Need left hand swivel housing from rhd - Defender Source
Old May 3rd, 2013, 04:57 PM
nfbeckman's Avatar
nfbeckman
Nick Beckman
1996 Disco 300 TDi 5speed
I need a left side swivel housing from a rhd defender or disco for a project I'm working on. Anybody have one laying around?
1996 Disco 5speed 300tdi
Old May 3rd, 2013, 05:07 PM
Roving Beetle
Doug
I do. No idea on value - not cheap to ship though. Let me know what you think.
Doug
Series coiler monster in building process, in gather parts mode.
Currently driving an ex-southern 1993 SWB RRC with too much "kit". Massive conversion and interior swap in process.
Lots, lots and lots more have come and gone....
Old May 4th, 2013, 06:52 AM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
If you do not match both sides up you may have different bearings in each side. You can find some used Disco stuff and get a matching set pretty cheap.
Old May 4th, 2013, 09:19 AM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Shit - just realized I am going to need one for an upcoming project as well.
I know there was a difference between the Disco and NAS Defender swivels and swivel housings but what about UK RHD ones? I would love to get one with a Railco top bearing.
Old May 4th, 2013, 11:09 AM
rayfi's Avatar
rayfi
Derek Moeller
110
I have a RHD defender front axle with a bent housing. Shipping from Oregon would be $$.
Old May 4th, 2013, 12:00 PM
nfbeckman's Avatar
nfbeckman
Nick Beckman
The axle im using is 1998 disco.
Old May 4th, 2013, 01:08 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
I am doing my front axle build off a Disco 1 axle as well. If you find a source please post. Thanks!
Old May 4th, 2013, 01:55 PM
rayfi's Avatar
rayfi
Derek Moeller
110
This is what I have. It's upside down by the way.
ID:	71479   Click image for larger version
Old May 4th, 2013, 02:26 PM
nfbeckman's Avatar
nfbeckman
Nick Beckman
If you can ship just the left swivel housing. I need it!
Old May 4th, 2013, 04:19 PM
Roving Beetle
Doug
The one I have is from a 93 110. If you have need ill ship it right out.
$50 shipped? Is that fair? No clue.
------ Follow up post added May 4th, 2013 04:20 PM ------
Hell you can have both sides for 70 shipped.
Old May 4th, 2013, 04:36 PM
nfbeckman's Avatar
nfbeckman
Nick Beckman
Sold! pm me your paypall !
Old May 5th, 2013, 07:40 AM
Capt Milks's Avatar
Capt Milks
The swivel housings are different between the Disco and the Defender and even in the Defender years. Most if not all of the bottom bearings are the same but the top bearing and pin can differ. Also the earlier Defenders have a longer housing and stub axle. You also have 1o spline vs 24. The Disco Parts are easier to source but you have to plug in the ABS sensor hole in the top pin, leave the sensor in or source the Defender top pin that doesn't have the ABS sensor hole. In the end I have found it easier to go to a junk yard and get a Disco set up. If you do that you can get everything that you need and might be able to score some nicer swivel Balls.
Old May 5th, 2013, 08:52 AM
Mybluett's Avatar
Mybluett
Defenders Northwest
110SW
Good advice - not so easy to find a RHD Discovery in a junkyard in the USA though.
Old May 5th, 2013, 09:21 AM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Agree - thanks Capt Milks for all the info. I had an idea that was the case but wasn't sure.
Probably a shit ton of the Disco left side swivels in the UK but no so much in the US. Unless there were some US Discos that came with a LHD outer swivel?
Old May 5th, 2013, 11:48 AM
Capt Milks's Avatar
Capt Milks
I have seen some of the earlier Discos that had both the RHD and LHD swivel housings but probably would be hard to find one I would guess. I know I have some earlier RHD stuff when I did a conversion but it is the older 10 spline stuff.
I am sure you could get a used one from the UK but shipping would be costly.
rhd
RHD Steering Housing for 24 spline fronts NPT90 Wanted 10 January 11th, 2013 04:24 PM
LH swivel outer housing from RHD truck Jopadorr Wanted 4 May 25th, 2011 03:59 PM
D-90 air filter housing cap needed (horn) arbik Wanted 4 November 30th, 2010 12:45 PM
RHD too LHD left over parts FS Dash, P steering etc SafariHP The Vendors Loft 4 October 25th, 2009 08:11 PM
