Re perposed NiteRider lights and a new switch panel - Defender Source
Old May 11th, 2016, 11:32 PM
LenB's Avatar
LenB
Len Bruffett
NAS '97 ST /SW-POE Config
I had converted an old set of my dual beam NiteRider halogen mountain lights to use a worklamps on my truck. I sourced some high output LED bulbs that had the same form factor as the stock halogen bulbs. The bulbs consume only 2 watts of power to output the equivalent of 20 watts. They worked well so I hit up ebay to buy several more sets - I paid as little as $1.95 for a set and as much as $20 to get the lamps. Most of the time they came with chargers and nicad batteries . I am going to re purpose the batteries for a different project. I installed 1 light set in each corner of the rack and another serving a an aux "reverse" light.
I was looking for Ideas to control these lights - it is a given I was going to use old school toggle switches. I found some that were sealed - wire lead switches. Very clean design. Then I saw the latest James Bond movie "Spectre". The Austin Martin DB-10 shown in the movie was impressive. (even though in actuality there is no DB -10) But the prototype Toggle Switch Panel installed on the dashboard that controlled, automatic weapons, flame throwers and ejection seat was the real treat. I felt obligated to adapt the design to fit Defenders. My design features a 1" wide annodized aluminum bar, with 4 sealed, wire lead toggle switches that can be used to control any electrical accessories you have added on your truck. It is easy to install and comes with all the hardware. It will require you to drill 1 hole. (1/8" in diameter) up under the dash pad (into an internal steel suport structure imbeded in the dash). I am selling it for $50.00 . I attached pics of the re purposed bicycle light and the switch panel.
Name:	DB10 Prototype switch panel side view.jpg
ID:	149287   Click image for larger version
Name:	DB10 Prototype switch panel detail.jpg
Name:	DB10 Prototype switch panel front view.jpg
ID:	149289   Click image for larger version
Name:	DB10 Prototype switch panel installed.jpg
ID:	149291   Click image for larger version
Name:	DB10 Prototype switch panel movie1.jpg
ID:	149293   Click image for larger version
Name:	DB10 Prototype switch panel movie2.jpg
Old May 12th, 2016, 01:25 AM
Hardtimes's Avatar
Hardtimes
Russell Newhall
110dc, 110sw, 97 nas90 LE
I was secretly hoping to see KITTs lighting system I get my knights and nites mixed up apparently :/
Old May 12th, 2016, 01:28 AM
D90Overkill's Avatar
D90Overkill
David Frank
1995 ST #2615
That's why I clicked, too!
So tell me what's up with your "atmosphere" switch? Tony or Frank? ;-)
Old May 12th, 2016, 01:55 AM
LenB's Avatar
LenB
Len Bruffett
Originally Posted by D90Overkill View Post
That's why I clicked, too! Embarrassed ;-)
"Ramble On" - Led Zeppelin
Old May 12th, 2016, 02:15 AM
D90Overkill
David Frank
1995 ST #2615
Nice! ;-)
Good, clever stuff! GLWTS
ht, lights, switch
Rear Door Services Switch Panel - Lights Out brettm Defender Technical Discussions 2 January 25th, 2016 12:39 PM
Rear Door Services Switch Panel - Lights Out brettm Defender Technical Discussions 1 January 23rd, 2016 02:25 PM
gauge and lights panel diagram help please! kevincdoyle Defender Technical Discussions 2 April 13th, 2014 02:31 PM
Rear Defrost Switch, Rear Wiper Switch, and Rear Wipe/Wash Switch bradfordish For Sale - Parts 5 January 26th, 2014 12:30 PM
SW rear door Switch Panel and switches SafariHP The Vendors Loft 0 May 29th, 2008 10:39 AM
