Oil cooler hoses - Page 2 - Defender Source
Old December 7th, 2004, 04:31 PM
rvrsrvc
Trevor Griffiths
71 109 double cab
Hans answered the question! We are only using a few inches of the old pipe, and none of the rubber. For radiators that do not have adaptors screwed into the radiator, there are direct fittings that are pipe thread that will fit directly, but so far the 3 in the shop right now all have adaptors!
There are a number of permetations on this Rover design, so we are trying to make them as common as possible.
Old December 7th, 2004, 04:48 PM
Kimos's Avatar
Kimos
Larry O'Hara
1997 Defender Wagon
Sounds good!
Old December 7th, 2004, 08:09 PM
paulb's Avatar
paulb
Paul / Boultbee
1994 D-90, Green #1576
Sounds good.
What's the price?
Old December 8th, 2004, 11:15 AM
pendy's Avatar
pendy
jim pendleton
89'd90
I have been repairing oil cooler lines like this for a while now. It is a good method. The trick is to cut the hose the correct length. I use odiker clamps and make sure the hose is a very tight fit. Also, test fit and start the hose in situ so the angles are correct.
It might be easier to supply the lines with barbs installed and supply bulk hose to be cut on installation.
JP
legend in my own mind
Old December 8th, 2004, 04:35 PM
rvrsrvc
Trevor Griffiths
71 109 double cab
I'll readily admit that these are probably overkill as far as materials. The assemblies are all crimped and the hose is designed for use in machinery that runs 24/7 repetitive motion.
Old December 8th, 2004, 11:42 PM
jvelador's Avatar
jvelador
Javier Velador
'95 D90 / '66 IIA
Would these be able to withstand heat better than stock? how about compared to stainless steel braided hoses? Just curious because I had mine replaced on my Disco with SS braided hoses hoping to acomplish this.
Javier
Old December 9th, 2004, 02:32 PM
newfD90's Avatar
newfD90
Chance
93 NAS 110
I'm interested in the '97 hoses when available.
Chance
Old December 9th, 2004, 03:20 PM
rvrsrvc
Trevor Griffiths
71 109 double cab
The silicone fire sleeve would protect the hose from the radiant heat from the exhaust probably better than the stainless due to the insulating layer between the inner and outer diameters of the fire sleeve. The stainless stuff like Earl's and Aeroquip is good, but I believe it costs a little more.
We 've modified our original design to better accomodate the hose routing for ac and non a/c v-belt v8s as well as increase the inside diameter of the hose itself.
We've also come up with a different combination of fittings that will make the serpentine belt replacements easier to fabricate.
Thanks to everybody who has expressed an interest in this project. We will keep going to get it just right much sooner than later!
I've tried to zip the pix and send them to Chris, but that was returned.
Old December 9th, 2004, 03:34 PM
Trevor send them to telsa@rocketmail.com they will come through my e-mail as long as the files are under 10 meg total.
Old December 15th, 2004, 11:33 AM
rvrsrvc
Trevor Griffiths
71 109 double cab
Update: I've changed the configuration again and am awaiting the latest version. I have also submitted the serp belt design to Bill for layout. Not going to fill any Christmas stockings, but soon!
Old January 18th, 2005, 05:25 PM
Abrooks's Avatar
Abrooks
Tony Brooks
Hey Trevor! Any word on these?
Tony
Old January 19th, 2005, 10:13 AM
rvrsrvc
Trevor Griffiths
71 109 double cab
Actually, yes. I think I had mentioned before that an expected baby was going to interrupt all of the delicate plans for life that I had layed out, and sure enough, they did! Max Edward was born on Christmas Day, and both he and Andrea are doing great!
After several versions and trial fits, we settled on a design for the v-belt engines. The v-belt version is fitted and has been test driven some distance. I was trying to get Trevor Comb's D in to test fit the serp belt version, as we haven't had any 97s in the shop lately.
I am still interested in donor hoses to have a supply in the works. This should theoretically cut down the production time. I have 2 sets for serp belt, so my real immediate need is v-belt.
Pricing: Well, if I don't have to buy new hoses to cut up and fabricate, I should be able to offer a pair of hoses for about $215. I may just buy a set or two just get things rolling- I can't envision not recouping my "investment" just on employees Rovers!
Old January 19th, 2005, 10:34 AM
Congrats on the Baby! I have the hoses from my old 3.9 if they are needed.
Old January 19th, 2005, 11:38 AM
mhansen's Avatar
mhansen
Mike Hansen
97 D-90 SW #2243
Atlantic British $62.95 Lower and $79.95 Upper for a '97
Did mine the weekend before last .
Don't put it off!!!!!!.......Mine were leaking at the fittings to the radiator, and the rubber was really soft.
I also replaced the power steering lines. The mechanical coupleing between the hose and the hard pipe was so loose that you could spin the hose holding onto the pipe with NO effort.
So while you are in there replace the power steering lines too.
My garage floor hasn't seen a drop for oil for a week now.
Cheers
--Benjamin Franklin
Old January 19th, 2005, 12:58 PM
Doug's Avatar
Doug
Doug Walker
TVR5L-powered NAS D-110
Wow, a WHOLE week? Damn, that's sweet.
Doug W.
Old January 19th, 2005, 02:22 PM
I am interested in the oil cooler hoses (and clean garage floor) pending pics and pricing.
Trevor, i need similar attention to my auto tranny lines (conversion on a '94). canb you recdomend anyone closer to me who makes these kinds of hoses? I am in chantilly, VA.
thanks
charles
Old January 19th, 2005, 09:27 PM
Abrooks's Avatar
Abrooks
Tony Brooks
Trevor, Massive Congratulations!! Sign me up for a set -- I can provide the fittings for an '88 rrc if that's of any help at all. My best to Max, Andra and yourself.
Tony
Old January 20th, 2005, 08:40 AM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
Congrats Trevor, good to hear M and M are both doing well. Sign me up as well for three sets (all 94's). I've got a couple of buddies here in the DC area that I'm looking out for as well.
Clay
Old January 24th, 2005, 10:44 AM
wcampbel@nas.edu's Avatar
wcampbel@nas.edu
Bill Campbell
1994 D-90 ST
Ya I cooked off my lines and had a nice little fire in the engine bay thanks to those cooler lines. Probably can count me in even though mine are brand new. Just depends on price.
Old January 24th, 2005, 11:41 AM
EnduroPro's Avatar
EnduroPro
Stephen LeBlanc
1994 Defender 90
Count me in too please....how much?
newish oil cooler hoses milli Defender Technical Discussions 0 February 24th, 2006 12:13 PM
Brand New Genuine Oil Cooler Hoses Billakris For Sale - Parts 10 November 30th, 2005 10:45 PM
Erm... oil cooler hoses oldscratchggf Defender Technical Discussions 2 September 5th, 2005 03:44 AM
FOR SALE - Set of Used Oil Cooler hoses / window studs eric_besore For Sale - Parts 10 August 31st, 2005 02:18 AM
