R380 Needs to be rebuilt - Defender Source
Old September 16th, 2013, 11:55 AM
Mpigapicha's Avatar
Mpigapicha
phil
1995 Defender D90
R380- 5th gear & reverse went, so needs to be rebuilt. Has about 90K on it.
Located in Southern Dutchess County, NY.
Offers?
Old September 16th, 2013, 02:00 PM
CDeWan
Clay DeWan
5.3L beastie
R380
If they went at the same time chances are it is just the guide. Mine got stuck in 5th and I used high/low to drive it home. It is a little plate with a molded channel in it that can be removed externally. It looks like an upside down U and one of the U sides broke so it got stuck in 5th. Thank goodness SW rovers helped me out with the replacement part.
Old September 16th, 2013, 02:10 PM
Could also be a broken shaft. In either case, it is easy enough to fix and if the synchro hubs are ok and the main shaft is ok, a new set of synchros will make it like new.
Old September 17th, 2013, 09:45 AM
Mpigapicha's Avatar
Mpigapicha
phil
1995 Defender D90
They did go at same time. Was able to drive on 4th gear home thankfully. If easy fix, I may give it a run though if more than that its above my capabilities...... hate to junk it nevertheless.
So if its that plate, I can access it from outside?
Old September 17th, 2013, 01:43 PM
CDeWan
Clay DeWan
5.3L beastie
post
I belive you can as it is one of the shaft forks. The bad part is if it broke who know where it fell or if it got crunched up in the tranny. I had someone rebuild mine at that point as it needed to be pulled. If I had a diagrahm of the tranny casing I could tell you the part. I am sure someone on this board can point it out so you may want to post something in the Defender Technical section regarding this.
Old October 16th, 2013, 04:18 PM
Sold, and RURR on its was down, hoping for an easy fix
95' D90 - daily driver..
Old October 23rd, 2013, 11:04 AM
Keebler's Avatar
Keebler
Kenneth Elliott
1994 D90 AA yellow (NAS)
I would like to get my hands on an extra R380. Mine needs to be rebuilt. 3rd and 4th scream, 5th is oddly quiet though....
I'd like to get a down unit and rebuild it on the bench to minimize my down time.
-Ryan-
Old October 23rd, 2013, 05:08 PM
What kind do u need?
Mark Kellgren
KM4BOR
Old October 24th, 2013, 01:49 AM
Keebler's Avatar
Keebler
Kenneth Elliott
One for a NAS.
Ill run the S/N and findout which gear ratios.
-Ryan-
Old October 24th, 2013, 04:00 PM
serial number will help. V8 and TDI will have different length main shaft.
Mark Kellgren
KM4BOR
Old October 25th, 2013, 12:54 AM
Really? Do you mean the input shaft?
Present:
1960 SII 109"- "Red Square"
1984 90 Tdi- "Yamelo"
1988 RRC- "Chewbacca"
1987 RRC- "Chewy 2"
2008 RRS SC- "The Supersofa"
Past:
Old October 25th, 2013, 07:26 AM
uggh, yes. sorry. Dave Ashcroft explained to me that the variance between TDI and V8's is in the front input shaft. Point being, variant type would help. I have a spare 61A in need of a rebuild as an example.
Mark Kellgren
KM4BOR
r380
Rebuilt R380 16kpsi For Sale - Parts 13 August 11th, 2013 09:48 PM
Defender R380 Gear Boxes Rebuilt by the only Land Rover Builder SafariHP The Vendors Loft 3 July 31st, 2012 08:25 PM
UK rebuilt LT77 R380 FS SafariHP The Vendors Loft 0 June 11th, 2008 05:46 AM
R380 source opinions D90user Defender Technical Discussions 12 December 8th, 2005 12:22 PM
What do I need to know about rebuilt cylinder heads (non-LR) loykd Defender Technical Discussions 2 October 18th, 2004 10:36 PM
