Safari Gard Hilift Mount - Defender Source
Old August 12th, 2011, 06:21 PM
Abrooks's Avatar
Abrooks
Tony Brooks
Mounts your hilift to your spare tire. Used but in good shape. What you see in the picture is what you'll get (you'll need washers and wingnuts for the hilift and a new hitch pin for the tube).
Call it $75, I'll box and ship for $10 if you need.
Name:	SG mount.jpg
Old August 12th, 2011, 06:55 PM
BOBCAT110's Avatar
BOBCAT110
Ken Jagolta
94 d-90
I will take it ,Tony. PM or email me your Paypal info if you have it.
Old August 12th, 2011, 07:39 PM
specops1526's Avatar
specops1526
Beluga '97 90
Nice, Ken! The elusive SG hi-lift carrier...
Originally Posted by rijosho
Beluga 97 D-90
Chawton 04 DII SE
Tangiers 04 DII G4
Old August 12th, 2011, 09:31 PM
2nds if Ken decides to pass for any reason...Tony I can pick it up from you in VA next week.
Old August 13th, 2011, 11:13 AM
BOBCAT110's Avatar
BOBCAT110
Ken Jagolta
94 d-90
Paid through Paypal, thanks Tony. I have been wanting one of these for awhile. I think you got the last Disco one from Alex, Brian. Right?
Old August 13th, 2011, 12:55 PM
Abrooks's Avatar
Abrooks
Tony Brooks
Shipping out on Monday, thanks.
Old August 13th, 2011, 01:21 PM
specops1526
Beluga '97 90
Yep, got that one from Alex. Nice that you finally got one...been a long time.
Beluga 97 D-90
Chawton 04 DII SE
Tangiers 04 DII G4
Old August 13th, 2011, 08:38 PM
stocker
Mack
1998 Disco 1 LSE
Surprised there isn't someone producing these to order. They seam simple enough.
D1Driver on the other boards
Old August 13th, 2011, 08:59 PM
Abrooks's Avatar
Abrooks
Tony Brooks
I was thinking the same thing -- it's not a complicated piece of engineering and I'd think any machine shop could replicate it relatively easily.
Old August 14th, 2011, 08:42 PM
BOBCAT110's Avatar
BOBCAT110
Ken Jagolta
94 d-90
Thanks, Tony. Hmmmmmmm, maybe I will have some made up........will let ya'll know.
Old August 15th, 2011, 10:42 PM
stocker
Mack
1998 Disco 1 LSE
The only issue I see is how would you lock the jack on there without using a generic cable lock? Then again, I wouldn't keep my jack on there all the time.
Old August 19th, 2011, 11:46 AM
BOBCAT110's Avatar
BOBCAT110
Ken Jagolta
94 d-90
Part received, thanks Tony and D90 Source.
Old September 1st, 2011, 09:36 PM
Jpayne's Avatar
Jpayne
Jeff Payne
'83 110 3 Door
Are you going to make some of these? If so I'll back off.
Since the original item sold I thought it ok to hijack. If anyone has a problem I'll start another thread.
I was thinking of having some of these developed and wanted to ask some questions first.
1) Why are these two separate pieces?
2) What is special about the angle and are there different angles drilled into the pipe?
3) Any other features that people would like to see on this?
Any input would be appreciated.
Jeff
Old September 1st, 2011, 10:14 PM
James Pierce's Avatar
James Pierce
James Pierce Jr.
I believe they are two piece so that you can install the tire over it. If it weren't the rim would not fit over the piece of flat bar that the high lift attaches to.
The piece with the lug pattern actually goes behind the tire, the tire is installed and the pipe protrudes through the center of the rim. The outer part pins on and your high lift attaches from there.
Hope this helps. Not sure how you would improve on it other than removing the SG.
Old September 2nd, 2011, 09:33 AM
Abrooks's Avatar
Abrooks
Tony Brooks
James is exactly right on the 2 piece design. The only suggestion I'd have for improvement would be to allow the bracket that holds the hilift to rotate a few degrees to the side to allow for an improved departure angle.
Old September 2nd, 2011, 09:55 AM
Jpayne's Avatar
Jpayne
Jeff Payne
'83 110 3 Door
Ok I understand. That pipe doesn't look like it is long enough to go all the way through the thickness of the wheel though. I guess it would end up right at the backside of the wheel. Doesn't it rattle a bit because of that pin connecting the pipes together?
I wonder what I would have to do to get it to fit on the setup I have on my rear door. Chop off the brace in the middle of the tire mount?
Old September 2nd, 2011, 10:38 AM
James Pierce
James Pierce Jr.
Chop or simply unbolt it from the inside? It looks like a u bolt. You could probably unbolt it and reinstall new hex bolts in its place.
My guess is it would rattle but I have no experience with them, mine is on the bumper where it belongs. I like the Idea of adding additional holes so it can be rotated 20 or 30 degrees to allow the foot of the jack to be at the bottom corner of the tire.
Old September 2nd, 2011, 11:02 AM
1) They are two separate pieces for convenience, to be able to get to the spare tire and/or the jack.
2) The only difference between the SW and ST version is the hole on the pipe, they are off by 90 degrees. You could easily drill a few additional holes to accommodate options.
3) A secure lock that would lock the jack to the part, plus secure the part too. Optional attachments would be cool too, i.e. jerry can holder, bike rack option or basket rack, and etc. I am not trying to debate the weight issues with the tire carrier.
Jeff
Old September 3rd, 2011, 09:03 AM
Buddie's Avatar
Buddie
Buddy
1997 D90 ST
Does anyone know how much did these go for new?
Old September 3rd, 2011, 09:10 AM
They were $85 new... But SG is gone, so they are no longer available new.
mount
Safari Gard National Press Release SafariGard The Vendors Loft 18 June 19th, 2009 09:37 AM
Safari Gard hi-lift mount rvrsrvc For Sale - Parts 4 October 27th, 2004 04:02 PM
Safari Gard equipped Defender for sale JAZZIQC For Sale - Vehicles 5 July 30th, 2004 11:41 AM
Safari Gard Spare Hilift mount dmarchand For Sale - Parts 0 July 8th, 2004 12:54 PM
SAFARI GARD hi lift mount Britt Easterly Wanted 3 July 5th, 2004 11:00 PM
