Spare Tire Hi Lift Jack Mount - Page 3 - Defender Source
Old February 9th, 2012, 11:35 AM
Jeff, I have an old SG? high lift holder - the style with round tubing and can see two very nice improvements in your design.
1. The integrated handle holder
2. The combination of the square tubing and slotted base plate take any lateral pressure off the pin and holes which should extend the life of it. The holes in mine have wallowed over time due to constant lateral/twisting movement against the pin.
Originally Posted by pendy
I'm here for the D's
Old February 9th, 2012, 01:17 PM
Jpayne's Avatar
Jpayne
Jeff Payne
'83 110 3 Door
Those are definitely two things I wanted to address when developing this design. I think it works well. I took mine out on the trail last weekend and it hung out back there just fine. I have a rack that it mounts to inside the truck for normal everyday use with the clamp attached. Then all I have to do is put it into the square tube that's always mounted behind the spare.
Old February 9th, 2012, 07:59 PM
popeohana's Avatar
popeohana
Jeremy
94 Arles ST
On page 2 of this thread, there was some talk about making this work with a bike rack, I would be interested in that. Jeff, have found a way to get an off-the-shelf bike rack to work with your mount?
Old February 9th, 2012, 08:27 PM
Jpayne's Avatar
Jpayne
Jeff Payne
'83 110 3 Door
I am close to getting it to work with the Yakima Sparetime rack
http://www.yakima.com/shop/bike/spare-tire/sparetime
I think what I have will work with an alloy wheel but I might need to make a different base plate for the steel wheels.
Old February 10th, 2012, 11:59 AM
roverman2010's Avatar
roverman2010
1985 LR 90 200Tdi
Jeff, I just found this tread, A couple of questions, what size are the holes you have on the square stock, would it take a locking hitch pin? I was just about to buy a wheel nut lock for the spare, But you could make a stub of stock with a round plate welded to it that is bigger than the spare wheel centre hole and using a locking hitch pin spare wheel security, when not using the hilift/bike mounts. Make sense?
I know it would be a bit of pain getting your hand in to lock/unlock, but better then losing a 400 dollar wheel combo
Do able?
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
97 XK8 BRG FHC For Sale
Old February 10th, 2012, 12:20 PM
Jpayne's Avatar
Jpayne
Jeff Payne
'83 110 3 Door
That's a good idea. I keep thinking that I need to get a locking nut set as well but your idea would work too. Getting the key up in there might be tricky.
The hole is 3/8". The trailer lock set I have came with a lock for the receiver which would be too big to fit but it also came with a smaller one that locked the coupler on the trailer end which has about a 1/4" shaft. I bet that one would work. I'll test fit it this weekend too see.
Old March 5th, 2012, 09:59 PM
Jpayne's Avatar
Jpayne
Jeff Payne
'83 110 3 Door
Unfortunately, I think it's safe to say that this won't work with the Yakima rack without modification to the rack. I bought a rack to do some testing with some different wheel/tire combinations. The one that seems to work best is a steel wheel with 38x12.5 super swampers. There are just too many variables in wheel tire combinations to make a universal product. The snag is that the rack relies on support by being tightened up against the outside of the tire.
One solution I have is for the user to modify their rack in such a fashion that there is additional padding or some kind of spacing between the rack and the tire. This would give the rack the support it desires. It looks to be about an inch of space that needs to be taken up in that area depending of course on wheel/tire combo.
Let me know if that makes sense and is something that you are interested in. I have not priced out the bike rack adapter yet since I have yet to find the perfect solution. If the above description sounds agreeable then let me know and I will move forward. It shouldn't be much additional cost to the package.
Also, price drop on these units!!! I am now offering the Hi Lift mount for $130 shipped
Jeff
Old March 6th, 2012, 09:09 AM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Jeff - the Yakima racks came with different sized spacers (the 1x1 square stock) that come with the rack (or at least when I bought mine).
Any interest in selling just the plate? I was just going to cut the tab off the Yakima plate and weld it on to a LR bolt plate. I can make my own but your design looks much better.
Old March 6th, 2012, 09:54 AM
Jpayne's Avatar
Jpayne
Jeff Payne
'83 110 3 Door
Yes I would sell you just the plate if you want that. I suppose I could also sell just a Yakima mount that will be a direct replacement for their mounting plate if you want that since theirs doesn't fit our lug pattern. That way you could still use the factory mount on another car for easy rack switching.
I've been stuck on the train of thought that this needs to be both a rack mount and a jack mount, but it just gets complicated with all the variations out there. So if you want to replace the factory part that won't fit our vehicles with a dedicated Yakima rack mount I can do that.
It will be a direct replacement for this part and will allow you to use the factory hardware with their spacers:
Old March 12th, 2012, 10:32 PM
Jpayne's Avatar
Jpayne
Jeff Payne
'83 110 3 Door
It's time to order more plates. Is there anybody out there who is willing to lick one for the next run? I will sell just the bare plate if you want to make your own creation, the Yakima mounting plate, or the Hi Lift mount.
If you are thinking that you might want one of these please let me know soon so I have an idea of how many plates to order.
Sorry but I'm not sure how much the yakima mount will be since I haven't actually made one yet. Best guess for now is somewhere in the $50-60 range.
Bare plate is probably around $30.
Hi Lift mount is now $130 shipped.
Let me know and I will get on the next run.
Cheers,
Jeff
Old March 12th, 2012, 10:36 PM
jeff I'll lick a yakima mount please
Old May 2nd, 2012, 10:05 AM
Jpayne's Avatar
Jpayne
Jeff Payne
'83 110 3 Door
Ok the Yakima mount is done. I have contacted all those who had expressed interest. If they are all still committed the first run is spoken for.
If there are more people that would like this product then let me know and I will do another run.
The mount accepts the factory Yakima spacers and actually fits the lug pattern for Defenders, DI and RRC (unlike the Yakima mounting plate)
ID:	50993   Click image for larger version
Old May 2nd, 2012, 12:45 PM
Abeer's Avatar
Abeer
Amarveer
94 D90 ST
Definitely in for a second run. Just sent you a PM
Old May 2nd, 2012, 01:01 PM
Jpayne's Avatar
Jpayne
Jeff Payne
'83 110 3 Door
Pm'd back
I forgot to add that these came in at $70 a piece. If I can do a bigger run the cost should go down a bit.
Old May 3rd, 2012, 01:06 PM
fishEH's Avatar
fishEH
Brett Fritzler
94, 95, 96 D1's
I really like the backing plate, how it can be rotated. One thing I'll mention is that it appears as though there is no tension put on the sliding pieces. It would seem the Hilift would rattle a bit on rough roads and still place a fair amount of stress on the sliding pieces and the holes. I made my own HiLift holder and at first the guy that welded it up didn't see how it would work.
First, the sliding pieces on mine are pinned at such a length that the piece the HiLift attaches to is actually inside the lip of the tire. This was tricky to achieve with the alloy spare, easier with a steel spare.
Second, the bolts that go through the HiLift are fairly long. This gives adequate space for a washer, wing nut, and hair pin. When I tighten down the wing nuts the HiLift is drawn into the tire. Not only does this provide cushion for the HiLift but it also places significant tension on the pin. This is good because it shifts some of the downward force from the weight of the HiLift. All components of the mount are tight and there is zero rattling or slop.
A simple $7 Poly isolator takes care of the handle.
Just my $.02.
Old May 3rd, 2012, 01:19 PM
KKilo23's Avatar
KKilo23
Kenny
Jeff, if you do a second run I will take one as well.
Old May 4th, 2012, 12:55 AM
triple9music's Avatar
triple9music
Chad Davis
1984 Defender 90
Will this setup work for a SW door(no mantec style tire holder) with the huge U bolt thing for stabilizing the spare? doesn't seem like it would work but I'm trying to get it to work!
Old May 4th, 2012, 09:15 AM
Jpayne's Avatar
Jpayne
Jeff Payne
'83 110 3 Door
Yes it will work on the door. You will just have to remove the U-bolt thing. It's just bolted through the door and can be easily removed
Old June 26th, 2012, 11:48 AM
bjf's Avatar
bjf
barry f
94 ST #395
Just a bump for a great product. I was pumped when Don gave me his mount so that I could use my yakima rack (modified original plate) but this one is great because it centers perfectly so if I was ever to use boosts or the stock wheels it would work perfectly.
If you haven't ordered one you really should.
Old June 26th, 2012, 02:15 PM
bjf's Avatar
bjf
barry f
94 ST #395
ac, mount, spare, spare tire, tire
Spare tire hood mount bd90 Defender Technical Discussions 15 November 12th, 2017 11:36 AM
Hi lift jack mount prototype Jpayne Misc. Chit-Chat 14 November 26th, 2011 10:23 PM
Spare Tire mount on hood Viper-25 Defender Technical Discussions 20 July 24th, 2005 10:36 AM
Rear spare tire mount - nuts Kimos Wanted 1 December 4th, 2004 08:17 PM
spare tire mount bonnet Abrooks For Sale - Parts 14 April 30th, 2004 11:01 AM
