NY: 300Tdi Frame FS - Defender Source
Old May 23rd, 2006, 02:28 PM
Lyman
Lyman Saltsman
1987 Rokon Ranger
NY: 300Tdi Frame FS
Solid genuine bare d90 frame. Frame bent from front impact just behind bulkhead crossmember. Appears to be fixable. Slight surface rust here and there.
PICK UP ONLY
pictures upon request. make offer....no offer refused... i'm partial to Molsen...
Old May 23rd, 2006, 06:20 PM
cdmbrennan
Chris Brennan
A case of Molsen?
Any pics?
Old May 23rd, 2006, 07:14 PM
Lyman
Lyman Saltsman
1987 Rokon Ranger
sure... that would work...pick up only., not going to ship, or load....only thing saving it from the plasma cutter is a case of Molsen...
i'll get some pics up, but it's worth the case...the wreck can be seen here:
http://www.defendersource.com/forum/...ead.php?t=7729
Old May 29th, 2006, 07:50 AM
Lyman
Lyman Saltsman
1987 Rokon Ranger
here's some pics. bend is right hehind hulkhead out riggers.
i type faster than i shoud....
ID:	5768   Click image for larger version
Old June 1st, 2006, 07:39 AM
Lyman
Lyman Saltsman
1987 Rokon Ranger
cutting it up Saturday...if anyone want's it, and can pick it up...i'll overlook the case of Molsen...
Old June 1st, 2006, 01:21 PM
Is there a differance between the NAS rear cross member and the TDI cross member. Maybe gas tank mounts? My rear cross member isn't perfect and will need replacment.
Old June 1st, 2006, 01:59 PM
Lyman
Lyman Saltsman
1987 Rokon Ranger
rear crossmember is the same.... NAS skid plate mounts to hitch mount holes on the Tdi chassis. I think i would go new if i were taking the time to replace a rear crossmember...George has them.
This crossmember is not perfect...but is very solid...we're running a VERY challenging trail Sunday, if you want to come over for the ride...and leave with an extra frame...
Old June 1st, 2006, 02:01 PM
KO, I was thinking frame swap in a couple years anyway, this one should hold for now.
Old June 5th, 2006, 06:41 PM
Lyman
Lyman Saltsman
1987 Rokon Ranger
ok...it was too wet to fire up the plasma cutter last saturday...but it will be cut up this weekend if no one takes it...
300tdi, fs, tdi
FS new galv. 109 coil sprung frame ECR For Sale - Parts 7 July 7th, 2009 10:59 AM
FS NAS D90 take out frame, no rust ECR For Sale - Parts 8 June 13th, 2009 02:03 PM
NTO Windscreen Complete and bare frame FS SafariHP The Vendors Loft 0 February 1st, 2009 08:56 PM
FS Defender 110 V8 frame, used ECR For Sale - Parts 4 August 29th, 2008 12:26 PM
