Sals detroit in carrier - Defender Source
Old March 6th, 2016, 05:18 PM
mightymg's Avatar
mightymg
Lane Farka
97 D90, 05 LR3, 95 RRC LWB
Selling my sals locker, it's in good shape and works perfectly set up for 24 spline. Does not come with gears. Just bolt in your ring gear and go!
450 shipped
Lane
project whore!
95 RRC LWB-- DD
97 D90 37 " krawlers, coilovers, beadlocks, stretched
05 LR3 - Mamas/ tow rig
- Moab rally vids 2010
Old March 6th, 2016, 05:27 PM
mightymg's Avatar
mightymg
Lane Farka
Another picture
project whore!
95 RRC LWB-- DD
Old March 9th, 2016, 08:02 PM
mightymg's Avatar
mightymg
Lane Farka
Bump 400$
project whore!
95 RRC LWB-- DD
Old March 9th, 2016, 09:40 PM
Firemanshort's Avatar
Firemanshort
David Short
1980 Stage One 109
Pm sent
Firemanshort
1980 Stage One 109
Sterling, VA
Old March 11th, 2016, 09:13 PM
mightymg's Avatar
mightymg
Lane Farka
Sold. Thanks!
project whore!
95 RRC LWB-- DD
Old March 31st, 2016, 12:06 AM
Firemanshort
David Short
1980 Stage One 109
New Home
Untitled by David Short, on Flickr
Here it now sits in the rear of a Stage One. Glorious.
Firemanshort
1980 Stage One 109
Sterling, VA
Old March 31st, 2016, 02:11 AM
chris snell's Avatar
chris snell
Chris Snell
87 Ex-MOD 110
Did you take any pics of the installation process?
1987 Ex-MOD 110 Tithonus LHD
2013 LR4
Old March 31st, 2016, 08:12 AM
LR Max
Thomason, Max
1973 Series 3 109
Dave, you'll love the rear detroit. It just works. Had mine for...15 years now. Cannot imagine having anything else. However I suggest in a year or two, replace both rear shafts and flanges. I had to eventually replace mine. I think if I had replaced them BEFORE they broke, it would be easier.
As for installation of a rear salisbury detroit, its super easy. Pull the cover, pull the shafts, remove the carrier straps, the take a crowbar and pry the carrier out. Get an old couch cushion and put it under the diff, so if it pops out, it lands on the couch cushion.
Then unbolt the carrier, pull the spiders out, pop the detroit in, the re-assemble. Just follow the instructions on torques and you'll be good.
Old March 31st, 2016, 09:08 AM
meatblanket's Avatar
meatblanket
Mike Simpson
1955 86 1986 ExMOD 110
I'm wondering why the marking compound is on there, shouldn't be any need to adjust anything if the old carrier, bearings, shims, etc just go back in.
Old March 31st, 2016, 09:15 AM
slorocco
Dan Prasada-Rao
1963, 109 Station Wagon
Look at the for sale thread. It appears he bought and installed what was sold on this thread, so it's a different carrier than was in there before.
Old March 31st, 2016, 09:18 AM
Daddymow's Avatar
Daddymow
Raub A.
1987 D110 Tithonus
Dave your fire truck is going to be a monster on the trails now.
Old March 31st, 2016, 09:46 AM
Firemanshort
David Short
1980 Stage One 109
Max described the install pretty well.
The hardest part was pulling the bearings from the old carrier - we needed to scrounge up a bearing puller. In the end - I do not know why we spend so much time pulling the old bearings when we installed new bearings on the Detroit. In any event - the old Sals is cleaned, oiled, and packed away for storage.
We re-used the shims from the open diff for the Detroit diff and checked everything with marking compound. We checked the old diff with marking compound before we removed it, too. We did not have to make any adjustments - but it was good to use the compound to make sure we knew what the before and after gear interface looked like.
Firemanshort
1980 Stage One 109
Sterling, VA
Old March 31st, 2016, 12:20 PM
LR Max
Thomason, Max
1973 Series 3 109
I had to replace my old carrier bearings a few years ago after axle shaft pieces tore up the races. I just took my entire 3rd member and replacement bearings off at my local NAPA that had a "machine shop". I dropped it off on the way to work and picked it up on the way home. Was charged $35 and it took 5 minutes to drop it off, and 10 to pick it up (due to obligatory BSing). Easier than screwing around with it for hours on end in my garage.
BTW, she will drive a bit different, but after about 100 miles, you get used to it. With manual steering, you do feel it in the U-turns, but, meh. On the flipside, off-road performance is increased by 538562958673278593625x, so solid trade off.
Old March 31st, 2016, 01:07 PM
Daddymow's Avatar
Daddymow
Raub A.
1987 D110 Tithonus
X2 on the u turns, but no big deal, other wise most of the time I don't know it is there.
Old March 31st, 2016, 02:23 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
I briefly discussed this with the Fireman...but are there any sources for HD axles for the rare Stage 1 axle width??
What size/length are your axles Max? (compared to a Stage 1 Sals)
Rent my
Old March 31st, 2016, 02:35 PM
slorocco
Dan Prasada-Rao
Pull the shafts and send them to Moser. They can make up a set for you then save the old one's as spares. I had them do a set for my front Salisbury.
Old March 31st, 2016, 02:38 PM
chris snell
Chris Snell
87 Ex-MOD 110
Stage 1? As in, the early 110 axles with the thicker flanges? KAM.
Land Rover Heavy Duty Half Shafts | KAM Differentials
2013 LR4
Old March 31st, 2016, 02:46 PM
Series Trek, I'm sure would do a set for you.
Extreme duty axles
Old March 31st, 2016, 02:53 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
I dont think so, Fireman's axles are really narrow.
I'd guess they're at least an inch an 1/2 or more narrower per side than a D1 or Defender axle.
slorocco probably has the right idea...
Rent my
Old March 31st, 2016, 03:55 PM
Firemanshort
David Short
1980 Stage One 109
The Stage One is narrower than the Disco / Def axles. However, my Stage One and Max's Series axles should be the same (provided Max's are 24 spline). Flanges should be the same, too.
I will have to keep an eye out for this.....
Firemanshort
1980 Stage One 109
Sterling, VA
Detroit Locker for Sals. rear end kellymoe For Sale - Parts 3 February 20th, 2010 11:23 AM
Front truetrac and rear sals. truetrac or detroit D90user Wanted 1 October 29th, 2007 12:55 PM
Looking for sals rear axle ChicagoDon Wanted 1 March 28th, 2007 07:52 AM
Sals. pinion seal D90user Defender Technical Discussions 0 March 15th, 2007 01:01 AM
Sals in Kansas pendy For Sale - Parts 0 March 29th, 2005 12:01 AM
