Oil cooler hoses - Defender Source
Old December 6th, 2004, 09:31 PM
rvrsrvc
Trevor Griffiths
71 109 double cab
Oil cooler hoses
I've had two Defender V8 with oil cooler hose failures come through the shop this year, and currently have 3 with marginal looking hoses. I've been working with a Rover guy (Bill Bettridge) who specialises in industrial plumbing. He has located adaptors that fit directly into the oil cooler adaptor at the oil filter housing, and have fabricated fittings using the original pipe into the oil cooler at the radiator. The hose is a single wire convoluted style that is rated in excess of anything we can throw at them for both temp and pressure. Finally, we wrapped them in a silicone fire sleeve for more heat protection.
So far, these hoses have fit D90's with or with out a/c, v-belt accessory drives and the V8. I plan on adding the 97 serp belt Rovers to the list, as soon as one comes in or Trevor Combs lets me borrow his Defender for a night!
Is this something that others might be interested in?
Trevor Griffiths
Old December 6th, 2004, 09:40 PM
Eric Siepmann
Eric W. Siepmann
1997 Defender 90 SW
Yes.
EwS
Old December 6th, 2004, 09:44 PM
rvrsrvc
Trevor Griffiths
71 109 double cab
Eric,
I'll post pix tomorrow showing materials, layout and fitted.
Trevor
Old December 6th, 2004, 09:48 PM
damn I should pay more attention to reading oopps. I am interested..
Old December 6th, 2004, 09:59 PM
sheki's Avatar
sheki
David Shechter
97' D90 SW 2.8L diesel
After hearing Doug Walker's story about losing his 110, who wouldn't replace their hoses. How much?
Old December 6th, 2004, 10:17 PM
sherpamike's Avatar
sherpamike
Mike Doligalski
'95 D90 ST
I am very interested
Old December 6th, 2004, 10:58 PM
loykd's Avatar
loykd
Ken Loy
1994 Portofino Red ST
I'm interested
Old December 6th, 2004, 11:09 PM
jorge's Avatar
jorge
JORGE ESPINOZA
97 ST WHITE MODS SUPERCHARGED
Trevor count me in.
Old December 6th, 2004, 11:16 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
How much, and where do I send the check?
My oil line fix
My 100k stopped odometer fix
Old December 7th, 2004, 12:10 AM
thelandroverguy's Avatar
thelandroverguy
Vince
1997 D-90 ST
Count me in........
Old December 7th, 2004, 12:31 AM
Joe P's Avatar
Joe P
Joe Pfeiffer
Black 97 D-90ST #0605
I'm in
If the truck makes it - the trail wasn't tough enough.
If the truck doesn't make it - the truck wasn't tough enough.
Old December 7th, 2004, 01:04 AM
D90user's Avatar
D90user
steve
109/110 ambulance-55 series I
I'm interested, add another.
Steve
Old December 7th, 2004, 01:14 AM
excanuk's Avatar
excanuk
Nigel Rigby
94 D90
I'm in too....
Old December 7th, 2004, 08:17 AM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
Trevor, thanks for all the good work. Please count me in as well.
Clay
Old December 7th, 2004, 09:07 AM
artm
Arthur Maravelis
97 SW
Me too..maybe two.
Old December 7th, 2004, 09:54 AM
rvrsrvc
Trevor Griffiths
71 109 double cab
Wow!
Okay, here's what I have so far: I have made 2 sets that we have/are about to fit to v-belt V8s with and without a/c. (I will start on developing serp belts asap.) The biggest hang-up to this plan is that the end that fits into the radiator is fabbed up using original oil cooler hoses. We cut the ends and weld on on JIC fitting. I have some here to get started, but I'll need more! Even the Discovery oil cooler hoses will work if anybody has any discarded pieces to sacrifice. I would like to get a bunch of the pieces fabbed at one time so that turn around is quicker.
What to charge? I'm not looking to retire off of this stuff! I'm fairly certain I can keep the price under $195 a pair, as long as I have enough usable ends. If I have to buy new hoses just to cut up, it pushes the price up, and I would like to avoid that!
I was going to attach photos but the files are too large. I will retake the photos and send again later.
Old December 7th, 2004, 09:59 AM
chrisvonc's Avatar
chrisvonc
Chris von C
No Defender at this time
Or zip them up and send them over to me Trevor. I can resize them and post them for you.
Chris von C
[/size]
Old December 7th, 2004, 11:16 AM
4WD-90's Avatar
4WD-90
Christopher Stanish
1994 defender 90
Thumbs up
Sounds like some cheap insurance, count me in!
Old December 7th, 2004, 11:56 AM
artm
Arthur Maravelis
97 SW
Originally Posted by rvrsrvc
...the end that fits into the radiator is fabbed up using original oil cooler hoses. We cut the ends and weld on on JIC fitting.
I don't know but isn't this the wrong way to go? I thought the point was to replace the entire assembly with something better not splice into the existing setup.
What is the fitting at the radiator? Why not have one custom fabbed, if need be, and do the same at the other end? Replace the hose with something better and there you have it.
Heck, I would think there's a few thousand orders out there waiting to be filled with a correct replacement.
Old December 7th, 2004, 12:12 PM
Hans's Avatar
Hans
Hans Haase
How about having a "Core Charge" type deal going on, to help get some hoses back. I have no problem sending you mine when I do the swap, I just have to have something to put in there so that I can drive the thing. Or maybe give a ring over to carcannibal.com which is a rovers only wrecking yard.
Art. The steel portions of the lines aren't an issue at all, it's the rubber flex section that goes bad and blows out. As long as that weak point is upgraded, there shouldn't be any problems using the upper steel section of the lines.
-Hans
My oil line fix
newish oil cooler hoses milli Defender Technical Discussions 0 February 24th, 2006 12:13 PM
Brand New Genuine Oil Cooler Hoses Billakris For Sale - Parts 10 November 30th, 2005 10:45 PM
Erm... oil cooler hoses oldscratchggf Defender Technical Discussions 2 September 5th, 2005 03:44 AM
FOR SALE - Set of Used Oil Cooler hoses / window studs eric_besore For Sale - Parts 10 August 31st, 2005 02:18 AM
