supercharger with Plug N Play MegaSquirt ECU - Defender Source
Old September 13th, 2011, 08:03 PM
cdb
Clark Bowen
This is the Rimmer setup with an Eaton 62 supercharger (rebuilt 2 years ago), adapters, custom plenum,
new (never installed) MS2 Extra EFI ecu Plug N Play from V8 Developments in the UK. [COLOR="rgb(139, 0, 0)"]http://www.v8developments.co.uk/prod_inject.html[/COLOR]
It is wired for distributorless ignition if you want to add it later and 2 wideband O2 sensors.
Also included are:
2 AEM Air/Fuel Ratio gauges, http://www.aemelectronics.com/wideband-air-fuel-gauge-8-5-to-18-1afr-with-analog-face-770
1 AEM 1-15 pound boost gauge, [COLOR="rgb(139, 0, 0)"]http://www.aemelectronics.com/boost-pressure-gauge-0-15psi-with-analog-face-1186
1 Knocklite [COLOR="rgb(139, 0, 0)"]http://www.vividracing.com/catalog/turboxs-knocklite-knock-detection-system-p-15475.html[/COLOR]
1 MSD Boost Timing Master[/COLOR] [COLOR="rgb(139, 0, 0)"][COLOR="rgb(139, 0, 0)"][COLOR="rgb(139, 0, 0)"][COLOR="rgb(139, 0, 0)"]http://www.msdignition.com/Products/RPM/Timing_Controls/Timing_Controls/8762_-_Boost_Timing_Master_for_use_with_MSD_Ignition_Con trol.aspx[/COLOR][/COLOR][/COLOR][/COLOR]
Everything was installed about 2 thousand miles ago, except for the supercharger.
Currently runs up to 5 pounds of boost and can be increased to about 8 lbs. with a smaller pulley (included)
Much cheaper than a 4.6 litre engine and more power.
The Rimmer kit was installed in Art Vigil's 1995 RRC for 125,000 miles with no problems. It was rebuilt 2 years ago by Magnuson [COLOR="rgb(139, 0, 0)"]http://www.magnusonproducts.com/[/COLOR].
The MegaSquirt is ideal for boosted motors, but I've had no problems running the system like Art did (with the addition of the BTM). I realized that the MegaSquirt system is for someone with greater access to a tuner and who loves fooling around with engines, software, etc. I'm too much of an old dog for these new tricks.
$2,700 for all.
2011 RR HSE -
2001 GMC 2500 4wd
Old September 19th, 2011, 04:47 PM
cdb
Clark Bowen
Lowering price to $2,000.
2011 RR HSE -
2001 GMC 2500 4wd
ecu, gas
FS: Megasquirt ECU and Stimulator Hans For Sale - Parts 0 February 1st, 2010 08:27 AM
Employment opportunity Rod Hayward Misc. Chit-Chat 18 December 20th, 2005 10:20 PM
what does this plug in to? mattdh Defender Technical Discussions 6 November 2nd, 2004 11:59 PM
Wiring question - bypassing ECU for rear defogger dmarchand Defender Technical Discussions 8 September 30th, 2004 11:21 AM
LR Glow Plug relay temp? dmarchand Defender Technical Discussions 0 June 9th, 2004 01:42 PM
