ST Tire Carrier Backing Plate - Defender Source
Old June 15th, 2012, 01:31 AM
CDeWan
Clay DeWan
5.3L beastie
Made from 1/8 steel plate - these Backing plates are made to be used with a stock tire carrier and some aftermarket ones depending on the placement of the upper hinge. The are not powder coated and are made to help spread the load of your current tire carrier over a larger surface. These go inside the tub behind your speaker. Price is $27 shipped CONUS. These also come as standard equipment on the ST Tire Carriers I have posted. Please PM if you are interested.
ID:	52971   Click image for larger version
Old August 30th, 2012, 01:30 PM
CDeWan
Clay DeWan
5.3L beastie
These are still available and great for your stock or aftermarket carriers. Also is good for a ST Rack as well but you may need to drill a few additional holes.
Old September 14th, 2012, 01:59 PM
genie90's Avatar
genie90
Jay Geaney
1994 D-90 ST #282
Are there any captive nuts welded on the back like the stock setup?
Jay
Old September 17th, 2012, 04:47 PM
CDeWan
Clay DeWan
5.3L beastie
Jay,
The don't but they are not PC or painted so you could have a few tacked on it. I know that our 94s are a little cramped in the upper rear corner. I did not put nuts on them so that they have some wiggle upon fitment before final torque.
ac, carrier, tire, tire carrier
Reinforcing Plate for ST Tire Carrier wadaman Wanted 7 December 8th, 2009 06:15 PM
Tire carrier problem - bad threads Antonios Defender Technical Discussions 4 May 7th, 2005 09:15 PM
stock ST spare tire carrier w/light bar WhiteD90 Wanted 3 July 1st, 2004 10:57 PM
Modify ST Tire carrier for SW use? dnewman9 Defender Technical Discussions 1 June 27th, 2004 06:06 PM
