Series Transmission - Defender Source
Old September 25th, 2010, 06:11 PM
mattm's Avatar
mattm
Matthias Moran
1963 109
Series Transmission
This is a late suffix series III main gearbox with series IIA suffix B transfer case and Rocky mountain Roverdrive. The late series III is sometimes called the Santana box and is (I believe) the strongest series gearbox that you can get. These are rare in the USA. Also, the suffix B transfer case is highly desirable for off-road use because the low range is about 20% lower that all the later series transfer cases. Unfortunately the main gearbox shows signs of wear on the 1st/2nd synchro unit although it's still usable. Also, the transfer case is leaking lots of oil through the transmission brake. I believe the transmission brake probably got packed with mud during MAR 2009 which destroyed the rear output oil seal. That's fairly easy to fix.
$900 complete (due to generally dirty condition.)
It's in my garage in Chevy Chase, MD and I prefer if you come and get it (although I could ship for a few hundred extra.)
Old September 26th, 2010, 04:40 PM
moose's Avatar
moose
Brett
Ex-Mod Tdi 110 Hard Top
What condition is the Roverdrive in? Would you consider selling it separately?
Brett
Ex-Mod 110 Tdi
Series 3 88 Diesel Soft Top
Old September 26th, 2010, 06:23 PM
mattm's Avatar
mattm
Matthias Moran
1963 109
It's fine but I prefer to sell the whole thing as it's less work for me that way.
series, transmission
Adapter plate for series 1962siia88 Series Technical Discussions 7 September 8th, 2010 01:16 AM
Conatiner Arrival means Defender / Series Parts Clean Out SafariHP The Vendors Loft 18 December 5th, 2008 09:38 AM
ZF Transmission Hesitation Shifting 1of40 Defender Technical Discussions 1 July 26th, 2005 11:41 AM
94 discovery automatice transmission capacity cgalpin Defender Technical Discussions 4 August 26th, 2004 10:57 AM
» Defender Registry
Lang
Langley90
90
uc4me
Add your Defender
