REBUILT FRONT DRIVE SHAFT $100 shipped - Defender Source
Old July 9th, 2009, 12:18 PM
RoverDude
John Gadd
Many
ALL U-JOINTS REPLACED!
Better than a new factory unit from the dealer. Now you can grease all the u-joints.
Completely rebuilt, balanced, greased and tested.
Fits all Discovery I 1994 - 1999, Range Rover 1987 - 1988 & Defender 90.
ONLY $100 shipped
roverdudeATsbcglobalDOTnet
Old July 13th, 2009, 08:25 AM
ctrover
jim larson
1984 v8 127
does anyone know if this will bolt right up to my 127?it has an lt230 and stock front 110 diff-I need to do the u joints and this seems like a great price.Thanks
Old July 13th, 2009, 12:16 PM
pendy's Avatar
pendy
jim pendleton
89'd90
You will need the flange also. It will work for you.
legend in my own mind
Old July 13th, 2009, 01:03 PM
ctrover
jim larson
1984 v8 127
what flange is that?something else I need to buy?thanks jim
Old July 13th, 2009, 03:35 PM
pendy's Avatar
pendy
jim pendleton
89'd90
He has the flange also. For 30.00. I was going to buy it if someone just bought the driveshaft. But you will need both. You will have to remove the flange from your transfer case and put the DII one on to use this driveshaft. Not hard at all. It is a good update for your truck.
You should buy this stuff from him.
Good Luck
Old July 13th, 2009, 03:59 PM
Is the front drivershaft for a D90 and a D110 the same?
Old July 13th, 2009, 07:40 PM
pendy's Avatar
pendy
jim pendleton
89'd90
Yes it is
Help! Question about front rotor and drive shaft. DesertRat Defender Technical Discussions 5 October 24th, 2005 07:14 AM
Rovertracks HD front axles CV's & GBR drive flanges ToaDisco For Sale - Parts 8 July 4th, 2005 01:50 PM
D11 front drive shaft jorge Defender Technical Discussions 3 April 12th, 2005 08:03 AM
front drive shaft jorge Defender Technical Discussions 6 December 9th, 2003 11:23 AM
