LT77 Transmissions - Defender Source
Old July 12th, 2012, 05:12 PM
Method PHX's Avatar
Method PHX
Brent Frazier
D130
LT77 Transmissions
1 LT77 Transmission w/70k miles, a Defender bellhousing, shift lever/knob, and no t-case linkage. $800.00 + Shipping (First 5 pics)
1 LT77 Transmission with unknown mileage, unknown bellhousing, shift lever/knob, and t-case linkage. $500 + Shipping (Last 3 pics)
PLEASE DON'T PM, email at wookie110@gmail.com
Many thanks
Brent
Name:	LT77 1 1.jpg
ID:	54154   Click image for larger version
Name:	LT77 1 2.jpg
Name:	LT77 1 3.jpg
ID:	54156   Click image for larger version
Name:	LT77 1 4.jpg
Name:	LT77 1 5.jpg
ID:	54158   Click image for larger version
Name:	LT77 2 1.jpg
Name:	LT77 2 2.jpg
ID:	54160   Click image for larger version
Name:	LT77 2 3.jpg
Method PHX: Defender Alchemy
Old July 12th, 2012, 05:32 PM
Abrooks's Avatar
Abrooks
Tony Brooks
Early or late boxes?
Old July 12th, 2012, 05:53 PM
First one with the long bellhousing is a later R380 L suffix box.
http://www.youtube.com/watch?feature...&v=Q02hoOuin5Y
http://www.ashcroft-transmissions.co...od&productId=6
Old July 12th, 2012, 07:12 PM
Method PHX's Avatar
Method PHX
Brent Frazier
D130
Reverse is in the Northwestern most gate, not the Southeastern most gate as an R380. I ran through the gears with these two trannies juxtaposed with a brand new R380. If I am wrong, I would love to know about it. It's happened before :-)
Old July 12th, 2012, 07:19 PM
texrover's Avatar
texrover
Jason
I might be interested if it's an R380
2003 RR L322
1971 Series IIA
1983 110 SW (Incoming)
1994 D90 ST (PO)
Old July 13th, 2012, 01:06 AM
Method PHX's Avatar
Method PHX
Brent Frazier
D130
Ren Ching was correct!!! I went back to the shop tonight and verified the shift pattern. That's an R380! Price is the same, my bad on the identification. Too many Defender parts and not nearly enough sleep.
Old July 13th, 2012, 01:24 AM
triple9music's Avatar
triple9music
Chad Davis
1984 Defender 90
is it for a petrol or diesel?
Old July 13th, 2012, 08:11 AM
Yes, 68A....L is a Defender TD5 gearbox, so will only fit a TD5.
Should post the S/N of the LT77 as the specific series affects values.
Old July 14th, 2012, 08:29 AM
There were Ls that went behind TDIs. I have one on my 90. Not sure how to tell TDi from TD5 units though I think the input shaft is the main difference.
------ Follow up post added July 14th, 2012 08:30 AM ------
Looked again it is a 60A not a 68.
Present:
1960 SII 109"- "Red Square"
1984 90 Tdi- "Yamelo"
1988 RRC- "Chewbacca"
1987 RRC- "Chewy 2"
2008 RRS SC- "The Supersofa"
Past:
Old July 14th, 2012, 01:14 PM
triple9music
Chad Davis
1984 Defender 90
if it's an R380 that'll fit a 300Tdi I'm interested but I think I'm in line behind texrover. plus would need to know shipping to 29464.
Old July 15th, 2012, 10:00 AM
texrover's Avatar
texrover
Jason
If it will mate to a 200tdi I'm in
Otherwise trip-9 can lick it
2003 RR L322
1971 Series IIA
1994 D90 ST (PO)
Old July 19th, 2012, 09:12 PM
Method PHX's Avatar
Method PHX
Brent Frazier
D130
Number on the LT77: 50A0114789D
QUOTE=Red90;359783]Yes, 68A....L is a Defender TD5 gearbox, so will only fit a TD5.
Should post the S/N of the LT77 as the specific series affects values.[/QUOTE]
Old July 19th, 2012, 09:29 PM
That is a pre Defender 90 or 110 box. Smaller layshaft bearings than the later models.
http://www.red90.ca/rovers/gears.html
Old July 19th, 2012, 09:32 PM
See here for details on the suffixes. http://www.ashcroft-transmissions.co...d&productId=78
Old July 20th, 2012, 12:26 AM
texrover's Avatar
texrover
Jason
Ok I've finally woken up to the serial number in pic#5; 60A not 68A as corrected above.
Looking at the Part Catalog I don't see a 60A suffix "L" but prefix 60A is a V8
Brent let me check on sourcing a bell housing tomorrow...
2003 RR L322
1971 Series IIA
1994 D90 ST (PO)
Old July 20th, 2012, 08:34 AM
the rover shop
shayne young
If its a v8 trans it won't fit a diesel.. Different input shaft sizes and lengths... Too costly to convert
Old July 20th, 2012, 08:37 AM
texrover's Avatar
texrover
Jason
Ah good man I should have known that already
Actually last night I thought "I should just call Shayne, 'cause he'd know all this shit"
2003 RR L322
1971 Series IIA
1994 D90 ST (PO)
Old July 20th, 2012, 08:55 AM
the rover shop
shayne young
You say the nicest things... Lol...
transmission
LT77 or R380? MAX711 Defender Technical Discussions 3 October 1st, 2010 02:29 PM
LT77 and V8 Stork17 Defender Technical Discussions 4 November 7th, 2008 03:15 PM
Lt77 Output shaft replacement Hans Defender Technical Discussions 5 December 9th, 2005 04:33 PM
Lt77 TexasD-90 Defender Technical Discussions 4 November 8th, 2005 04:39 PM
serial # differences from lt85 and lt77 draaronr Defender Technical Discussions 1 August 30th, 2004 11:56 AM
