Tail Lamp Boot Kit - Defender Source
Old June 1st, 2007, 09:00 AM
Bozman's Avatar
Bozman
Greg
1991 200tdi D90
Tail Lamp Boot Kit
I have been replacing the tail lamps over the past few months, one at a time as they fail due to corrosion in the sockets. It seems like a terrible design putting the rear lights in the wheel well open to the abuse of everything coming off the tires (mud, water, rocks, road kill).
Anyway, I stumbled onto this at Rovers North and wanted to share it with everyone. Seems like a good investment.
http://www.roversnorth.com/store/sho...it-defender-90
Kit includes new bulb sockets, rubber boots, clamp, connector repair kit and sealing compound. Does all five rear lamp assemblies.
Old June 1st, 2007, 12:54 PM
jorge's Avatar
jorge
JORGE ESPINOZA
97 ST WHITE MODS SUPERCHARGED
The kit was an LR recall due to the bulb socket corrosion cause by moisture getting into the bulb sockets , both of my D90s have the upgrade done in 2001. can't recall if did the recall under warranty. I still had to change the bulb sockets 2 years ago on my D90 , due to wading in some deep puddles , but never had a problem on my wife's D90.
Old June 1st, 2007, 02:00 PM
I ordered and installed that kit when I rebuilt my truck in 04.
It is a challenge to get a seal around the thin part where the wires go through - I used some sillly-cone on that end. The kit includes plastic clamps for sealing the large end around the bulb holder.
It seemed like a good set-up, and it appeared to keep water out for a few months, but by the following winter, water was finding its way back in.
I used all new parts when I did the install, the kit, bulb holders, bulbs and even tail light lenses were all new. I also packed the connectors with dielctric grease.
These really only seem to work in ideal situations, you have to keep the mating surfaces super-clean, ensure the boot slips all the way onto the back of the lens, seal the small end perfectly, and get the clamp on tight.
I think the only real long-term fix is moving to Arizona or buying ECR's LED kit.
Old June 1st, 2007, 09:44 PM
Chaucer
Will
93 110 | 97 90
My 90 came with them (previous owner), but still had the corrosion problem. I ended up doing the drain hole + dielectric grease to finally stop the problem.
Old June 5th, 2007, 04:23 PM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
my previous owner either bought or made a shield to cover from the rear tail lights. he took a lot of time and effort to point this out to me when i was picking up my truck but i didn't give it much thought. 2 yrs later i'm seeing why; the plastic has never fogged or faded so i gues he knew what he was doing.
kit, lamp
Tail Light Boot Installation - Fixing Hosed Tail Lights JimC Misc. Chit-Chat 1 July 11th, 2017 04:14 PM
Rovers North Tail Lamp Guard Install Arnzo Defender Technical Discussions 13 September 6th, 2008 07:17 AM
Tail light lamp guard sheki For Sale - Parts 4 January 12th, 2006 08:50 AM
Rear lamp guards (tail light) mod4b Wanted 1 August 2nd, 2005 05:06 PM
NAS SW entire roll bar kit sheki For Sale - Parts 4 September 30th, 2004 05:28 PM
