RTE Rear Shock Mount Kit - Defender Source
Old May 25th, 2011, 10:04 PM
The Dro
Dro
1988 Ninety
Brand New. I installed it last Tuesday (last night) and removed it today. Zero miles on them. I'm going to use stock shock settings.
$145
I just want to cut my losses and you can save a few bucks here.
I can bring to HH or ship on your dime.
http://www.rovertym.com/index.php/Di...Mount-Set.html
Old June 15th, 2011, 10:42 AM
The Dro
Dro
1988 Ninety
$150 shipped
Old June 15th, 2011, 10:47 AM
cellulararrest's Avatar
cellulararrest
Chris Snyder
1994 D90 #614 | '07 L322 SC
Are these tall enough for 12" foxes in the rear? If so, I'm interested.
Old June 15th, 2011, 11:06 AM
The Dro
Dro
1988 Ninety
I believe they do work with them. You'll need to add a 4" bump stop so they do not bottom out.
I called RTE and they will work with RTE 3" springs.
Can anyone chime in and give us a hand?
Old June 15th, 2011, 11:21 AM
Rugbier's Avatar
Rugbier
Gustavo
Yeap,
They will work with the RTE 3" springs with no problem as these are made for extended travel shocks
GLWS
NO SIGNATURE
Old June 15th, 2011, 11:25 AM
cellulararrest
Chris Snyder
Alright. I'm just slightly apprehensive that they won't be tall enough if I want to run the 12" in the rear with a 2" lift. Sure, I could add bumpstops, but that's kind of a workaround. The Rockware's are taller.
Old June 15th, 2011, 11:33 AM
Rugbier's Avatar
Rugbier
Gustavo
12" shocks with 2" is not a good recipe
NO SIGNATURE
Old June 15th, 2011, 11:40 AM
cellulararrest
Chris Snyder
Compressed distance between mounts won't change significantly between 2" and 3" lifts.
I went out and took some measurements. Looks like these won't work out for me, unfortunately. Rockware it is.
Old June 15th, 2011, 11:58 AM
The Dro
Dro
1988 Ninety
I still think they'll work... but, no problem.
Old June 15th, 2011, 12:42 PM
Compressed distance between mounts won't change AT ALL between 2" and 3" lifts.
Fixed it for ya
Old June 15th, 2011, 01:06 PM
cellulararrest
Chris Snyder
Originally Posted by Ren Ching View Post
Fixed it for ya
You're probably right. I don't know the coil count or wire diameter difference between 2" and 3" springs. Either way, it doesn't make enough of a difference.
Old June 15th, 2011, 01:10 PM
The Dro
Dro
1988 Ninety
I know we talked about it, but the RTE shock mount, sits 1" higher than stock.
Old June 15th, 2011, 01:11 PM
cellulararrest
Chris Snyder
Yep - Fantastic mounts, just not fit for my application, unfortunately. Someone else will come along! Great price.
Old June 15th, 2011, 01:20 PM
The Dro
Dro
1988 Ninety
Thanks!
Old June 16th, 2011, 03:19 PM
The Dro
Dro
1988 Ninety
These are still for sale...
Old June 21st, 2011, 08:52 AM
The Dro
Dro
1988 Ninety
bumpity
Old June 24th, 2011, 07:50 AM
The Dro
Dro
1988 Ninety
I know you want these...
Old June 27th, 2011, 08:05 PM
The Dro
Dro
1988 Ninety
Bump
Old July 8th, 2011, 07:46 AM
The Dro
Dro
1988 Ninety
I need funds for the series...
Old July 8th, 2011, 02:42 PM
wcampbel@nas.edu's Avatar
wcampbel@nas.edu
Bill Campbell
1994 D-90 ST
Are these for Discos or Defenders?
I may be interested. What shocks would I run with these?
kit, mount
Scorpion Rear Upper Shock Mounts enjoi1968 For Sale - Parts 2 December 5th, 2009 09:44 PM
Rear Shock Mount (Stock) Stmpede Wanted 7 October 16th, 2007 02:18 AM
Rear Shock Mount Drop Kit mffoster For Sale - Parts 3 January 10th, 2007 10:05 AM
For Sale: Mantec Steering Guard, NSO Rear Shock Mount, Hinged Radius Arm Doogs For Sale - Parts 8 January 26th, 2005 11:28 AM
Nadim Samara chrisvonc D-90 Source Friends 0 February 23rd, 2004 10:44 PM
