 01:03 PM
ntan
N
Range Rover
#1 (Thule racks) sold.
Old October 25th, 2015, 11:20 PM
ntan
N
Range Rover
Bump. A few things sold...
- Window winders sold
- one of the rear tail lenses sold
- 2-door RR instrument clusters sold
All other items still available (including the rear loadspace carpet mat, headlight and taillight guards, mudflaps, etc.)
parts, part
Roof top tent and Thule feet with crossbars quick128 The Flea Market 23 July 13th, 2011 02:10 PM
Factory Roof Rack (Thule) Crossbars AggieD90 For Sale - Parts 1 April 20th, 2010 04:21 PM
Thule-compatible roof rack crossbars Tmotsinger Wanted 1 April 23rd, 2007 08:34 PM
Thule #420 high rise gutter mounts lactic For Sale - Parts 4 February 28th, 2006 11:25 AM
thule crossbars and rack etc ccrover For Sale - Parts 3 October 29th, 2003 06:04 PM
