Synthetic winch line - 3/8" x 100' - Page 3 - Defender Source
Old October 19th, 2012, 07:48 AM
87 D110 (Ruby)
It is never going to be something that will keep the rope on the drum if strain/tension of any magnitude is ever applied to it. You could do whatever you want...but as Wolf pointed out ALWAYS maintain a few wraps on the drum and you are fine.
You can attach the end however you like - the crimp solution would be fine.
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
Originally Posted by Overlander
Can I just crimp and brass ring terminal on the end of it? Looking at OK Offroad winchlines, it appears that's what they do. I have some handy.
That works too. Anything to hold the line while you wind it in under tension. Find a tree or light pole..,
Semper Fi!
Old October 19th, 2012, 08:20 AM
Thanks. I'm not new to winches, only to synthetic, so tracking on the wraps. Off to the hardware store.
Mark Kellgren
KM4BOR
Old October 20th, 2012, 09:45 PM
Banzai Jimmy's Avatar
Banzai Jimmy
1994 Discovery
I have one of the OK Offroad lines and the end of the rope came out of the crimped terminal and ended up falling between the first and second row. Really glad I found that at home and not while winching - I had used it a bit on a recent run and decided to respool it and inspect the rope.
I ended up laying the rope from one end of the drum to the other with it held in place with some duct tape. Then I began respooling it - that first row will hold that end in place. As most know and was already mentioned, never spool out to the end and leave several wraps in place.
I won't be using a crimped on terminal again.
winch
Line Lock for Winch Line Maine 110 The Vendors Loft 6 February 7th, 2006 06:47 AM
synthetic winch line good or bad ripp2002 Defender Technical Discussions 1 January 18th, 2005 07:28 PM
Dynaflex Synthetic Winch Lines Starting @ $280.00 RedRhinoProducts The Vendors Loft 1 November 4th, 2004 09:07 AM
Steel winch line NIB sheki For Sale - Parts 0 September 30th, 2004 05:43 PM
WARN 8274-50 Winch, THE ULTIMATE!!! RedRhinoProducts For Sale - Parts 0 September 28th, 2004 08:18 AM
