Safari Guard 3" springs $300 - Defender Source
Old August 6th, 2014, 02:12 PM
Brewie212's Avatar
Brewie212
Brian Kandefer
Have a set of progressive 3" SG springs, there was no sag on my 90 ST. They did have some sag when installed on 97le with all the extra weight. Asking $300 plus the ride.
Old August 6th, 2014, 02:22 PM
down_shift's Avatar
down_shift
Russell
94' D90 ST & 06' LR3
Can you hold these for 10 minutes for Ed Kang? I'm tracking him down now.
Old August 6th, 2014, 02:28 PM
Brewie212's Avatar
Brewie212
Brian Kandefer
Clock started
Old August 6th, 2014, 02:31 PM
thanks guys! I appreciate the heads up, russ
sending you a pm brewie
------ Follow up post added August 6th, 2014 02:34 PM ------
Any idea on the spring rate and free height in inches or mm for the fronts?
I really only need front coils as the rear is already at 3"
Old August 6th, 2014, 03:08 PM
Brewie212's Avatar
Brewie212
Brian Kandefer
Nope just they came off a stage three SG suspension system. Progressive rated springs, I had them acid dipped and and powder coated black
Old August 6th, 2014, 03:17 PM
best springs ever made for a 90
Old August 6th, 2014, 03:32 PM
down_shift's Avatar
down_shift
Russell
Ed -- you are getting too technical. Pull the trigger then unload your existing rear springs. Why mess with a quality match set of four?
Old August 6th, 2014, 03:35 PM
I'm out guys...sorry about that. I really appreciate the heads up!!
Old August 11th, 2014, 01:12 PM
Brewie212's Avatar
Brewie212
Brian Kandefer
Bump
Old September 2nd, 2014, 09:27 PM
cellulararrest's Avatar
cellulararrest
Chris Snyder
1994 D90 #614 | '07 L322 SC
Payment sent on these, so consider them gone.
I think I have a spring addiction...
Old September 2nd, 2014, 09:32 PM
Brewie212's Avatar
Brewie212
Brian Kandefer
I have a set of 3" RTe springs as well
Old September 2nd, 2014, 10:00 PM
phoenix37's Avatar
phoenix37
john
interested in the RTEs PM sent
Old September 2nd, 2014, 10:47 PM
fishEH's Avatar
fishEH
Brett Fritzler
94, 95, 96 D1's
Well sonuva......!!!
About a week too late for me.
Old September 2nd, 2014, 10:48 PM
Brewie212's Avatar
Brewie212
Brian Kandefer
I had them a week ago
Old September 2nd, 2014, 10:50 PM
fishEH's Avatar
fishEH
Brett Fritzler
94, 95, 96 D1's
Yesssss, but you didn't post them a week ago.
Old September 2nd, 2014, 10:58 PM
Brewie212's Avatar
Brewie212
Brian Kandefer
You didn't ask
Old September 3rd, 2014, 08:32 AM
RockShow's Avatar
RockShow
Ben Goodwin
1996 D1
What do you want for the rte 3"?
Old September 3rd, 2014, 08:46 AM
Brewie212's Avatar
Brewie212
Brian Kandefer
$300
Old September 3rd, 2014, 09:06 AM
RockShow's Avatar
RockShow
Ben Goodwin
1996 D1
I think I am going to go with the 2" but thought I would check.
You wouldn't happen to have a timing cover for a 300 tdi lying around in your treasure warehouse? I managed to break all for threaded lobes off the pulley shaft trying to remove the fan.
Also, garage doors are all set as soon as my contractor puts in his next order at the supply place.
Old September 3rd, 2014, 09:08 AM
Brewie212's Avatar
Brewie212
Brian Kandefer
Originally Posted by RockShow View Post
I think I am going to go with the 2" but thought I would check. You wouldn't happen to have a timing cover for a 300 tdi lying around in your treasure warehouse? I managed to break all for threaded lobes off the pulley shaft trying to remove the fan. Also, garage doors are all set as soon as my contractor puts in his next order at the supply place.
no worries! Thanks for doing the leg work on them for me! No 300 timing covers here, I would contact Pendy, as for the 2" springs they are NLA. If you need anything let me know
Rotating Shackle "Hoist Ring" Retaining Clips (Safari Guard Style) KKilo23 Wanted 39 May 17th, 2014 10:29 PM
" Wolf " Style Steel Rims 6.5" X 16" 2 3/4" javelinadave For Sale - Parts 3 January 27th, 2014 08:36 AM
$1000 in d-90 parts for $500, incuding new hinge kit and safari guard diff guard hecklerkoch91 For Sale - Parts 10 June 16th, 2011 08:19 PM
3" springs "OR" 1" spacers for the rear discoinjapan Wanted 0 June 16th, 2009 10:33 PM
OME springs: "A" and "B"?? jaherring Defender Technical Discussions 3 October 30th, 2004 05:49 AM
