Misc parts - Defender Source
Old October 26th, 2015, 09:43 PM
Robbie Donaldson's Avatar
Robbie Donaldson
Robbie Donaldson
1995 Discovery
Misc parts
Would prefer to sell locally, but if small enough, willing to ship (on your dime). Best offer on all prices if they seem out of line.
STC1746 - ignition switch (new in box) - $100
Atlantic British Head bolt kit - 9224 (nib) - $50
YMT100050 - genuine pump harness (nib) - $100
STC8575 - brake hardware (pins, cotter pins, springs) - only half the kit (2 of everything instead of 4) (nib) - $2
FTC4785G / FRC8221 and a bunch of other seals (nib) - not sure price as there are a bunch of various seals
NTC6860 Control arm bushings (4) (nib) - $30
Front driver's side D90 caliper - used but perfect shape (dirty) - $50
AB Trailer wiring kit - $50
ESR2167 - coolant upper hose (nib) - $20
NTC7297 - lower coolant hose (nib) - $15
ETC6890 - heater hose (nib) - $5
BTR217 - heater hose (nib) - $10
BTR216 - heater hose (nib) - $5
Crower cam - 50227 (nib) - $75
Ranger Rover Classic fog lights with light guards - $50
Discovery manual seat surrounds (two plastic covers on the bottom outside of each seat base bottom) - $20
Edashkit - center console skateboard overlay (nib) - $100
ESR4065MH Mann fuel filter (nib) - $5
5 original Disco XD (yellow truck) wheels - stock black powder coated from Rover. Used but not abused. Some slight curb rash on one or two, but nothing severe. $200
Rear pinion guard (Marc Olivares build) - will not work with beefed up UJs - $40
DI sun shade - $20
Various odds and ends that hopefully I will get around to posting as things start to leave the garage.
email at rbd4a -at- yahoo.com. All items are in Herndon/Oak Hill area of Northern VA.
-Robbie
Name:	2015-10-26 19.08.11.jpg
ID:	133203   Click image for larger version
Name:	2015-10-26 19.10.11.jpg
Name:	2015-10-26 19.08.52.jpg
ID:	133205   Click image for larger version
Name:	2015-10-26 19.12.49.jpg
Name:	2015-10-26 19.13.07.jpg
ID:	133207   Click image for larger version
Name:	2015-10-26 19.13.19.jpg
Name:	2015-10-26 19.14.51.jpg
ID:	133209   Click image for larger version
Name:	2015-10-26 19.18.11.jpg
Name:	2015-10-26 19.19.17.jpg
ID:	133211   Click image for larger version
Name:	2015-10-26 19.18.39.jpg
1995 Discovery
1995 RRC LWB
Old February 27th, 2016, 03:49 PM
Robbie Donaldson
Robbie Donaldson
1995 Discovery
Updating listing and adding some things. Most of this is for Discovery I. See below for current inventory.
STC1746 - ignition switch (new in box) - $85
Atlantic British Head bolt kit - 9224 (nib) - $40
YMT100050 - genuine fuel pump harness (nib) - $85
NTC6860 Control arm bushings (4) (nib) - $25
Front driver's side D90 caliper - used but perfect shape (dirty) - $40
AB Trailer wiring kit - $35
Crower cam - 50227 (nib) - $50
Ranger Rover Classic fog lights with light guards - $20
ESR4065MH Mann fuel filter (nib) - $2
DI sun roof shade - $10
DI rear window motor/regulators - $10 for the pair
DI rear window wiper - $2
DI glass - sunroofs, rear windows and window frames, quarter window glass, cargo door window - free (you pick up)
RRC air bags and mounts. 2 brand new Arnott Industries, 1 mounted 1 not. $50 for the lot.
DI rear stock links - straight - $5
DI rear drive shaft - roto flex diff end - $5
DI sunroof ECU and and bits - $5
DI rear seat belts and mounting pieces - $5
DI (95) rear seats - dirty, but no tears, rips or cuts - $5
DI steering surround - great shape but one hole cut/drilled in the side - $5
DI a-arm trim pieces with speakers (2) - $5 for both
3.9 front cover (off of 95 DI) - worked perfect when removed. When replaced with 4.2, put a brand new cover and pump on just because. Comes with original oil pump gears - $100
Battery tie down clamp - just clamp, no hardware - $1
95 DI starter heat shield (I think) - $5
Sway bar quick disconnect kit (front and rear) - 3 out of 4 unless I can find the other pin. $5
DI driver's kick panel - $5
DI driver's side sun shade - $1
Britpart LGJ100900 guide valve x 8 - nib - $20
Safety Devices roof rack clamps x 4 - no hardware - $50
DI (94/95) rear lights - $20
DI (96+) rear light (right hand side when looking at rear of truck) - $10
RTC4647 x 2 (transmission drain plugs) - 1 new 1 slightly used - $5
YWT10002L x 2 - flasher relay - nib - $40
AMR4873 - flasher relay - $30
email at rbd4a -at- yahoo.com. All items are in Herndon/Oak Hill area of Northern VA. Would love for someone to just bundle these up and take the lot (or as much as possible).
-Robbie
1995 Discovery
1995 RRC LWB
Old February 27th, 2016, 04:40 PM
D90Overkill's Avatar
D90Overkill
David Frank
1995 ST #2615
Pm'd
part, parts
Defender and Discovery Parts: Wheels.Tires.Racks.Doors.Misc Parts KKilo23 For Sale - Parts 30 February 25th, 2012 05:49 PM
Misc D90 Parts brush guard, wheels/tires for sale or trade dnewman9 For Sale - Parts 5 October 15th, 2004 11:05 AM
Misc. D90 parts for sale Chris Cox For Sale - Parts 2 January 11th, 2004 10:15 PM
Misc. D90 parts for sale Chris Cox For Sale - Parts 9 November 13th, 2003 03:51 AM
