SG 3-link - Defender Source
Old September 4th, 2012, 05:46 PM
Jake1996d1's Avatar
Jake1996d1
Jake
96 Disco/88 RRC
SG 3-link
So it has been fun but I have decided it may be time to let the 3 link go on to a new home.. Was going to chop it up to make it work with a toy hi pinion but I think I'll just sell it instead.. Not to mention I have been driving on the highway more often. Bought it not to long ago from Denny at HLC... This is a complete original unit with SG's crossmember, links, track bar box and axle mounts.. 100% bolt on. Would like to get around $700 for it.
Also have a center link for a 5" lift made my Mongo - 2.5 .250 wall with a brand new ballistic orbital joint (or both if you're willing to pay) for $125
Will accept RTE radius arms for 5" lift as partial trade.
Can post pics if needed. Will need time to remove it from truck once I find a serious buyer.
Old September 4th, 2012, 06:08 PM
The crossmember will need to be modified to make it work on a 90, as the disco frame is different.
Old September 4th, 2012, 06:11 PM
Jake1996d1's Avatar
Jake1996d1
Jake
96 Disco/88 RRC
Really? Did not know that - how is it different? I knew it was difficult to fit on a TDI for some reason.
Old September 4th, 2012, 08:30 PM
mightymg's Avatar
mightymg
Lane Farka
97 D90, 05 LR3, 95 RRC LWB
The bottom bolts are different, I ran my disco one on my 90, but as stated i had to modify it.
project whore!
95 RRC LWB-- DD
97 D90 37 " krawlers, coilovers, beadlocks, stretched
05 LR3 - Mamas/ tow rig
- Moab rally vids 2010
Old September 4th, 2012, 08:38 PM
I have the Rovertym ones for a 4 inch lift, and I may be interested in a trade.
Old September 4th, 2012, 08:42 PM
Lindy's Avatar
Lindy
Eric Lindstrom
1994 d-90 #1444
You been in Ankeny for long?
Old September 4th, 2012, 09:17 PM
ini88's Avatar
ini88
Daniel Marcello
Alloy+Grit Creative Director
I have a Defender 3-link cross member that I can sell to help the potential buyer.
1955 Series I
1975 FC101 Vampire
1994 Defender 90 #916
1967 Lancia Fulvia
1974 Alfa Romeo GTV
Old September 4th, 2012, 09:25 PM
I'd love to see pics of this.
Old September 4th, 2012, 09:33 PM
Jake1996d1's Avatar
Jake1996d1
Jake
96 Disco/88 RRC
Nope less than a month! I'll shoot you a PM with my info if you want to take the rovers out
------ Follow up post added September 4th, 2012 08:36 PM ------
If you can measure the length and let me know what you are think they are worth. I got a line on a pair for $175+ shipping I may jump on so let me know..
Old September 4th, 2012, 09:38 PM
175 is a great price.
Dan, what do you want for the crossmember?
Old September 4th, 2012, 09:40 PM
Jake1996d1's Avatar
Jake1996d1
Jake
96 Disco/88 RRC
Yes it is but just like the 3-link shipping wont be cheap...
Old September 4th, 2012, 11:19 PM
ini88's Avatar
ini88
Daniel Marcello
I have no idea. in the low hundred(s) look up how much they got for and I will make mine cheaper
I had it on the truck and it is in great condition as it was never hooked up to the 3-link. The 3-link is mint and in storage. I need to put a 300Tdi 3-link member on there soon.
1955 Series I
1975 FC101 Vampire
1967 Lancia Fulvia
1974 Alfa Romeo GTV
Old September 6th, 2012, 12:45 PM
Jake1996d1's Avatar
Jake1996d1
Jake
96 Disco/88 RRC
BUMP Help me fund my yota swap!!
Old September 6th, 2012, 01:15 PM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
I'm interested, but would like to see what's involved in making it work with my tdi. I assume it's just a matter of fabbing up a different cross member.
Semper Fi!
Old September 6th, 2012, 01:21 PM
From what I remember, I think tdi guy has the installation of it the build thread of his personal D90.
Old September 6th, 2012, 01:41 PM
Jake1996d1's Avatar
Jake1996d1
Jake
96 Disco/88 RRC
Yea Randy has one on his tdi 90. There was a thread on pirate a while ago about fitting it on a TDI. I think the exhaust was the main issue and the D1 cross member can be made to work with some drilling like lane mentioned. I can take measurements off of it if you'd like.
Old September 6th, 2012, 01:50 PM
Wolf Fabrication
Sterling Archer
'08 D3
Is it the newer kit with poly bushings and heim joints?
Semper Fi!
Old September 6th, 2012, 02:26 PM
Jake1996d1's Avatar
Jake1996d1
Jake
96 Disco/88 RRC
Afaik SG never made a kit with heim joints. The kit has two upper links that bolt to radius arm mounts and a poly at the axle. The center link that comes with it is a terraflex link. I have a center link that is custom made (see above) and twice the size of the stock link. What's your email??
Old September 6th, 2012, 02:29 PM
Wolf Fabrication
Sterling Archer
'08 D3
wolffabrication@gmail.com
A few threads on this board mention an updated kit with new hardware.
Semper Fi!
Old September 6th, 2012, 02:41 PM
Jake1996d1's Avatar
Jake1996d1
Jake
96 Disco/88 RRC
Hmm weird, they may be talking about the better terraflex center link. with an orbital on one end.. Since the center link takes a lot of the braking force I decided to go big. The ballistic joint on the frame side is solid and helps with axle wrap. Withthe stock joint you can feel some of the axle wrap but that's just because it's all made of poly. Lots of info here http://discoweb.org/forums/showthrea...ghlight=3-link
A couple pics of it on the floor assembled so you can see what it looks like and then the HD center link, and installed on the truck (sorry it's so dirty)
ID:	57172   Click image for larger version
ID:	57174   Click image for larger version
3-link, sg 3-link
SG 3 Link Bushings Needed TDI Guy Defender Technical Discussions 19 March 7th, 2010 12:47 AM
SG 3 link bushing source TDI Guy Defender Technical Discussions 4 January 3rd, 2007 12:12 PM
New SG HD Drag link TDI Guy For Sale - Parts 3 June 23rd, 2006 08:05 AM
SG 3 link pro's con's Bowtracer Misc. Chit-Chat 5 October 30th, 2004 12:11 PM
SG Stage 2 w/ 3rd link Joe P Defender Technical Discussions 5 February 1st, 2004 01:13 PM
