On Board Air - Defender Source
Old April 20th, 2006, 10:15 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
On Board Air
This is for those people running v-belt set ups, so mainly the 94 crowd, that do not have air conditioning. A couple of my friends have been bugging me to make them my On Board Air setup that uses the York 210 Air compressor off the engine--it will run air tools and fill up tires, and do it better than most set ups out there. There is that Oasis electric air compressor that runs the same pump off a winch motor, to give you all reference. All those that went to the solihul rally last year probably saw me using it replacing axles, inflating tires, ect. It is a good set up. Anyways, I have enough parts to make 4 and 2 are already taken. If anyone is interested, I will make 2 more at the same price, $300/each which will include the bracket to mount it to the engine, the compressor (they are used, but I tested them and they work great--I do have one that is new) and any/all advice to hook them up to work fine. If you live here in Colorado, you can play all you want with mine. I can give advice and websites to get more info about plumbing, but a simple search of onboard air will get you plenty. Given the cost of the compressor and the time to make the bracket, I am obviously not doing this to make money. If you can't pick it up, I will ship it--they are rather heavy, so that will be about $20 but I will only charge actual freight. If you are interested, let me know--I have been running mine for about 2 years. FYI--they fill my 255/84/16 33" tires from 14 to 30 in under a minute. Also, the compressor will have a clutch. That is about it--drop me a line if you are interested.
Old April 20th, 2006, 10:22 PM
efournier
Eric
'95 D-90 ST
email sent
Old April 22nd, 2006, 12:36 PM
Pat's Avatar
Pat
Patrick M.
D90 '96 300Tdi 5 speed
Hi
I understand those compressors are lubricated with some special oil that goes with the coolant gas when they are used in AC apps.
How is the compressor lubricated in your app?
Pat
Old April 22nd, 2006, 12:55 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
They (the York) uses engine oil and have a resevoir. You have to check it every now and then to make sure it still has some, but it does not burn through it very quickly. There is a vast amount of info, but this page has some good ones--check out:
http://www.jedi.com/obiwan/jeep/york_lube.html
What you are refering to is the Sanden style compressors that use the Freon as part of their lube-loop. No worries with the York.
Old April 24th, 2006, 11:36 PM
Pat's Avatar
Pat
Patrick M.
Thanks David, I understood now
Pat
In line blower for mantec raised air intake system LenB Smaller Projects 22 November 20th, 2009 08:24 PM
On board air tank needsaD110 Smaller Projects 4 September 16th, 2009 02:56 PM
CO2, ARB on board air! TwisteD90 For Sale - Parts 4 June 16th, 2004 11:43 PM
On board air compressor Davis Defender Technical Discussions 5 March 7th, 2004 08:28 PM
On Board Air javelinadave Misc. Chit-Chat 13 December 2nd, 2003 12:41 PM
