Rear Step Bumper - Defender Source
Old June 20th, 2012, 11:15 AM
UT-Rider's Avatar
UT-Rider
Sean
1997 D90
Rear Step Bumper
Rear step bumper coming off this weekend. In good shape. Rubber in good shape too. No dents cracks etc. Minimal surface rust in the hitch insert.
$400. Local pick up please. If youre in CT or nearby I can meet you on the Long Island side of the ferry.
ID:	53240   Click image for larger version
"Life's too short not to go big" - JB
Old June 20th, 2012, 11:20 AM
sirjond's Avatar
sirjond
Jonny
1995 D90 ST Alpine White
sending pm
Old June 20th, 2012, 11:26 AM
So confused - did you buy another truck? Did you already finish the renovations on the other house? Welcome back if so.
Old June 20th, 2012, 11:32 AM
UT-Rider's Avatar
UT-Rider
Sean
1997 D90
Bought a '97 SW. Getting rid of a few things I won't be using.
House Renovations done. Sold really quick. See what selling a D90 gets you in renovations..... http://www.redfin.com/VA/Herndon/153...0/home/9091512
Thanks!
Old June 20th, 2012, 11:34 AM
Did you buy the truck from NC or Michigan?
Old June 20th, 2012, 11:38 AM
That's what I was thinking too, but the '97 one with the galvy frame had a PTO hole in the rear crossmember didn't it?
Old June 20th, 2012, 11:39 AM
UT-Rider's Avatar
UT-Rider
Sean
1997 D90
Neither.
Old June 20th, 2012, 12:40 PM
Did you or are you moving to Herndon VA? Or is that house you posted the one you sold?
Old June 20th, 2012, 12:48 PM
UT-Rider's Avatar
UT-Rider
Sean
1997 D90
That's the house we sold. We moved to NY last year. Used to live in Alexandria off Duke St.
Old June 20th, 2012, 12:50 PM
Damn right down the street from me...you should've come to HH!
Old June 20th, 2012, 01:00 PM
UT-Rider's Avatar
UT-Rider
Sean
1997 D90
Requests for more pictures. The ends are just dirty, no rust. There is minor surface rust underneath. Nothing major.
ID:	53242   Click image for larger version
Old June 20th, 2012, 09:24 PM
Jackie Treehorn's Avatar
Jackie Treehorn
A
1985 (legitimately)
anybody know if this is a direct bolt-on for a 110?
I don't want to assume it does becaue as we know the rear cross-members are NOT interchangeable and the degree of bend on the frame rail extensions is different.
Since the step bumper ties into the frame rails on the 90 I was wondering if they line right up with the 110 as well. (anyone follow my thought here?)
I may be interested if it's a direct bolt-on. I currently have an ROW rear step and it doesn't accept the square receiver hitches (and it doesn't tie into the frame rails which is where you'd get your towing strength from).
Old June 20th, 2012, 09:29 PM
Goes on a 110, BUT you need to fab some little extensions to tie into the chassis underneath. Let me see if I have some pics so you can see what I mean.
Old June 20th, 2012, 09:32 PM
Here...first one is what I was referring to, you can see how they "extend" the bumper to the chassis. Easy to make.
ID:	53264   Click image for larger version
Old June 20th, 2012, 09:44 PM
Jackie Treehorn
A
1985 (legitimately)
Yes, that's exactly what I thought, thanks for confirming and providing pics.
I may just modify my ROW step to accept the standard hitch because mine's in perfect shape (still had the part number stickers on it when I installed). It would only be worth it to me if it was literally plug-n-play.
Old June 20th, 2012, 09:52 PM
Those little brackets are a quick job to make I'm telling you...a few minutes with an angle grinder with a cut blade, drill holes, paint. It ain't bad...and if you do plan to tow anything of substance it's nice to have the extra connection points (and 2" receiver). I tow my boat (not small), hydraulic dump trailer, car trailer with car, etc...
Old June 20th, 2012, 10:04 PM
Jackie Treehorn
A
1985 (legitimately)
Agreed, but unless it were local and I could avoid freight, it represents more time and money for something that needs fab work (albeit minimal) and probably some restoration.
One other nice thing about the ROW version is that it has high-lift jack points built in. I really am torn because I don't want to hack it up.
Old June 29th, 2012, 08:34 AM
UT-Rider's Avatar
UT-Rider
Sean
1997 D90
Still for sale.
Old June 29th, 2012, 09:01 AM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
These are getting harder and harder to find. You can get the look alike in the UK but they do not have the class 3 receiver hitch. They are easy to mod to fit just about any truck, I have them on both the ROW 90 and 110 Dc. Good luck with the sale.
Land Rover 110
Old July 1st, 2012, 11:50 AM
UT-Rider's Avatar
UT-Rider
Sean
1997 D90
Sold
bumper, rear step bumper
Used NAS rear step bumper rubber trim piece HeloBubba For Sale - Parts 6 April 11th, 2012 10:51 AM
OEM Rear Step Bumper for Defender rijosho The Flea Market 12 March 2nd, 2010 02:29 PM
Rear step bumper pad Defender13 For Sale - Parts 0 July 6th, 2006 12:18 PM
Discovery 1 Tubular rear bumper LiveAtTheEdge Defender Technical Discussions 0 March 23rd, 2004 02:03 PM
