Quarter Panel Guards for 110 - Defender Source
Old April 10th, 2011, 03:25 AM
JSQ's Avatar
JSQ
Jack Quinlan
Because there is no satisfactory protection offered for their vulnerable quarter panels I have produced guards suitable for 110s. The guards are constructed with the same material, workmanship and finish as the receiver hitches. They are compatible with all 110s both NAS and ROW with modification to exhaust on some vehicles. The guards can be used in conjunction with the factory NAS rear step/hitch.
$500 shipped in the lower 48.
https://lh3.googleusercontent.com/_8...0/IMG_1736.JPG
https://lh4.googleusercontent.com/_8...0/IMG_1873.JPG
Those who own 110s know just how easily damaged the quarter panels are. These soft aluminum body panels protrude conspicuously over the departure angle of the trucks. Furthermore, damage to the quarter panels is difficult to repair in a manner consistent with factory construction because of the presence of unpainted pop rivets.
It is not uncommon to see an otherwise fairly clean 110 with damaged quarter panels.
https://lh3.googleusercontent.com/_8...nder110-12.jpg
The guards have been designed to minimize the potential for damage to the quarter panels without altering the vehicle in any unnecessary fashion and to be consistent with factory styling.
To this end the guards have a channel surrounding the quarter panel, which terminates in a squared-off bumperette at the rear corners and are supported by an angled brace at the junction and an outrigger to the frame.
https://lh4.googleusercontent.com/_8...0/IMG_1743.JPG
https://lh4.googleusercontent.com/_8...0/IMG_1746.JPG
https://lh4.googleusercontent.com/_8...0/IMG_1749.JPG
The passenger and driver side outriggers are symmetrical for strength and aesthetic purposes and therefore some exhaust/resonators may interfere. Many do not. If your vehicle exhaust conflicts with the outrigger simply reroute your exhaust. The factory hanger may still be utilized.
The guards bolt to the rear crossmember and the JATE ring mounting points on the frame.
https://lh3.googleusercontent.com/_8...0/IMG_1765.JPG
The channel is notched to accommodate the braces for the body panels and the driverside mounting bracket is cut out for the exhaust hanger.
https://lh3.googleusercontent.com/_8...0/IMG_1757.JPG
The channel is radiused to match the eyebrow.
https://lh3.googleusercontent.com/_8...0/IMG_1778.JPG
The upper edge of the channel is not parallel to the perfectly horizontal edges of the bodywork. To make the channels so would require that the guards be unnecessarily large and conspicuous. Instead the upper edge slopes subtly downward from the crossmember to the wheel arch giving the illusion of conformity while reducing the area of the guard.
https://lh4.googleusercontent.com/_8...0/IMG_1781.JPG
https://lh5.googleusercontent.com/_8...0/IMG_1728.JPG
The guards are produced with attention to detail.
https://lh3.googleusercontent.com/_8...0/IMG_1857.JPG
https://lh5.googleusercontent.com/_8...0/IMG_1860.JPG
Because of the handbuilt construction of 90s and 110s, vehicle dimensions are often inconsistent.
To allow for this, clearances on the guards for body and chassis are generous.
https://lh6.googleusercontent.com/_8...0/IMG_1865.JPG
https://lh6.googleusercontent.com/_8...0/IMG_1864.JPG
https://lh3.googleusercontent.com/_8...0/IMG_1869.JPG
All necessary hardware for mounting is provided.
Two strips of adhesive felt are also provided should the user choose to install them on the outer edge of the guard channel to minimize any possible abrasion to the painted bodywork during installation or flex during offroad use.
https://lh3.googleusercontent.com/_8...0/IMG_1872.JPG
The guards are sufficiently strong to lift the vehicle and should minimize damage to the quarter panels during offroad use.
https://lh4.googleusercontent.com/_8...0/IMG_1878.JPG
No guarantee is furnished that you will not be able to damage your vehicle with the guards installed. If you are determined to damage your vehicle and make every effort to do so I have the utmost confidence in your abilities.
If this describes your style you will be better served by a more drastic approach to the problem.
https://lh4.googleusercontent.com/_8.../s800/buck.jpg
For those who wish to add quarter panel protection without dramatically altering their vehicle, or even for those who wish to fit protection only during offroad use, these guards are an excellent solution.
https://lh4.googleusercontent.com/_8...0/IMG_1791.JPG
------ Follow up post added April 10th, 2011 12:29 AM ------
Two sets of guards are available for immediate shipment.
One set has already been furnished with adhesive felt lining the entire side of the inner channel along the body to minimize any possible abrasion to the painted bodywork during test fitment. It's a nice touch.
The first person to buy will get this set.
https://lh4.googleusercontent.com/_8...0/IMG_1887.JPG
Old April 10th, 2011, 09:22 AM
Roverdoc's Avatar
Roverdoc
Dan Kemper
1997 D90 SW #278
Very nice Jack
Old April 10th, 2011, 11:41 AM
JSQ's Avatar
JSQ
Jack Quinlan
1st set to Ron Peppard.
Old April 10th, 2011, 12:57 PM
lynchee's Avatar
lynchee
Dennis Lynch
94 D90 #699
Those are VERY nice. I was thinking about making some for my 90.
I like that they work with or without the NAS bumper.
Old April 10th, 2011, 01:04 PM
JSQ's Avatar
JSQ
Jack Quinlan
Thank you.
I will be producing guards for 90s, with a shorter channel radiused to match the eyebrow and no outrigger, in the near future.
Old April 10th, 2011, 05:08 PM
97-D90-736
Nick Vogel
1997 D-90 / 2012 LR4
I would like a set to, going to run your hitch and would like the corners to have a safe place to hide behind.
Old April 10th, 2011, 06:29 PM
ipgregory's Avatar
ipgregory
Ian Gregory
'97 D90 ST #1008
Its a great design. Bought mine used from Dale about 18 months ago. Not sure who originally made them. Mine have taken some pretty hard knocks and Dale said they got some abuse on his truck as well.
If you're going to make some then there is a tweak I would make to strengthen them even further based on my experience with them if you're interested?
Ian
Name:	D-90 rear corner guard.jpg
ID:	37793   Click image for larger version
Name:	D-90 rear corner guards a.jpg
Name:	D-90 rear corner guards b.jpg
ID:	37795   Click image for larger version
Old April 11th, 2011, 01:45 PM
JSQ's Avatar
JSQ
Jack Quinlan
2nd set to Richard Chang.
------ Follow up post added April 11th, 2011 12:06 PM ------
Payment received from Richard.
Your guards will ship tomorrow. Email me for UPS tracking info if you like.
Awaiting payment from Ron.
Old April 12th, 2011, 11:15 AM
JSQ's Avatar
JSQ
Jack Quinlan
1st set available.
Buyer was all email and no paypal.
Old April 13th, 2011, 12:39 AM
JSQ's Avatar
JSQ
Jack Quinlan
1st set to Kevin Didion.
Kevin, your guards will ship tomorrow. Email me for UPS tracking info if you like.
Old April 14th, 2011, 01:36 AM
JSQ's Avatar
JSQ
Jack Quinlan
If anyone else would like a set, just let me know and I will put you down for the next batch which will be produced shortly.
Old October 25th, 2011, 08:26 PM
JSQ's Avatar
JSQ
Jack Quinlan
One set to Collin.
Old October 26th, 2011, 11:00 PM
JSQ's Avatar
JSQ
Jack Quinlan
One set to John.
Old October 27th, 2011, 02:57 PM
JSQ's Avatar
JSQ
Jack Quinlan
One set to Eric.
Old October 27th, 2011, 05:20 PM
AmityD90's Avatar
AmityD90
Gery
1987 ROW D90
Thank you.
pm sent with some questions
Old November 26th, 2011, 02:58 PM
Jack:
Sent you an email about a week and a half ago, do you have a set of these left?
Old November 28th, 2011, 06:32 PM
JSQ's Avatar
JSQ
Jack Quinlan
Jack:
There will be two sets available after the other three ship. They are being powdercoated right now.
Old November 29th, 2011, 05:00 AM
Ray Bone's Avatar
Ray Bone
Ray Bone
defender.
One for me as well
Old November 30th, 2011, 01:15 PM
JSQ's Avatar
JSQ
Jack Quinlan
One set to Ray.
Old November 30th, 2011, 07:40 PM
JSQ's Avatar
JSQ
Jack Quinlan
All five sets are boxed. The three previous orders will ship tomorrow.
One set to Ray pending payment.
One set available.
110, guards
NEW Quarter Panel, Viscus Drive Unit hank17 For Sale - Parts 1 August 7th, 2008 05:17 PM
Front Door/Rear Quarter Panel Alignment Grover Defender Technical Discussions 12 August 7th, 2008 07:22 AM
TD5 90 Rear 1/4 panel guards, Best manufacturer/seller? DiscoDino Defender Technical Discussions 2 January 30th, 2006 01:31 PM
D-90 right side rear quarter panel needed ember Wanted 0 February 24th, 2005 08:47 PM
D90 Rear Quarter Panel leafsprung For Sale - Parts 4 November 25th, 2003 02:04 AM
