Proper 1988 Defender petrol V8 engine, runs great& complete. removed for turbo-diesel - Defender Source
Old April 1st, 2013, 12:17 PM
ZombieMotors
Zak Mosieur
1987 Defender 110/300tdi
As the ad says, I have a fine-running-with-zero-issues 1988 3.5L V8 gasoline engine here for sale that is being sold complete with carbs, exhaust, air cleaners, all ancillaries, everything to stick this in your Defender, Range Rover, Series Hybrid, etc and go. This is still in the truck as I type this, if you want to come and see it run before it is pulled, but it is coming out in the next couple of days and will be ready to ship by Friday (if need be). The fine-shifting (but getting noisy in all gears but fourth ) LT85 gearbox may be for sale as well with its transfer case, also complete. Clock shows just over 130K miles, and engine always starts right up, and after warming up for a few minutes (is cold-blooded!) runs like a top. No smoke, drips or funny ticking or knocking sounds, I would throw some seals in it while it was out and then drop it right back into its new home and use it as-is.
I'd like $1800obo for the engine with all its parts, and $1000 for the LT85.
Give me a call or email with any questions, thanks 503-505-7113 , zombiemotors@earthlink.net
This truck has also been fitted with a complete LPG system that runs off of a tank in the back, I will also be removing this system and putting it up for sale if someone wants to run off of LPG or propane, everything is here to switch from gas to the LPG tank with a flick of the switch on the dash, making your truck multi-fuel. Pretty slick, $1000 for this complete kit.
defender, diesel, engine, v8
V8 Engine Oil - Synthetic vs Semi Synthetic nickt Defender Technical Discussions 68 September 18th, 2016 09:38 AM
Engine Swap: which one? 200tdi, 300tdi, or something I dont even know about gonzanc Defender Technical Discussions 46 April 2nd, 2013 09:36 PM
Defender 200 TDI engine for sale k4rovers For Sale - Parts 1 January 22nd, 2007 06:00 PM
Diesel Defender Nil Wanted 1 August 14th, 2005 11:58 AM
Take out V8 engine and trans--complete evilfij Wanted 9 June 17th, 2004 06:00 PM
