R380 with bad 2nd synchro - Defender Source
Old February 24th, 2010, 01:36 PM
Having Frank (www.roverrepairs.com) replace my R380 in my Red D90, anyone want the old R380 transmission as a core? It is fine other than the worn second syncho. Condition of output splines is unknown. Factory NAS V8 R380. Miles unknown but I believe less than 100k because the D90 came with an LT77 from the factory and has about 120k on it now. Can ship direct to Roadsiderob aka southwestrovers for a rebuild.
Make an offer or to comply with listing rules I will take $500 and I will crate it.
Old February 24th, 2010, 01:45 PM
bjf's Avatar
bjf
barry f
94 ST #395
Who is roadsiderob?
Old February 24th, 2010, 02:15 PM
http://www.defendersource.com/forum/members/roadsiderob-623.html
Rob Dassler of Southwest Rovers. He rebuilds LR transmissions and T-cases.
Old February 24th, 2010, 03:55 PM
phoenix37's Avatar
phoenix37
john
Barry wants this. There is a spider in his 110s R380 that is making a funny noise and its driving him nuts so I think he needs this tranny.
Old February 24th, 2010, 04:08 PM
Ok BJF, pony up some cash to me and I will send it to rob and he will send you a perfect one.
Ron
*cue one part at a time*
Old February 24th, 2010, 04:14 PM
phoenix37's Avatar
phoenix37
john
out of curiousity whats it cost to have Rob rebuild?
Old February 24th, 2010, 04:15 PM
JPRO576's Avatar
JPRO576
blueboy
'96 Discovery Tdi
R380
Mr. Rob is hands down a master. I just sent out an R380 for my client and it's perfect. No issues. Came back to me looking brand new. Rebuild with new shift fork, oil pump etc. -- 1400.00. What a steal. Would recommend him to anyone.
JP
Old February 24th, 2010, 04:55 PM
specops1526's Avatar
specops1526
Beluga '97 90
I almost sent my G4 Disco to Rob for a pre-purchase inspection...wish I had, he would have told me it had a bad tcase and saved me a lot of $$$...
BTW, I've got a tcase from an '04 Disco with CDL if anyone is interested. I need it out of my garage...sorry for the hijack, Ron.
Originally Posted by rijosho
Beluga 97 D-90
Chawton 04 DII SE
Tangiers 04 DII G4
Old February 24th, 2010, 05:09 PM
bjf's Avatar
bjf
barry f
94 ST #395
So the tranny in my 110 is clunky. I wonder if it just needs an adjustment. Backlash maybe. I was looking at the receipt. The last owner put it in at 77,000 miles in 2002. I have 91,000 miles now. Would love to ask the shop to fix it under warranty. 8 years later but come on only 14000 miles.
ha
Old February 24th, 2010, 05:10 PM
clunky is probably NOT your transmission. More like a U-joint or front or rear diff or t-case.
Old February 24th, 2010, 05:12 PM
bjf's Avatar
bjf
barry f
94 ST #395
well my tcase is leaking.....
Old February 24th, 2010, 05:26 PM
JPRO576's Avatar
JPRO576
blueboy
'96 Discovery Tdi
clunk
On the clunk issue we just went through this. Is this on a 93 110. Even if the trans was replaced you need to pull out the input gear or (main shaft gear) and check for spline damage. On the early gears they were not cross drilled. So there was a lack of lubrication on the splines. The gears are avail. through your favorite LR parts guy. Part # you want is FTC5089. Let me know if you need pricing. And yes I can beat any dealer out there on it. My 2 cents.
JP
Old February 24th, 2010, 05:43 PM
bjf's Avatar
bjf
barry f
94 ST #395
so basically the tranny needs to come out?
Old February 24th, 2010, 05:56 PM
JPRO576's Avatar
JPRO576
blueboy
'96 Discovery Tdi
No! B- all you need to do is pull off the inspection or (pto) cover. You will be able to pull it out directly. Check the internals and you should know instantly. It was really only on the early cases. As long as there is no damage to the new trans splines you should be good to go with no clunking. Like New! It really freshens up those trucks. Let me know if I can help.
JP
Old February 24th, 2010, 06:15 PM
bjf's Avatar
bjf
barry f
94 ST #395
well I have a NAS 93 with a r380. Anyone have a picture of what I am supposed to open and how. Man if this is an easy fix I will be pumped.
------ Follow up post added February 24th, 2010 03:21 PM ------
http://www.ashcroft-transmissions.co.uk/part_28.html
I would assume since it is a 93 the new style would work.
Old February 24th, 2010, 07:01 PM
JPRO576's Avatar
JPRO576
blueboy
'96 Discovery Tdi
clunk
Barry PM sent. And yes the new style will work. Even better.
Old February 24th, 2010, 07:07 PM
clunks in 110's are also often the rear axle hubs.
Old February 24th, 2010, 07:47 PM
bjf's Avatar
bjf
barry f
94 ST #395
Doug
Would you get that clunk while shifting?
Old February 24th, 2010, 08:16 PM
Bad bushing or rear a-frame ball joint. Or a bad t-case.
Old February 24th, 2010, 08:47 PM
phoenix37's Avatar
phoenix37
john
Thats what mine used to do before i blew my tcase. Let me drive the 110 and Ill let you know if its the same thing i experienced.
r380
R380 synchro question mattm Defender Technical Discussions 2 January 26th, 2010 10:40 AM
Need Help For Bad Handling...(I mean BAD!) Cube II Defender Technical Discussions 18 July 7th, 2006 09:07 AM
R380 source opinions D90user Defender Technical Discussions 12 December 8th, 2005 12:22 PM
2nd grinding? Synchro? Burke Defender Technical Discussions 25 January 28th, 2005 04:09 PM
bad bad BAD noise rover4x4 Defender Technical Discussions 11 December 12th, 2003 12:44 AM
