NAS H.D. Rear Bumper - Defender Source
Old June 17th, 2014, 05:25 PM
Chris Stockdale
Chris Stockdale
2002 Discovery
I had my fabricator put together a new rear bumper that follows the contours of the NAS, but with a couple of subtle changes. I widened the step 2.5" and increased the tubing size to 1.91 OD vs. the 1 3/4" factory. Also added real diamond plate vs. the rubber/plastic that was on there. Receiver is class III specs and we are pricing at $900 plus shipping.
The bumpers come powder coated semi gloss black, but can be a different color should you so desire at an additional cost.
I need to know if it would be for a true NAS or ROW vehicle (set up is slightly different).
Call me directly to order please.
Texas Defender Imports
512-332-1335
ID:	96989   Click image for larger version
Old June 17th, 2014, 05:40 PM
nicely done
Old June 17th, 2014, 05:47 PM
Nice bumper. But those sneakers.....so.........
Old June 17th, 2014, 05:48 PM
I think you also need to know NAS D90 or NAS 110
Old June 18th, 2014, 10:44 AM
Chris Stockdale
Chris Stockdale
2002 Discovery
The sneakers are extra!
Old June 18th, 2014, 10:58 AM
As a bit of constructive criticism I would suggest using the original size tube and going back to the original step width. The larger tube looks out of proportion for where it sits on the truck and a better way of increasing strength would be to use a heavier wall tube of the same diameter. I don't think the original ones were very thick, .120 tubing would be much thicker and stronger than the originals.
As for the step, the wider step just eats up even more of the departure angle than the original bumper.
Just my $.02, good luck with the project.
Old June 18th, 2014, 11:20 AM
roverman2010's Avatar
roverman2010
1985 LR 90 200Tdi
Will this fit a Marsland replacement LR90 Td5 xmember chassis
Can you do a picture the 2 lower arms that bolt to the chassis (anti-roll bar pick-up points)
Galvanized?
Gotta think about this, as I have used the two jacking points in the xmember in the past and are very handie.
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
97 XK8 BRG FHC For Sale
Old June 18th, 2014, 12:47 PM
Chris Stockdale
Chris Stockdale
2002 Discovery
I just looked at an image of the TD5 cross member from Marsland you referenced and cross member mounting points look the same, so yes it should mount up. I can have the bumper galvanized at additional cost - probably additional $150, and if you send me a picture of your setup on the lower side I can match up with what you have.
------ Follow up post added June 18th, 2014 11:48 AM ------
As a side not, I can do an exact replica of the NAS rear bumper, less the rubber step (I would use diamond plate unless otherwise requested).
Old June 18th, 2014, 12:52 PM
Brewie212's Avatar
Brewie212
Brian Kandefer
I believe RN sells the rubber matting
Old June 18th, 2014, 12:53 PM
Chris Stockdale
Chris Stockdale
2002 Discovery
Great on the rubber matting. Thanks
Old June 18th, 2014, 03:13 PM
Paul K's Avatar
Paul K
Paul Kennington
'85 Ninety V8 SW
What is the difference between RoW and NAS fitment? (After I spent a fortune adapting a RoW rear bumper to have a receiver hitch...)
Current fleet: '85 Ninety 3.9 V8i Auto SW, two Discovery 1's (one for my Nephew, one for my Niece),'07 BMW 335Xi.
Old June 18th, 2014, 03:16 PM
Chris Stockdale
Chris Stockdale
2002 Discovery
It's just where the bottom bracketing goes. Row will go to the chassis, where as NAS goes to the rear mounts attached to the fuel cell protection
Old June 19th, 2014, 07:52 AM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
Nice work. Years ago I removed OE primarily because on my truck it trapped debris and held moisture against the rear cross. I was getting concerned about corrosion because I use it daily and can't keep cleaning out the traps.
Would there be a way to accommodate some spacing to help prevent this in your bumper?
Clay
bumper, nas
Looking for an ARB bumper and rear step bumper pacificwildfire Wanted 2 March 23rd, 2011 10:28 AM
galvanized rear bumper and rusty front bumper mattdh For Sale - Parts 5 August 13th, 2008 11:17 PM
Factory Nas '97 bumper or bumper that fits a xd9000i warn winch Frankie Carbone Wanted 1 July 6th, 2007 07:05 PM
Rear bumper ends.... with stock bumper CDN38 Wanted 8 January 16th, 2007 07:35 PM
FS Front Wrap Around BBar, Bumper and Rear Bumper Mike M For Sale - Parts 6 November 18th, 2004 08:00 PM
