Take-off welded 110 roll cages - Defender Source
Old January 7th, 2016, 04:42 PM
Ash's Avatar
Ash
Ash Heller
OM606 110 Frankenstein
If I had to guess I'd say these are made by P&P based on the overall design, but they're definitely way more stout than the bolt-together units. These are made of heavy wall DOM and have some serious mass to them.
The front tie-in is something you'd have to work out on your own, but personally I'd shorten the leg and make a pad that passes through and hits the bulkhead, similar to the way Safety Devices does it. The 'C' pillar just bolts into the tub and T-post, and the 'D' pillar passes through and ties into the rear crossmember.
As far as condition, they could definitely use a good sanding and a fresh coat of paint or powdercoat, but there isn't any rust worth mentioning. Pretty much all of the orange stuff in the pictures is red clay and silt.
I have two of these on hand for $1250 a piece, including the tie-ins for the rear. As for shipping, that's something we'll have to work out. Fastenal may be willing to take them, but I can't guarantee. Whatever the case, any materials or labor required to required to prep these for shipping will be passed on to the buyer.
Geared Restoration Co.
352-572-3236
Old January 7th, 2016, 05:21 PM
roverman2010's Avatar
roverman2010
1985 LR 90 200Tdi
If the front legs end with a flat plate with a 12mm hole Then front legs bolt directly to the outrgger as safety devices does use. You just need to slot the wing to suit.
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
97 XK8 BRG FHC For Sale
Old January 7th, 2016, 05:57 PM
mgreenspan's Avatar
mgreenspan
Matthew Greenspan
Land Rovers
Those look like Whitbread Off-Road 5 door roll cages.
You little rebel, I like you.
Old January 7th, 2016, 06:06 PM
mongosd2's Avatar
mongosd2
Frank Rafka
01 D2 96 D1 83 110
Couple of options for ya to make it easier to ship and re-fit:
Roll Cage SAFETY Slug: FITS 1-3/4OD x .120WALL TUBING : TMR Customs, Custom Fabrication Components for Offroad Vehicles
Safety slug, you can cut the cage apart and use these to re-assemble it. We use these in Trophy Trucks to fix bent tube all the time
or these to make it so you can disassemble and make it easier to remove if need be
Interlocking ID Tube Clamp - 1.75OD, 1.5ID [1032] : TMR Customs, Custom Fabrication Components for Offroad Vehicles
These are just examples of what available, both options are as strong to stronger than the tube they are weld too...
Name:	Screen Shot 2016-01-07 at 4.00.24 PM.png
ID:	138736   Click image for larger version
Name:	Screen Shot 2016-01-07 at 4.00.59 PM.png
Old January 7th, 2016, 07:26 PM
Ash's Avatar
Ash
Ash Heller
Yeah I've used those TMR clamps a number of times with really great results. I'd be happy to cut these cages up at the buyer's request if that makes shipping or transporting easier.
And Matt, I think you're right! Looks to be identical.
-Ash
352-572-3236
Old January 7th, 2016, 07:36 PM
mongosd2's Avatar
mongosd2
Frank Rafka
01 D2 96 D1 83 110
Cool...half my buggy is Canadian...
Old January 7th, 2016, 07:43 PM
Ash's Avatar
Ash
Ash Heller
Nice! Honestly whenever I buy fabrication parts TMR is the first place I look. Quality is killer and every time I've called the guys have been awesome to deal with. They definitely have my business.
-Ash
352-572-3236
Old January 8th, 2016, 08:02 AM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
Do they come with the four brackets that go to the frame? You have a picture of the one that connects the rear? to the wheel well...do you have th four of them as well?
Land Rover 110
Old January 8th, 2016, 08:45 AM
ATX_D110's Avatar
ATX_D110
Victor
1985 RHD D110 (SOLD)
Interested and PM sent. Also can you post a close up pic of the lower front legs? Thanks!
Old January 8th, 2016, 09:26 AM
Ash's Avatar
Ash
Ash Heller
Mike, I was provided four brackets total for each cage -- two (pictured above) on the interior of the tub at the 'D' pillar, which bolt through the floor to a secondary bracket that bolts into the rear crossmember. I'll snap a picture of that today. I don't believe I was provided anything for the 'A' pillar legs, but if it just rests on the bulkhead outrigger it should be pretty simple.
Victor, to answer your question -- I don't know if these will clear your ribbed roof or not. I'll send an e-mail to Whitbread to see if they can provide any insight. If there's any clearance issues I would expect them to be between the center rib and the center bar on the cage.
-Ash
352-572-3236
Old January 8th, 2016, 09:46 AM
speedpin's Avatar
speedpin
1985 130 Gen IV
Could this be used on a 3 dr 110 soft top. would be modifying some bars but should interfere with hoop set..
~ Semper Fidelis ~
Old January 8th, 2016, 09:49 AM
ATX_D110's Avatar
ATX_D110
Victor
Ash - I'll wait your response and if so, let's talk shipping. Regards,
Old January 8th, 2016, 09:50 AM
Ash's Avatar
Ash
Ash Heller
Possibly, but I couldn't say for sure. The biggest difference would be that on the 3 door you'd ideally want your second hoop at the 'B' pillar behind the front doors, where this has the second hoop landing at the 'C' pillar behind the middle doors. It might look a little goofy.
-Ash
------ Follow up post added January 8th, 2016 09:57 AM ------
You're in luck, Victor. Shoot me a PM and we can talk details.
Shayne just sent a deposit for one, I'll consider the second 'licked' by Victor pending the details of shipping.
-Ash
352-572-3236
Old January 8th, 2016, 09:59 AM
speedpin's Avatar
speedpin
1985 130 Gen IV
Yeah those are the bars I would alter, I don't think I have seen a 110 3 dr ST with external cage before anyways.
Ash,
Can you shoot me the measurement from the middle of the rear most body bracket (curved mount attaching to tub) to the top of the cage (height).
~ Semper Fidelis ~
Old January 8th, 2016, 10:09 AM
speedpin's Avatar
speedpin
1985 130 Gen IV
If both taken, disregard above.
~ Semper Fidelis ~
110, cage
Take Off Parts, New Take Off Parts & parts from GLR globallandrovers The Vendors Loft 0 September 22nd, 2015 03:07 PM
New LH Full (SW) Door - Welded seams dmarchand For Sale - Parts 6 October 8th, 2014 09:09 PM
Salisbury Axle with a welded on stub axle, disc brakes, Factory? Capt Milks Defender Technical Discussions 5 December 21st, 2010 09:45 AM
Exhaust "issue" at welded joint Bozman Defender Technical Discussions 4 October 5th, 2010 08:40 PM
Evans Roll Cages from UK, Starting @ $865.00 US RedRhinoProducts The Vendors Loft 0 April 1st, 2005 10:38 PM
