Quarter Panel Guards for 90s - Defender Source
Old May 1st, 2012, 05:24 PM
JSQ's Avatar
JSQ
Jack Quinlan
In response to demand voiced with the sale of the Quarter Panel Guards for 110s I have produced QPGs suitable for 90s.
In the past there have been satisfactory products of this kind but they are NLA and the current offerings are lacking in both craftsmanship and design. The QPGs for 90s are constructed with the same material, workmanship and finish as those I produce for 110s. They are compatible with all 90s both NAS and ROW with little to no modifications. The guards can be used in conjunction with the factory NAS rear step/hitch or the Receiver Hitch I produce.
$400 shipped in the lower 48.
https://lh5.googleusercontent.com/-s...0/IMG_4225.JPG
https://lh4.googleusercontent.com/-f...0/IMG_2881.JPG
Those who own 90s know just how easily damaged the quarter panels are. These soft aluminum body panels protrude over the departure angle of the trucks. Furthermore, damage to the quarter panels is difficult to repair in a manner consistent with factory construction. It is not uncommon to see an otherwise fairly clean 90 with damaged quarter panels. Some users fit unsightly chequerplate to try to reinforce the soft quarterpanels. Even then damage occurs.
https://lh4.googleusercontent.com/-H...06%2520178.jpg
Some solutions to this problem are so ugly and obtrusive that they are worse than chequerplate or a crumpled panel.
https://lh3.googleusercontent.com/-6...0/1sc00062.jpg
The QPGs for 90s, however, have been designed to minimize the potential for damage to the quarter panels without altering the vehicle in any unnecessary fashion and to be consistent with factory styling.
To this end the guards have a channel surrounding the quarter panel, which terminates in a squared-off bumperette at the rear corners and are supported by an angled brace mounted simply and securely to the rear crossmember.
https://lh3.googleusercontent.com/-M...0/IMG_4209.JPG
https://lh3.googleusercontent.com/-O...2/IMG_4198.JPG
https://lh5.googleusercontent.com/-V...0/IMG_4208.JPG
https://lh6.googleusercontent.com/-D...0/IMG_4214.JPG
The mounting brackets of the QPGs for 90s have been notched for the tub supports and exhaust hanger. Clearances are generous to accommodate the inconsistent hand-built dimensions of 90s. Similarly, the channels that surround the quarter panels are wide enough to allow for some previous damage.
https://lh3.googleusercontent.com/-3...0/IMG_2896.JPG
https://lh5.googleusercontent.com/-o...2/IMG_4200.JPG
https://lh3.googleusercontent.com/-y...0/IMG_4211.JPG
Unlike prior designs that were simply cut square or at a straight angle, the channel of the QPGs for 90s are radiused to better match the gentle curve of the wheel arch.
https://lh4.googleusercontent.com/-o...2/IMG_2902.JPG
https://lh4.googleusercontent.com/-q...0/IMG_4195.JPG
Because of their larger size the QPGs for 110s are made with the upper edges of the channel sloping slightly down to reduce their footprint on the truck. However, the short quarter panels on 90s allow this line to be perfectly horizontal and parallel to the sills or sliders. The resulting shape of the QPGs for 90s is very pleasing. Rather than standing out conspicuously, the guards almost seem to melt away.
https://lh3.googleusercontent.com/-T...0/IMG_4228.JPG
The QPGs for 90s are produced with great attention to detail.
https://lh3.googleusercontent.com/-9...0/IMG_2887.JPG
https://lh5.googleusercontent.com/-3...0/IMG_2895.JPG
The components are cut from a master plan on a plasma table for uniformity and then expertly welded before being powdercoated gloss black.
https://lh6.googleusercontent.com/-z...0/IMG_2891.JPG
Because of their greater size the channels on QPGs for 110s must be box constructed with more welding.
https://lh4.googleusercontent.com/_8...0/IMG_1743.JPG
The shorter length of the QPGs for 90s makes it possible to construct the channel by rolling the bottom edges in a press using a tool steel form specially constructed for that purpose. The result is both clean and strong.
https://lh6.googleusercontent.com/-H...0/IMG_2899.JPG
https://lh3.googleusercontent.com/-J...0/IMG_2900.JPG
https://lh4.googleusercontent.com/-N...0/IMG_4231.JPG
https://lh5.googleusercontent.com/-R...0/IMG_4232.JPG
All necessary hardware for mounting is provided. Two strips of adhesive felt are also provided should the user choose to install them on the outer edge of the guard channel to minimize any possible abrasion to the painted bodywork during installation or flex during offroad use.
https://lh4.googleusercontent.com/-T...0/IMG_2884.JPG
No guarantee is furnished that you will not be able to damage your vehicle with the guards installed. If you are determined to damage your vehicle and make every effort to do so I have the utmost confidence in your abilities.
If this describes your style you will be better served by a more drastic approach to the problem.
https://lh4.googleusercontent.com/-0.../s640/buck.jpg
For those who wish to add quarter panel protection with the absolute minimum of inconvenience or alteration to their vehicle, or even for those who wish to fit protection only during offroad use, the QPGs for 90s are the best evolution to date of designs of this type.
https://lh5.googleusercontent.com/-q...0/IMG_4220.JPG
Old May 1st, 2012, 07:22 PM
GaryBaxter's Avatar
GaryBaxter
Gary Baxter
Nice work; I'll take two sets. PM sent.
Old May 1st, 2012, 07:47 PM
JSQ's Avatar
JSQ
Jack Quinlan
Two sets to Gary.
Old May 1st, 2012, 09:04 PM
Finally, very nice.
Old May 2nd, 2012, 02:20 PM
JSQ's Avatar
JSQ
Jack Quinlan
Gary, your sets have shipped. PM me for tracking info if you like.
One set to Brent. Payment received.
Your set should ship tomorrow.
Old May 3rd, 2012, 01:50 AM
JSQ's Avatar
JSQ
Jack Quinlan
One set to Martin. Payment received.
Old May 3rd, 2012, 04:48 PM
D110DC's Avatar
D110DC
Pete
66 SIIA, 70 IIA, 97 D90
Interested in a set for both 90 and 110.
Pete
1966 ECR Series IIA
1970 Series IIA (Stella)
1997 D90 ST
2011 LR4 HSE
2010 Range Rover Supercharged
Sadly gone (some more sadly than others):
1983 D110 Double Cab 300 TDi
1989 RRC
1996 D1
2006 LR3
2008 RR
Old May 4th, 2012, 02:48 PM
JSQ's Avatar
JSQ
Jack Quinlan
One set to Pete.
Old May 5th, 2012, 11:47 AM
JSQ's Avatar
JSQ
Jack Quinlan
Payment received from Pete.
Your set should ship monday. PM me for UPS tracking info if you like.
Old May 7th, 2012, 02:18 AM
JSQ's Avatar
JSQ
Jack Quinlan
One set to Eric.
Old May 7th, 2012, 01:52 PM
JSQ's Avatar
JSQ
Jack Quinlan
Payment received from Eric.
Your set will ship today. PM me for UPS tracking info if you like.
Old May 8th, 2012, 11:06 PM
JSQ's Avatar
JSQ
Jack Quinlan
One set to Robert.
Old May 10th, 2012, 12:19 AM
JSQ's Avatar
JSQ
Jack Quinlan
Payment received from Robert.
Your set shipped today. PM me for UPS tracking info if you like.
Old May 11th, 2012, 03:14 PM
JSQ's Avatar
JSQ
Jack Quinlan
12 sets remaining.
Old May 23rd, 2012, 03:18 PM
JSQ's Avatar
JSQ
Jack Quinlan
11 sets remaining.
Old June 1st, 2012, 08:06 PM
JSQ's Avatar
JSQ
Jack Quinlan
Still available.
Old June 1st, 2012, 08:58 PM
Funtogun
Robert Lewis
1994 D90 ST
Received mine and they look great. Thanks for a great product. -Robert
Old June 4th, 2012, 02:42 AM
JSQ's Avatar
JSQ
Jack Quinlan
Robert, let's see some pics.
Old June 19th, 2012, 12:23 PM
JSQ's Avatar
JSQ
Jack Quinlan
Summer is here.
Protect your quarter panels or taste your own salty tears on the trail.
Old July 4th, 2012, 12:57 PM
Funtogun
Robert Lewis
1994 D90 ST
Pics of the guards installed. A little dirty an already banged up a bit...fully functional and a good piece of kit. Thanks
ID:	53850   Click image for larger version
90, guards
Quarter Panel Guards for 110 JSQ For Sale - Parts 71 July 12th, 2017 03:05 AM
Need right rear quarter panel 88 series anyone?? Arrington Wanted 2 July 4th, 2011 07:39 AM
TD5 90 Rear 1/4 panel guards, Best manufacturer/seller? DiscoDino Defender Technical Discussions 2 January 30th, 2006 01:31 PM
D-90 right side rear quarter panel needed ember Wanted 0 February 24th, 2005 08:47 PM
D90 Rear Quarter Panel leafsprung For Sale - Parts 4 November 25th, 2003 02:04 AM
