Soft Top Door Tops, Door Panels - Defender Source
Old August 13th, 2007, 11:32 AM
Bozman's Avatar
Bozman
Greg
1991 200tdi D90
I have a set of soft top door tops and inner plastic panels I no longer need. I am willing to split either set up if I find buyers for the other half of the set. Buyer pays all shipping charges. PayPal is fine.
Door Tops: $600 for both ($350 if they are split up) Great condition, includes rubber gasket. These are tinted, but the tint is in great shape. Glass slides fine, I would recommend some stainless door studs as the existing ones are a little rusty.
Inner Panels: $200 for both ($150 for passenger, $75 for the driver's side) Both are in okay shape. The passenger side panel is in better shape of the two. No cracks, only missing plastic around screw holes as is standard for the door panels. I guess I would consider them to be in overall average condition.
MORE DETAILED PHOTOS AVAILABLE UPON REQUEST.
ID:	10016   Click image for larger version
ID:	10018   Click image for larger version
ID:	10020   Click image for larger version
Old August 13th, 2007, 01:38 PM
bryanf
bryan smith
95 disco
wanting to purchase.
wanting to purchase,your door panels.sent you an email.
Old October 27th, 2007, 12:36 PM
Bozman's Avatar
Bozman
Greg
1991 200tdi D90
Door Tops still available.
Old October 29th, 2007, 03:47 PM
Bozman's Avatar
Bozman
Greg
1991 200tdi D90
Pics showing tint, as requested.
Name:	IMG_0046 small.jpg
ID:	10883   Click image for larger version
Name:	IMG_0047 Small.jpg
Old October 30th, 2007, 09:23 AM
Bozman's Avatar
Bozman
Greg
1991 200tdi D90
Pending payment, they are SOLD.
Thanks.
Old October 30th, 2007, 09:40 AM
rmuller
Ryan
1966 S2a 88" | 2006 LR3
Anyone have any tips for installing door panels in similar shape? I'm missing a few of the outer screw holes on the panels I bought from another seller..
Ryan
Current:
1966 Series IIa "Olive"
2001 Discovery II
2006 LR3 HSE7
Old October 30th, 2007, 10:09 AM
Bozman's Avatar
Bozman
Greg
1991 200tdi D90
One key is not to overtighten the screws. Lightly hand tight is enough.
Also, you can try using some washers that sit on top of the plastic that is remaining. You will need longer screws for this.
Old October 30th, 2007, 10:20 AM
rmuller
Ryan
Yeah, thats what I was thinking, either washers on there, or fab something out of plastic and epoxy it on there.. or possibly even bondo or something similar
Ryan
Current:
2001 Discovery II
2006 LR3 HSE7
Old October 30th, 2007, 10:34 AM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
You can't do it with bondo. You could rivet a metal strap across the hole area and put a screw through that into the door but to be honest the washer idea sounds the best. Its quick, cheap, easy and clean.
Old October 31st, 2007, 07:57 AM
Or epoxy a metal strap across the back of the hole areas that are damaged and redrill the holes. I have found that due to the shape of the recess, the washer doesn't always work.
Old October 31st, 2007, 11:19 AM
jaguiler
John A
2006 - LR3
a metal strap across the back of the panel seems to be the best solution, as mentioned above - then you just drill into the strap where the hole should have been - you can then rivet the strap to the panel. use a stainless steel strap
door, door tops, panels, soft top
1997 Bestop Soft Top Like New & Misc Parts Adam Armendariz For Sale - Parts 16 December 8th, 2005 01:43 AM
Best Top Soft Top For Sale WCURoverD90 For Sale - Parts 2 November 1st, 2005 04:24 PM
White 95 D90 Soft top for sale.. sniff.. Richard Dekkard For Sale - Vehicles 5 December 1st, 2004 12:38 PM
Original Soft Top 94 D-90 & Surrey Top!!!! doozle For Sale - Parts 7 November 10th, 2004 08:22 PM
Which is the best soft top for D-90? bbandit Defender Technical Discussions 13 March 9th, 2004 08:40 PM
