Summer Blues - Page 2 - Defender Source
Old July 9th, 2010, 10:27 AM
pendy's Avatar
pendy
jim pendleton
89'd90
Originally Posted by hillstrubl View Post
Weird,
So far my 300tdi is doing fine sitting in traffic (even though I look like i jumped in a pool fully clothed) in DC's 100+ weather the last few days
You can take the hood off and open the air vents and let your clutchless fan cool you too ! Or get yourself a trucker cabin fan.
legend in my own mind
Old July 13th, 2010, 05:15 PM
pendy's Avatar
pendy
jim pendleton
89'd90
Important !
You must tighten the replacement Clutchless fan using a holding tool. It must be made very tight. Cleaning the waterpump/Idler hub and using locktite is also recomended. 1/4" wrench fits the hub to tighten it. A hook tool against the hub bolts or large pliers on the pulley itself, with an old belt to protect grooves, can work if more correct tools are not available.
Without the clutch, when the engine shuts down, the Clutchless Fan can try to remove itself, if not tightened correctly. Make your new Clutchless Fan very tight during installation !
Damage can occur to your radiator and other items in your engine bay if the installation is not correct. To avoid damage to engine components tighten the Clutchless Fan very tight using a holding tool on the hub for a positive installation. You can not rely on the serpentine belt to hold the hub enough for correct fitment.
Lefty Tighty on this nut !
ID:	29328   Click image for larger version
Old July 14th, 2010, 10:51 AM
hillstrubl's Avatar
hillstrubl
Danny
2005 Disco 3
wifey is pushing for me to put in A/C... but I def don't have the cash for that now.
~2005 Disco 3 "Moneypenny"
~2008 GTI TSI
Old July 14th, 2010, 02:37 PM
I am planning to put AC in mine. Will make it happen by hook or by crook. A RHD system shouldn't be too hard to scrounge up.
Old July 14th, 2010, 03:04 PM
pendy's Avatar
pendy
jim pendleton
89'd90
How about a bucket of dry ice under the trucker fan? Do it at dusk so it appears to work. Cheap date. Drive to an old make out point. And wifey may want to reward her genius for keeping her cool.
Old July 16th, 2010, 09:54 PM
revor's Avatar
revor
Keith Kreutzer
Old beat up 110
Installed... Simple and easy! It's on there tight and loctited. Tomorrow we'll check it out!
Nice bling!!! And I still have all my fingers!
ID:	29406   Click image for larger version
Keith
Big, Red and ... aaa Red..
Old July 16th, 2010, 10:47 PM
dogbite's Avatar
dogbite
Paul D
95 D90 ST & SW
Go mine on today too.... it'll be a little bit before I can test it.....
Old July 16th, 2010, 11:17 PM
cdb
Clark Bowen
I've been following this thread because I just got a Lincoln fan - same as the Taurus - and I was going to install it in my D90 - 300TDI.
I'm not sure what the advantage of this setup is over stock or the electric Taurus unit.
Would someone please enlighten me.
------ Follow up post added July 16th, 2010 08:18 PM ------
Another comment for DB....
A/C was the biggest waste of money and time I ever spent on my D-90. Passenger freezes, I roast.
2011 RR HSE -
2001 GMC 2500 4wd
Old July 17th, 2010, 12:00 AM
Thanks, which system did you put in?
Old July 17th, 2010, 12:13 AM
Cred's Avatar
Cred
Clarence
1994 D90 #1057
I'm still anxiously waiting. Hopefully I will see it Monday.
Old July 17th, 2010, 12:20 AM
cdb
Clark Bowen
I bought the RN system - about 2 years ago.
My wife really wanted a/c, but we usually only have a bikini top on the D-90 in the Summer, so it was quite a waste of money.
Even with the full Badger top on, there isn't much difference, as the top radiates so much heat.
I can also feel the effect on the power with the a/c going.
In my gutted RR, I use a truckers fan, and it helps for about $30.
2011 RR HSE -
2001 GMC 2500 4wd
Best Route during Summer from Boston to Virginia 1of40 Defender Technical Discussions 5 June 16th, 2005 03:40 PM
Summer Gas Mileage mdmccallum Defender Technical Discussions 5 June 9th, 2005 12:10 AM
The Summer Cigar P.I.F. Eric Siepmann Misc. Chit-Chat 0 June 1st, 2005 02:26 PM
New Car Blues Nategracie808 Defender Technical Discussions 12 July 18th, 2004 10:24 AM
Summer camp staff member needed sherpamike Wanted 2 May 1st, 2004 12:47 PM
