RRC ABS Elimination "kit" - Defender Source
Old October 5th, 2016, 08:57 AM
Shiftonthefly1
Ben
97 Disco
I have all the parts necessary to change the ABS system to a regular standard braking system. All factory parts from an older non abs truck. Bolt in. No cutting drilling or re-plumbing. I have all the factory lines master cylinder reservoir booster/factory shim, brake fluid switch and proportion valve. Looks and works like factory.
250 plus shipping.
Old October 5th, 2016, 09:16 AM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
This is tempting.
I was talking with another RRC enthusiast at MAR about the ever dwindling availability of working ABS pumps for Classics.
One of mine is a '91 Hunter(non-ABS) and the other is a '93 LWB but its a 300Tdi.
What would be required to convert a Tdi ABS system to standard brakes?
Also, is there a legal issue removing the ABS system completely from a 1993 vehicle?
Rent my
Old October 5th, 2016, 09:29 AM
Shiftonthefly1
Ben
97 Disco
Not sure about the TDI trucks. I would assume they'd have same brakes but I have no idea.
No idea on the legality. Not sure how anyone would contest such a thing.
Also I wanted to mention that the donor truck was a lifetime desert vehicle. So the lines and parts have zero rust. The brakes worked fine before I removed them
Old October 5th, 2016, 02:37 PM
In Pa the inspection requirement says the ABS need not work.
Old October 5th, 2016, 08:43 PM
MonLand
Loic Fabro
95 D90 - 96 Disco -06 LR3
Make sure you let your insurance know if you change any of the equipments they regard as "safety features".
MonLand
1995 D90 NAS
1996 Discovery NAS
Old October 6th, 2016, 01:44 PM
ukoffroad's Avatar
ukoffroad
Chuck Yarbrough
67 IIA
My 92 RRC had no ABS, much more reliable. It went into a friends truck when that one rusted to bits.
Chuck
67 Series IIA
The parts falling off this vehicle are of the finest British craftsmanship.
Old October 6th, 2016, 02:41 PM
belgian's Avatar
belgian
Maxim
1995 RRC SWB
Same here on my '92
The base models in that year came without ABS/ Sway bars and less wooden trim to keep costs down.
The ABS breaks, wooden trim fades/chips, so ironically the cheaper models in '92 are more wanted /valuable now!
1984 Camel Trophy 110
1995 Range Rover Classic SWB
1992 Range Rover Classic SWB
Old October 6th, 2016, 04:10 PM
The abs in these trucks is very unsafe. When it fails you loses all braking.
Old October 6th, 2016, 05:42 PM
Shiftonthefly1
Ben
97 Disco
I've never had one fail. Just leak. I just hate the complexity and that stupid pump coming on everytime I start the truck.
Old October 7th, 2016, 04:47 AM
junkyddog11's Avatar
junkyddog11
oil soaked filter
95 RRC 300tdi
Is that a real thing? I can't tell how many I've repaired and never seen one totally fail. The only total failures witnessed have been highly botched conversions and shade tree 'fixes'.
Matt Browne
Old October 7th, 2016, 07:24 AM
Brentflyfish's Avatar
Brentflyfish
Brent McDonald
1988 LHD 110 SW
I had one fail on me while on a family trip to the smokeys and I had absolutely no brake assist. It was harder to stop than my old classic car. I didn't feel safe the entire drive home.
Old November 1st, 2016, 10:03 AM
Shiftonthefly1
Ben
97 Disco
Bump
Old November 1st, 2016, 11:16 AM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
Really?
Mine is a 93 LWB-totally stock system.
When the pump fails you'd better plan for about 2 city blocks stopping distance....
Rent my
Old November 1st, 2016, 11:43 AM
Either you believe in the magic, or you don't. Wabco makes ABS braking systems for commercial aircraft, so they aren't exactly a bunch of knuckleheads.
PS so what about the calipers up front? You don't mention exchanging them for non ABS...
Old November 1st, 2016, 11:52 AM
belgian's Avatar
belgian
Maxim
1995 RRC SWB
There is no difference. When ordering a caliper for my '92 Non-ABS, I was leaning towards getting the '87-'89 calipers, since they were the only non-abs ones I could find.
After a quick phone call, they told me to order the '90-'93 ABS calipers since there is no difference, and that is the correct year.
Old November 1st, 2016, 12:26 PM
Shiftonthefly1
Ben
97 Disco
Only difference in calipers is vented or not vented discs. These lines only go to the union in the fender well of the hard lines/flexible lines for the caliper. It literally just eliminates the abs portion of the brake system. The only other part that's different is that this system only needs one line to feed the rear circuit. The other line is simply abandoned.
All this sounds much more complicated than it is. The pictures above are from my truck. I personally did this a couple years ago and this system is still going strong. No issues or concerns. It actually brakes much better this way.
Old November 8th, 2016, 04:36 PM
92-LSE
Michael
1992 Range Rover LSE
PM sent (and a second by mistake, sorry)
kit
Abs vs non-abs swivel pins jafir Defender Technical Discussions 6 October 14th, 2014 07:24 PM
ABS CVs fit in non ABS car? sflash868 Defender Technical Discussions 2 July 21st, 2014 05:55 AM
Anyone ordered the "ABS plastic" outer wings/fenders? evilfij Defender Technical Discussions 29 July 1st, 2010 07:37 PM
ABS Amigo - "Group Buy"/Discount 98 HOO For Sale - Parts 5 October 20th, 2009 11:34 AM
RRC non-ABS: can you lock brakes? artm Defender Technical Discussions 1 May 30th, 2005 06:13 PM
