RRC Part Out - Page 2 - Defender Source
Old November 22nd, 2015, 07:15 AM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
Originally Posted by Kevin88RRC View Post
Exactly.... the wiring end from the harness.
Not all RRC had heated windshields. Started in 93 I think. I put one in my '88 and still working on the wiring.
I just checked.
1989 model year started the heated front windscreen( and thinner side windows!)
So, yeah, your '88 is the last year of no front window heat.
Honestly, that is one of the best features in the Classic- it always clears up a frosty or foggy window fast!
From memory, I think there are 2 wires for the windshield- 1 on each side about 6 inches up from the bottom.
Rent my
Old November 23rd, 2015, 09:42 AM
Roverlab
Trevor Griffiths
85 110, 92 110, 92 RR, 06 LR3
Don, I'll take the fuse box cover and the 6 switch panel.
Also, would you feel like removing the crankshaft pulley including the alternator drive, the power steering pulley, and the alternator?
Email is
Same place, new dogs.
Old November 23rd, 2015, 10:40 AM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Originally Posted by Roverlab View Post
Don, I'll take the fuse box cover and the 6 switch panel. Also, would you feel like removing the crankshaft pulley including the alternator drive, the power steering pulley, and the alternator?
Sounds good.
If my bro-in-law doesn't want to I'll pop the hood and grab those items. Not sure the condition but can pull them.
Old November 23rd, 2015, 11:03 AM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Front bumper, cowel, ends and brush guard - $500
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Brush guard is a little crispy in some areas - probably be best for a strip and repaint/powder.
Old November 23rd, 2015, 11:07 AM
Kevin88RRC's Avatar
Kevin88RRC
Kevin Keith
1988 RRC
Hey Don... can you snip that plug off the body harness for the heated windscreen?
thx
Old November 23rd, 2015, 11:09 AM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
thx
I should be able to - waiting for response from BIL - thanks
And it sounds like there would be 2 of them correct?
Old November 23rd, 2015, 11:16 AM
Kevin88RRC's Avatar
Kevin88RRC
Kevin Keith
1988 RRC
Oppose sorry if I looked impatient. Thought it might have gotten buried in the thread.
Only one plug for the front. The other is for the rear.
ID:	135438   Click image for larger version
Old November 23rd, 2015, 11:17 AM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
They will probably be lurking just behind the plastic finisher pieces...and the switch plug piece.
Rent my
Old November 23rd, 2015, 01:08 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Oppose sorry if I looked impatient. Thought it might have gotten buried in the thread. Only one plug for the front. The other is for the rear.
Not impatient at all!
You are looking for the plug on the other side of that switch you circled?
Sorry - for all the questions I am not that familiar with RRC's.
Old November 23rd, 2015, 06:26 PM
Kevin88RRC's Avatar
Kevin88RRC
Kevin Keith
1988 RRC
Yes the female plug side with some wire to splice on to.
Old November 23rd, 2015, 08:00 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Ok will check into it
Old November 25th, 2015, 08:07 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Ok - so he is going to take the windscreen out of the parts truck as his white RRC has a crack in it. He wants to make sure the plugs are all set on his before he sells. If you don't mind waiting a few weeks he hopes to have it done and will get whatever you need that is left.
Old November 27th, 2015, 09:14 AM
Kevin88RRC's Avatar
Kevin88RRC
Kevin Keith
1988 RRC
Thanks for the update. I'd like to get it sorted sooner but if I don't I'll check back in with you.
FYI, they are color coded. But he circled the blue one and that isn't it.
-Jeff
You are correct. In my hast I circled the wrong switch in the back view.... should have been the lower right.
What is the name or part number for this part? rd10014 Defender Technical Discussions 3 June 24th, 2014 12:03 PM
Parting out 1991 RRC SWB & 1993 RRC LWB. Erik@Lucky8 For Sale - Parts 0 November 7th, 2013 10:43 AM
NAS (mostly) small bit clean out from the 94 Part Out and others SafariHP The Vendors Loft 7 August 6th, 2012 09:26 AM
Bottom Part of Rear Seat Belt "V" OR Part Number? hutch Wanted 5 March 25th, 2008 08:41 PM
need a part # or info on where to buy part yellowrover Defender Technical Discussions 4 August 3rd, 2004 09:55 PM
