Psyoptic Development Defender 90 XD Sliders - Defender Source
Old May 5th, 2016, 02:21 PM
madcowdungbeetle
Carter
This is my last set I'll be doing for a while. In usual work-a-holic fashion I've got too many projects going on and not enough time, and I need to invest in my future in the fabrication world.
This particular set is special because it is the first set I've done with grip tape on the surface.
For those who aren't in the know: These are the toughest rock sliders you will ever find for your Defender, and 110% made in the USA. These are designed to handle the toughest off-road conditions, and will soundly demolish any car door that dares open too far in the mall parking lot. They double as a side-step and serve as a great platform for reaching your roof rack, or taking the top on or off of your D90 Soft top.
The sliders are 100% constructed from laser cut and CNC formed 0.250" thick steel plate. Most of the other sliders currently on the market are 1.5 - 2mm or ~0.079" thick. In other words my sliders are 3X thicker, and substantially stronger. They are also the ONLY Defender rock slider to my knowledge to feature a true boat-sided design as well as 3 solid frame mounting points per side. These will fit any Defender 90 with a rear mounted gas tank.
These are NOT cheap, thin-wall, thin-tubed, mall crawler, poser-spec, import garbage steel rock sliders like so many of the offerings currently on the market.
$1000 + shipping
Some previous info/reviews:
http://www.defendersource.com/forum/...der-59600.html
ID:	148872   Click image for larger version
Old May 5th, 2016, 07:05 PM
JiriPilot
Jiri Marousek
1986
sliders
re those for a right or left side tank? I have a RHD '86 90, so just curious. saw in the other thread there was some discussion on tank location. Thanks.
Old May 5th, 2016, 07:22 PM
madcowdungbeetle
Carter
This set is intended for 90's with a rear-mounted fuel tank.
Old May 5th, 2016, 09:23 PM
User Name
User
NAS D90 '95
I'll give you $200 total. You pay for shipping too!
Old May 5th, 2016, 10:07 PM
madcowdungbeetle
Carter
I think I'll pass... but thanks for the offer.
Old May 5th, 2016, 10:35 PM
Nos4ra2's Avatar
Nos4ra2
Nos4ra2
1995 NAS D90 #2489
looking forward to seeing your new products, but my wallet is cringing.
good luck.
Old May 6th, 2016, 01:41 AM
D90Overkill's Avatar
D90Overkill
David Frank
1995 ST #2615
I think I paid $200 just for shipping alone. And I'm still still stoked about these! Trailhead lines, new tyres, everything that tiktaalik made, and pdxd's were the best upgrades I've done to date.
Old May 6th, 2016, 01:59 AM
Avahdani's Avatar
Avahdani
Nushi
NONE
They are sweet.
Old May 6th, 2016, 05:57 AM
BlackField's Avatar
BlackField
Oscar
D110
110 version coming soon?
Old May 6th, 2016, 11:21 AM
madcowdungbeetle
Carter
Yes and No. Yes I can make them, and have made them, I'm just not sure the market is there to make them worth my time, on anything other that a 1 off custom route.... and that is $$$
Old May 6th, 2016, 11:27 AM
slorocco
Dan Prasada-Rao
1963, 109 Station Wagon
So, I'm assuming these use existing mounting points on the chassis even for the mid mount position. Looks like it uses the crossmember mounting holes. Is that correct?
Also just curious, will a standard Hi-lift still work on these or are they wider than the lifting jaw on a hi-lift?
Thanks man. These are really tempting but not sure I can spare the $$$ at the moment.
Old May 6th, 2016, 12:22 PM
madcowdungbeetle
Carter
...and like that these are SOLD and headed to Indiana!
Old May 6th, 2016, 12:52 PM
slorocco
Dan Prasada-Rao
Cool, glad they sold quick for you. Later.
Old May 6th, 2016, 12:59 PM
madcowdungbeetle
Carter
You're absolutely correct on the mounting.
As far as a hi-lift goes, I would use one of the jaw adapters that is wider, and more encompassing, purely for safety/stability. Those things are already dangerous enough as it is. I remember a while back when a guy at an event caught a handle in the face. It was not a good scene.
Old May 6th, 2016, 01:27 PM
slorocco
Dan Prasada-Rao
Thanks for the answers on the questions man. These are about the best sliders I've seen. They also look like a lot of work to produce.
Old May 6th, 2016, 05:29 PM
I've had mine for 3-4 years and they are bullet-proof.
They are hands down the best slides ever conceived.
90, defender, defender 90, slide
Psyoptic Development XD Rock Sliders pre-order madcowdungbeetle For Sale - Parts 15 May 4th, 2015 11:06 PM
Psyoptic Development XD Rock Sliders for D90 madcowdungbeetle For Sale - Parts 24 January 30th, 2015 12:56 PM
Psyoptic Development sliders woldd90 Smaller Projects 11 March 10th, 2010 07:13 PM
new Mud UK product in development Overlander Misc. Chit-Chat 2 February 26th, 2008 12:37 PM
