Puma fiberglass lightweight racing hood NEW - Defender Source
Old May 22nd, 2016, 10:42 AM
Vieques Rovers's Avatar
Vieques Rovers
Vieques Speed Shop
1986 110
I have one left! I had 5 of them last month. Sold 3, keeping one.
This is a puma style hood, with no heavy inner liner, the one that interfered on NAS trucks. This is a well made bonnet, in white gelcoat. Simply drill hinge holes and use 3M panel bond for a factory hood pin, or go with custom fasteners.
Ships Fedex LTL or pick it in person.
No air gaps, voids, or chips. Construction is top quality. Look at the tight fit on this NAS truck.
$350. Plus shipping.
Old May 22nd, 2016, 01:07 PM
D90Overkill's Avatar
D90Overkill
David Frank
1995 ST #2615
Ships from where? Lots of stops along N. Lat. 18! ;-)
Old May 22nd, 2016, 01:31 PM
Vieques Rovers
Vieques Speed Shop
1986 110
Sorry! The hood is at 30075, at north Georgia auto detail shop.
Not affiliated with any local shops in Atlanta.
Most that I've shipped have cost 140-170.
If you are feeling adventurous, come on down to latitude 18- I've got one waiting at the shop in Vieques.
Old May 26th, 2016, 09:59 AM
TELOS's Avatar
TELOS
Nate
LHD 110 SW - 300Tdi
I recently received one of these hoods. It arrived very quickly (since it was coming from Georgia and not Vieques!!) and fits really well. It has been a pleasure working with Fango.
Old May 31st, 2016, 05:11 PM
Jgerrard
Jeff Gerrard
1997 Defender 90
Is it steel reinforced?
Old May 31st, 2016, 05:15 PM
TELOS's Avatar
TELOS
Nate
LHD 110 SW - 300Tdi
The hood is not steel reinforced as far as I can tell. It might not need any additional reinforcement as it feels very solid, but I am fabricating an internal steel frame nonetheless... to add a little extra strength and give the latch pin and hood prop attachment points.
Old May 31st, 2016, 05:32 PM
rednas90
I'll take the hood. How do you need paid?
Sent from my SAMSUNG-SM-N920A using Tapatalk
Old May 31st, 2016, 10:54 PM
Vieques Rovers
Vieques Speed Shop
1986 110
Hood options
The lightweight hood requires no steel. You can add an aluminum strip at the front lip with thread or for pin, Saftey catch, and rubber buffer mounts with epoxy or 3m panel bond. They now make single tube panel bond so you don't need special applicators other than a caulk gun.
The regular hood version is a two piece, outer shell and inner liner. The pricier hoods have an inner liner for factory looks and mounting can done with threadcerts.
Old June 3rd, 2016, 12:42 PM
Vieques Rovers
Vieques Speed Shop
1986 110
I still have the hood, with about 4 Houdinis (not following through).
I also have a vented hood, the lightweight version for sale. It has a Evercoat fiberglass primer over the white gel coat. Customer traded it in for a Puma hood.
Shipping in the USA is $159. unless you know another way.
Old June 3rd, 2016, 01:27 PM
Vieques Rovers
Vieques Speed Shop
1986 110
fiberglass PUMA stlye with hood scoop. LIGHTWEIGHT
This is the lightweight version I have for sale. This does not require reinforcement or any metal subframe. You can transfer your hinges and figure out the hood pin and safety latch with epoxy or by glassing in an aluminum support. I have to call it "used" since it was primed over the factory white gel coat.
$345 plus shipping.
Old June 3rd, 2016, 01:50 PM
defender1844
Amit Likhyani
can you post pics of the vented hood? Is it a scoop or flush mounted louvers? If it's the latter, where exactly are the louvers?
Old June 3rd, 2016, 02:49 PM
D90Overkill
David Frank
1995 ST #2615
Kind of fun for ~ $500 shipped. Maybe for Jwillia's LSA? ;-)
ac, fiber, fiberglass, glass, hood, ht
Land Rover Defender Puma Hood / Bonnet NEW Genuine DefenderPilot For Sale - Parts 10 May 3rd, 2016 04:37 PM
bonnet/hood prop solution for aftermarket puma hood? ITALY2AMERICA Defender Technical Discussions 4 March 30th, 2016 07:52 AM
WTD Puma Hood - Not Fiberglass - RN RURR rdavisinva Wanted 6 November 20th, 2014 09:11 PM
New in package hood/bonnet emblem set for your Puma clone! (or Disco II ) - For Sale HeloBubba For Sale - Parts 8 May 2nd, 2013 11:16 PM
Puma Hood and Hood support CDeWan Defender Technical Discussions 1 June 9th, 2011 11:51 AM
