Misc Rover Parts - D90 and Range Rover - Defender Source
Old September 13th, 2016, 02:50 PM
Defender Parts:
1. Used Safari Gard 3-Link Cross Member: $250 OBRO
2. New, Unused Safari Gard Rear Corner Guards - $450 OBRO
3. Soft Top Bench - $250
(The back is in rough shape, the seating area is pretty good, the hardware is in good shape, will be perfect if you get a set of covers)
Discovery II (D2):
2 New Safari Gard Weld On Diff Guards $100 each OBRO (Can be welded on anything)
Range Rover P38:
1. RR Transmission - I believe it is from a 1999 - Not sure of the mileage. - $300 OBRO
2 RR Transfer case - Also from a 1999 - $275 OBRO
3 RR Sunroof entire assembly from a 2002 - $275 OBRO
4. Safety Devices P38 Roof rack with Wind Farring - $1900 OBRO
Range Rover Sport:
4 2012 Range Rover Sport Wheels - $600 OBRO
Will ship at your expense
Thanks for looking!
ID:	157542   Click image for larger version
ID:	157544   Click image for larger version
ID:	157546   Click image for larger version
ID:	157549   Click image for larger version
ID:	157552   Click image for larger version
ID:	157554   Click image for larger version
ID:	157557   Click image for larger version
ID:	157559   Click image for larger version
Old September 20th, 2016, 06:16 PM
Make an offer!
Old September 20th, 2016, 06:33 PM
D90Overkill's Avatar
D90Overkill
David Frank
1995 ST #2516
Can a 90's crossmember swap with a RRC? I'd love to not have to pull the crossmember on the classic every time I drop the tranny pan. My 90 is in another state right now, otherwise I'd just compare.
Love the rack, but long money and long miles ;-(
"Barry is correct!"
Old September 21st, 2016, 10:19 AM
I don't think so... My 100" is on a RRC frame, otherwise we would have used the SG cross-member.
I will double check for you though.
Old September 21st, 2016, 11:20 AM
Kevin88RRC's Avatar
Kevin88RRC
Kevin Keith
1988 RRC
I'm not 100% sure but I think the crossmember is swappable. I sold an early straight version from an '88 RRC to Ren Ching for his defender project.
Old September 21st, 2016, 11:26 AM
Abrooks's Avatar
Abrooks
Tony Brooks
Do you have 4 or 5 RRS wheels? Are they 20"?
Old September 21st, 2016, 04:16 PM
I have 4, they are 19".
Which ones are you looking for?
Old September 21st, 2016, 07:04 PM
Abrooks's Avatar
Abrooks
Tony Brooks
If I could find a very nice set of 20" to replace my curb rashed wheels I would be interested.
Old September 22nd, 2016, 12:37 AM
D90Overkill
David Frank
1995 ST #2516
Originally Posted by woldd90 View Post
I don't think so... My 100" is on a RRC frame, otherwise we would have used the SG cross-member. I will double check for you though.
Gratzie!
"Barry is correct!"
Old October 21st, 2016, 12:17 PM
bmaster
Bill
1997/D90 Soft Top
do you have the hardware for the bench that mounts to the sidewalls inside the truck? the ones that hold the seat in place when in use?
Old October 21st, 2016, 07:43 PM
I do not have the hardware, just the seat. Sorry. It would not be hard to make them or have someone make them.
Old January 21st, 2017, 10:06 AM
Defender Parts:
1. New, Unused Safari Gard Rear Corner Guards - $400
2. New Safari Gard Weld On Diff Guard $80 OBRO (Can be welded on anything)
3. Safari Gard winch brush bar with skid plate . Set up for the Husky Winch. $2200, shipping is about $250
Range Rover P38:
1. RR Transfer case - Also from a 1999 - $200 OBRO
2. RR Sunroof entire assembly from a 2002 - $200 OBRO
Thanks for looking!
Old January 21st, 2017, 10:10 AM
Tvalenti27's Avatar
Tvalenti27
Thomas Valenti
97 D90 LE #226 (SOLD)
PM Sent for the SG Brush Gaurd
Old March 1st, 2017, 04:13 PM
Updated Prices or Make an Offer or Trades?
Defender Parts:
1. New, Unused Safari Gard Rear Corner Guards - $350 (set up for a SW, but can be notched for a ST, it needs to clear the nut on the rear tire carrier.
2. NAS Rear Step Bumper, with factory special washers $750 OBRO zero rust
3. Full set of White ROW Flares $200 OBRO
4. (2) Rear Matte NAS Flares $200 OBRO
5. 4 2" Suspension Lift aluminum blocks - Best Offer
6. Front Genuine RoverTime front Control arms (3-4" of Lift), made by Steve $200 OBRO
7. Rear Rockware Trailing arms $150 OBRO
8. Rockware spring retainers - Make Offer
9. Adjustable Pan Hard Rod $200
**Stock NAS 90 Parts I need:
1. Front and Rear Stock Drive Shafts
2. Tie Rods & Track Rods
3. Stock Front Radius Arms
4. Side Steps
5. Whatcha Got?
Series:
As I continue to build my 100", I am selling off parts I don't need to help fund my project.
It includes: The Top, sides, full rear series door. ~ $1000 Or Best Offer
I can be returned to stock or modified further for you needs. I can ship it, meet somewhere or hold it until the next event or your are close to Atlanta.
I also have a series windscreen, a series seat boxes, a RHD Series Bulkhead (for parts) - Make an Offer
I will add some pictures later.
Range Rover P38:
1. RR Transfer case - Also from a 1999 - $150 OBRO
2. RR Sunroof entire assembly from a 2002 - $150 OBRO
3. RR Transmission - needs the valve block. - Best Offer
Thanks for looking!
Old March 4th, 2017, 12:37 PM
bump
Old April 6th, 2017, 10:19 PM
colorover's Avatar
colorover
Brendon Loveday
95 D90
PM sent
Old April 7th, 2017, 04:46 AM
badvibes's Avatar
badvibes
Jeff
1991 RRC
PM sent re: Rovertym control arms
Old April 8th, 2017, 08:09 AM
fishEH's Avatar
fishEH
Brett Fritzler
94, 95, 96 D1's
PM sent on the trailing arms.
parts, d90, range rover, 90, part
Parts Bin Lettings - Misc Parts for Sale Olde Lode Lane For Sale - Parts 16 May 2nd, 2016 12:01 PM
FS: D90 Soft Top Window Storage Bag and misc softtop parts kiphartzell For Sale - Parts 6 June 21st, 2013 06:01 PM
Defender and Discovery Parts: Wheels.Tires.Racks.Doors.Misc Parts KKilo23 For Sale - Parts 30 February 25th, 2012 04:49 PM
Feeler: WTB a D90 galvy frame and misc other parts. Roving Beetle Wanted 5 April 4th, 2011 08:02 AM
Very Nice D90 parts and MISC goodies in NC DOUGHBOYDD2500HD For Sale - Parts 18 August 31st, 2006 02:53 PM
