Rovertym Arms/Links Front and Rear - Defender Source
Old January 16th, 2011, 06:01 PM
Got these and the fronts don't fit my vehicle, hence, surplus to requirements. They are for a 3" lift. Trailing links have two of the 3 spacers that they come with. You'll need the 3rd one for a bigger than 3" lift (I think). All of the bushings are good save for one on one of the radius arms. I tried to drill out the bolt but ran out of drill bits. It isn't far off if someone has the patience to finish the job. Or just press out the bushing and install a new one. Save yourself the core shipping and the wait. A bit dirty and could use spme paint if you are into that sort of thing but as anyone who has seen these knows, they are about 2" thick solid steel so not much to worry about.
$450 picked up in DC or delivered to NOVA Happy Hour. Interesting trades considered.
Old January 16th, 2011, 09:13 PM
pushngo
Randy Williams
What kind of trades would you consider?
Old January 17th, 2011, 01:31 PM
cabell's Avatar
cabell
Cabell Crowther
Interested in splitting the set? I might be able to use the rears. How do the rears differ from the ones on your truck?
Old January 17th, 2011, 01:46 PM
Rears are the same as what I have, AFAIK. Adding or removing spacers corrects the pinion angle.
I would split the set if someone will buy the fronts. 250 fronts 225 rears. 450 all four. Cabell what are you using up front? Are you lifted?
Old January 17th, 2011, 01:59 PM
cabell's Avatar
cabell
Cabell Crowther
Using the front arms you have there with 3" lift (ome 764 front).
Old January 18th, 2011, 01:56 PM
JSQ's Avatar
JSQ
Jack Quinlan
I'm looking for a set of RTE radius arms but hoping to do better than $75 less than brand new.
Old January 18th, 2011, 03:50 PM
Sending PM...
Old January 18th, 2011, 05:42 PM
ini88's Avatar
ini88
Daniel Marcello
Alloy+Grit Creative Director
those RTE radius arms kick ass. built like a tank.
Old January 18th, 2011, 08:22 PM
The Dro
Dro
1988 Ninety
No RA is brand new... unless you buy Equipe, Terrafirma, etc.
If you buy them from RTE you will need to pay for a core charge (cannot remember the amount) and ship yours to them. The $325 turns into $375 or higher depending were you are.
Old January 19th, 2011, 04:00 PM
FYI these fit D1, D90/110, RRC.
The fronts are 30lbs each and the rears are 15lbs each. They can be shrinkwrapped and shipped pretty economically. Some examples, I think it was about 65.00 to ship all 4 to GA. $75-80 to ship the fronts only to the West Coast. I have a buyer for the rears if someone wants the fronts only.
Old January 19th, 2011, 04:22 PM
hillstrubl's Avatar
hillstrubl
Danny
2005 Disco 3
good luck with the sale
~2005 Disco 3 "Moneypenny"
~2008 GTI TSI
Old January 19th, 2011, 09:23 PM
Michael
Michael
Discovery 1998
If i have 2" lift, will the RAs just give me a longer wheel base?
Old January 19th, 2011, 10:00 PM
I suspect you will end up with too much caster which may make the steering heavy. You may also have problems with your front driveshaft.
Old January 21st, 2011, 11:11 AM
Fronts sold, thanks D-90 source. Sale pending on rears
Surrey top, rear bench seat, and front guard klcarvalho For Sale - Parts 9 October 21st, 2005 12:45 PM
FS Front Wrap Around BBar, Bumper and Rear Bumper Mike M For Sale - Parts 6 November 18th, 2004 08:00 PM
I need front winsheld,right fender black flare, rear door glass. Vadim Wanted 2 July 23rd, 2004 11:47 AM
Front and Rear diffs interchangable? castlerock4x4 Defender Technical Discussions 1 December 24th, 2003 03:11 AM
