Quick Release fire extinguisher mount - Page 6 - Defender Source
Old December 17th, 2012, 02:22 PM
Yes, interested at 3.25
Originally Posted by pendy
I'm here for the D's
Old December 17th, 2012, 02:29 PM
Cohbra11
1. o2batsea 3
2. HeloBubba 2
3. maleger 2
4. nathanwind 3-4
5. t42beal13t 1
6. lynchee 2
7. dave_lucas 1-2
8. rob37 1
9. Lrd90 1
10. ini88 1
11. curry 1
12. down_shift 1
13. Shep29 1
14. Rugbier 1
15. Bill Larson 4
16. k_kowboy 1
17. Birdman 1
18. D110DC 2
19. EStocks 1
20. Holiday 1
21. revtor 2
22. Hinckley423 1
23. Warner 2
24. nuclearmonkey 2
25. sirjond 1
26. rover4x4 1
27. 97XD 2
28. rrubino2 1
29. jayz 1
30. Jon D' 2
31. cgalpin 1
32. KSARover110 2
Old December 17th, 2012, 03:17 PM
Bill Larson's Avatar
Bill Larson
Bill Larson
still interested. that works for me.
Old December 17th, 2012, 08:21 PM
Cohbra11
Here's some 3.25" OD extinguishers I found online. Please note that I HAVE NOT PHYSICALLY VERIFIED THESE DIMENSIONS!!
However, the 3.25" OD dimension is listed along with the extinguisher on the websites that I found them on. I could have sworn that I had seen earlier today that the H3R brand had a 3.25" OD but they apparently do not.
Kidde FA110 - $27 - Coast Gaurd & DOT Approved
http://www.amazon.com/Kidde-FA110-Pu...e+extinguisher
Kidde 408-466141 2.5lb - $20
http://www.amazon.com/Kidde-Extingui...e+extinguisher
Kidde FX511 2lb - $27
http://www.amazon.com/NEW-Automobile...e+extinguisher
Proline Pro 2.6lb - $49
http://www.amazon.com/Kidde-ProLine-...e+extinguisher
Old December 17th, 2012, 10:14 PM
dave_lucas's Avatar
dave_lucas
Dave Lucas
I would rather have the most common size. Only makes sense to go with the most standard size.
Old December 19th, 2012, 04:04 PM
Cohbra11
I'm back in the garage today fabricating another clamp using all of the dimensions & specs from the new design so that I can validate it before pulling the trigger. We're getting very close here, but I'm still waiting on a final quote on the casting. I've talked to the foundry a few times in the last week and I'm comfortable enough now to say that the initial price will be about $55. I didn't quite get down to the $50 dollar mark that I know many were hoping for, but I'm sure you guys can understand and I wouldn't imagine that $5 more dollars would really make a difference in your decision to buy if you were serious about it in the first place. As I said before, I've only added a little bit into the cost for my time and labor to assemble & test the mounts, which doesn't add up to much.
It's taken a lot of work, and hours, to get to this point in the process, and considering the fact that I've basically done all of the design and planning on this project for free (since I am not trying to recover my investment thus far in the cost of the parts I sell) I hope you will continue to be patient in waiting for all of this to come to fruition.
Thanks again everyone,
Brian T.
Old December 19th, 2012, 05:36 PM
revtor's Avatar
revtor
Steve Maietta
1969 IIA 88" Bugeye
Brian, take your time and get it right the first time. If it ends up costing a lil bit more, so be it Make it a solid quality piece. We'll support that. Designed and made in the USA by the people for the people. Love it.
BTW, Im in for 1, not 2.
thanks
~Steve
Old December 21st, 2012, 10:00 AM
Cohbra11
1. o2batsea 3
2. HeloBubba 2
3. maleger 2
4. nathanwind 3-4
5. t42beal13t 1
6. lynchee 2
7. dave_lucas 1-2
8. rob37 1
9. Lrd90 1
10. ini88 1
11. curry 1
12. down_shift 1
13. Shep29 1
14. Rugbier 1
15. Bill Larson 4
16. k_kowboy 1
17. Birdman 1
18. D110DC 2
19. EStocks 1
20. Holiday 1
21. revtor 1
22. Hinckley423 1
23. Warner 2
24. nuclearmonkey 2
25. sirjond 1
26. rover4x4 1
27. 97XD 2
28. rrubino2 1
29. jayz 1
30. Jon D' 2
31. cgalpin 1
32. KSARover110 2
Old December 21st, 2012, 01:02 PM
Squaretyre's Avatar
Squaretyre
Landan
94 d90
If not to late and work with common size, I'd like to jump on the list for one as well.
Old December 22nd, 2012, 08:45 PM
Cohbra11
I've finished the new clamp based on the new design specifications which has a few tweaks to it. The main ones being that the clamp is now 1/4" thick with rounded ends on them making it much more durable than my initial prototype. Also, the base has a lower profile and a larger footprint to give it a more solid base when being bolted to a flat surface. Some of the other changes are very subtle and were simply to reduce the manufacturing costs as long as it didn't affect the durability or functionality of the mount.
I also visited with a spring manufacturer here in the Denver area yesterday and they were excited about helping us with designing a custom spring for the clamp. They recommended that I come down to their facility while they set up their machine to run a stainless steel spring specifically for this clamp. They want me to be there so we can tweak the parameters of the spring and test them in the clamp until we feel that we have the perfect spring for the application. I thought this was pretty cool of them, but unfortunately it will add a buck or two to the overall cost, but I think it will be worth it since the spring is the most critical piece of hardware in the clamp.
I also did some testing this evening to see how much force is required to extract the extinguisher from the clamp and found that this design requires ~29lbs of force, or ~6.5Gs. That is based on my extinguisher that I'm using which weighs about 4.5lbs. I don't have a scale that is accurate enough to get too specific, but this should give you a good idea of how well it holds onto the extinguisher. I'm hoping that we can improve on this even more with a custom spring.
Here's a couple of pics from the fabrication over the last few days as well as the finished part and another quick video of the operation. You can ignore the strap on the back of it, I just put it there to have something to hold onto when I pull the extinguisher out of the clamp.
Here's the video here:
1. o2batsea 3
2. HeloBubba 2
3. maleger 2
4. nathanwind 3-4
5. t42beal13t 1
6. lynchee 2
7. dave_lucas 1-2
8. rob37 1
9. Lrd90 1
10. ini88 1
11. curry 1
12. down_shift 1
13. Shep29 1
14. Rugbier 1
15. Bill Larson 4
16. k_kowboy 1
17. Birdman 1
18. D110DC 2
19. EStocks 1
20. Holiday 1
21. revtor 1
22. Hinckley423 1
23. Warner 2
24. nuclearmonkey 2
25. sirjond 1
26. rover4x4 1
27. 97XD 2
28. rrubino2 1
29. jayz 1
30. Jon D' 2
31. cgalpin 1
32. KSARover110 2
33. Squaretyre 1
Old December 22nd, 2012, 09:07 PM
Looking good. Upgrade me to 2 please Brian.
Old December 22nd, 2012, 09:31 PM
jlaudin
Jeff Laudin
2005 Freelander
Please add me for two. Jeff
Old December 22nd, 2012, 09:39 PM
The Dro
Dro
1988 Ninety
Count me in for 2. Pls.
Old December 22nd, 2012, 10:02 PM
SMac's Avatar
SMac
Sam
NAS 97 D90 SW
Lookin great! Count me in for one please.
Old December 22nd, 2012, 10:29 PM
Cohbra11
1. o2batsea 3
2. HeloBubba 2
3. maleger 2
4. nathanwind 3-4
5. t42beal13t 1
6. lynchee 2
7. dave_lucas 1-2
8. rob37 1
9. Lrd90 1
10. ini88 1
11. curry 1
12. down_shift 1
13. Shep29 1
14. Rugbier 1
15. Bill Larson 4
16. k_kowboy 1
17. Birdman 1
18. D110DC 2
19. EStocks 1
20. Holiday 1
21. revtor 1
22. Hinckley423 1
23. Warner 2
24. nuclearmonkey 2
25. sirjond 1
26. rover4x4 1
27. 97XD 2
28. rrubino2 1
29. jayz 1
30. Jon D' 2
31. cgalpin 2
32. KSARover110 2
33. Squaretyre 1
34. jlaudin 2
35. rrc.swb 2
36. SMac 1
Old December 23rd, 2012, 01:55 PM
triple9music's Avatar
triple9music
Chad Davis
1984 Defender 90
What's the price right now?
Old December 23rd, 2012, 01:59 PM
Cohbra11
We're looking at roughly $55 right now.
Old December 23rd, 2012, 02:21 PM
smob's Avatar
smob
Steve
'97 Arles Blue SW #2131
ZOMIGOD - how did I miss this thread? I'm in for 1, please, if it's not too late. Thanks.
-Ren Ching
Old December 23rd, 2012, 03:19 PM
CMSgt Bo's Avatar
CMSgt Bo
Bo
1985 One Ten
Sign me up for 2 please.
Proud member of the YCHJCYA2PDTHFH club.
My mechanic told me, "I couldn't repair your brakes, so I made your horn louder."
Old December 23rd, 2012, 03:32 PM
Please add me to the list
extinguisher, fire, mount, quick
Icon 4x4 Fire Extinguisher Reese_D90 Misc. Chit-Chat 19 July 25th, 2012 06:15 AM
Cool Quick Release Fire Extinguisher Bracket Wolf Fabrication Smaller Projects 1 December 19th, 2008 10:48 AM
Fire Extinguisher bjf Defender Technical Discussions 29 April 21st, 2008 06:41 PM
Fabritech Sway Bar Quick Release Kit For Disco Series 1 kpracer For Sale - Parts 0 July 22nd, 2004 01:50 AM
Recommendation on a Fire Extinguisher - size, type, mounting, etc. COSteve Defender Technical Discussions 16 April 16th, 2004 02:21 AM
